09-08-2023, 12:17 PM | #67 |
Rep 214
Silly question maybe, but stock pads have an adhesive for the pistons to adhere to. If the aftermarket pads don't have them, do you just grease the backs and put them on? Was hoping to hot swap track pads for track days and oem for daily driving, but I feel the backing plate on the oem pads will delaminate when removing and make them useless afterwards.
10-17-2023, 04:39 PM | #68 | |
Rep 477
I was wondering if both sets came with sensors. Couldn't find clear answers about it Thx |
11-04-2023, 07:43 AM | #70 |
Rep 32
The iSweep pads are the only aftermarket pad I could find for my ZTK. I have the IS2000 on the front(waiting for the rears).
Very happy with them so far! Better than stock in all ways! |
11-27-2023, 09:22 PM | #71 |
Rep 32
Just had time to install the rear ISweep IS200 brake pads on my ZTK M340i Xdrive.
Had just the front Is2000 pads installed for a bit and they they had enough extra torque over the stock rears to induce oversteer if you got on them hard! Now that I have them front and rear the braking is much, much better than stock and the dust is much, much less and a light brown that washes off very easily compared to the glue like stock dust😃 No noise…. Wish Pagid made the RSL29 pads for the ZTK brakes as that’s what I ran on my E39 M5 and E85 Z4M Roadster and really liked them but these are pretty dang good👍 |
AddictedTo///M220.00 |
11-29-2023, 08:43 PM | #72 | |
Rep 473
11-30-2023, 12:59 PM | #73 | |
Rep 5,508
Apparently in Japan the M340i only comes with the larger calipers - they do not get the smaller Supra/Z4 Brembo calipers we get. I had a set of ZTK Type PS pads that I sold a few months ago on this forum. https://g20.bimmerpost.com/forums/sh....php?t=2007773
Auto Detailing Enthusiast!
12-04-2023, 06:38 AM | #74 |
Rep 66
12-04-2023, 11:35 AM | #75 |
Rep 32
12-20-2023, 08:29 PM | #77 |
Rep 473
I am looking to get new pads/rotors soon.
I am in two minds in just getting the OEM (which I assume are Brembo Low Met pads) and the Hawk 5.0. Now in another vehicle that had a similar braking system (Brembos) I replaced the OEM brembo pads with Hawk HPS (which I think the 5.0 replaced) and I found the cold initial bite was not the same. Needed extra pedal pressure when stone cold. I did not like that. Even though it was slight, I didn't like it. On that car, the next set of pads I went back to Brembo Low Met and they were just better. High temp wise didn't seem any worse than the Hawk and cold were just much nicer. Anyone comment on the Hawk 5.0 compared to the OEM/stock Brembo pads when stone cold. Are they the same feel? Also I have not been able to see any graphs or comparisons of the Brembo OEM's vs Hawks 5.0 - that would be great to see. I am wondering if they are really much better hot while still feeling the same cold? |
12-20-2023, 09:46 PM | #78 | |
Rep 1,180
cyam208.00 |
12-21-2023, 12:12 AM | #79 | |
Rep 473
When you removed the OEM pads, could you tell what pads they were? Where they Brembo Low-Met pads? They have the black backing which seems to imply they are the low-met. |
12-21-2023, 12:15 AM | #80 | |
Rep 1,180
I did not observe any branding on the pads but they did have black backing, IIRC.
cyam208.00 |
12-21-2023, 02:39 PM | #82 |
Rep 473
12-21-2023, 03:01 PM | #83 | |
Rep 5,508
Brembo for OEM has two different compounds. One is a low dust low torque application for normal street cars. The other is a high dust high torque application for sporty cars. They're all made in China to cut costs yet Brembo charges a high premium for the brand name. Neither will hold up on an actual track day and neither are ideal for street use as its either no braking torque or high dust. Brembo does make racing brake pad applications but those are not available for street use. Hawk has been making average "high performance" brake products for years. Their compounds are really dated and the technology is not there. You get some low dust low torque applications like the HPS 5.0 for street use. Stuff that can't handle a spirited mountain road drive much less track use. Then you can step up to a HP+ which squeals and dusts a lot, needs time driving to warm up before it works but they say is "street use". Then for track they have brake pads that use high metal content that destroy wheels and eats paint if it gets wet. Only plus for Hawk is that it is relatively low cost since it is American made and locally available.
cyam208.00 |
12-21-2023, 03:11 PM | #84 |
Rep 5,508
As for pads I have used,
I currently run Project Mu pads on my street car and track day car. They have a wide range of pads from street to race day. They have been building enthusiast brake applications for over 30 years and continue to introduce new compounds for specialty applications. Official brake pads for use in Super GT racing series, WRC, GT86 Cup car racing and other racing series. They have many "hybrid" street/track compounds that can actually be used for both with little drawbacks. I have run Endless pads as well. They are similar to Project Mu but at a higher price point. Porsche uses Endless for their race cars. Both Endless and Project Mu are high quality and 100% made in Japan. Ran Ferodo, not recommended, outdated pad compounds. They'll recommend DS2500 pads for everything (its a 40 year old brake compound) and it is neither good for street or track. Ran Stoptech, the Sport pads work very good. Like a DS2500 but newer and better with less noise and dust. Do not get the Stoptech Street as they're rebranded Centric pads. Ran Carbotech, good track day compounds. Their street stuff is ok but the XP line of track day pads are excellent with high torque. They don't eat wheels and paint unlike many other track only pads. Have not run Counterspace Garage but recommended for track use. It's a newer California company with a few good track day compounds. Run by many on track days. Ran Hawk and Brembo pads before... not impressed. Here's my current collection of brake pads that will eventually find their way onto my cars. There's a few thousand dollars in brake pads here to be used and tried. I have 3 BMWs - 1 regularly tracked. I'll eat through a set of brake pads every 2-3 months from track use @ $300-500 per set. So I go through pads a lot. Japanese pads for European applications are special order so I order them in batches so I always have extra pads ready.
12-21-2023, 03:42 PM | #85 | |
Rep 214
12-21-2023, 03:51 PM | #86 | |
Rep 5,508
I did a quick google of the RSL 29. Just be aware that some track compounds have brake dust will bond with paint. So you will want to wash it as soon as possible after a track day or the dust will become a permanent part of your wheels and paint. Most track only pads are not good for street use as they squeal, dust and need heat to work well. Should be fine if track is the primary use of your car.
12-21-2023, 03:57 PM | #87 | |
Rep 1,180
12-21-2023, 04:01 PM | #88 | |
Rep 5,508
I highly disagree with CSG's marketing of their CP pad. They compare it to a DS2500 and a Project Mu Club Racer?! The DS2500, as I mentioned earlier, is a very outdated pad and the Club Racer is a track day pad. The charts show that the CP is lower noise, dust and wear than both. What they don't show is that the Club Racer has way more braking torque and has double the heat capacity of the CP. This is a apples and oranges comparison! It's like saying the Prius has better fuel economy than the Ferrari... They should be comparing the CP to something similar from the Project Mu line up like a Type PS. But its marketing... they want to make their pad look favorable. And holy sh!t, they cost way more than Project Mu and Ferodo.
peelerec1053.50 |
