2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Wipers stuck up. Fixed
      05-06-2024, 08:59 PM   #1
jpeckinp
Drives: 2024 M440i Convertible
Went to use the wipers and they did a half pass and stuck up. I can hit the switch and they try to move but won't go down. 1400 miles and first warranty claim.
      05-06-2024, 09:38 PM   #2
bimmer456
Drives: 340i
Maybe they’re in service mode
      05-06-2024, 09:53 PM   #3
jpeckinp
Wouldn't they go back down when told or on a power cycle?
      05-06-2024, 10:06 PM   #4
peelerec
peelerec's Avatar
1045
2022 BMW M340i  [10.00]
Sounds like you put them in service mode / car wash mode.
Try pushing engine start/stop three times and then pulling down windshield wipers + hold for three seconds.
      05-06-2024, 10:37 PM   #5
jpeckinp
I was in a car wash when it happened.
      05-06-2024, 10:41 PM   #6
jpeckinp
Just tried they move maybe a 1/4 inch.
      05-06-2024, 11:47 PM   #7
peelerec
peelerec's Avatar
1045
A car wash that makes contact with the car or touch less?
If it’s a car wash with brushes that make contact, then it’s possible they caused damage.
      05-07-2024, 01:20 PM   #8
jpeckinp
It was after the brushes. Unfortunately.
      05-07-2024, 08:15 PM   #9
jpeckinp
Dealer found my issue. It was my tuner. The box for the JB4 was blocking the wiper motor.
Got read the act about how if they read the ECU that will be reported to BMW and it will be in the data base and it will void my warranty. She didn't like it when I mentioned the Magnuson Moss.
bmwz46728.50
      05-08-2024, 04:46 AM   #10
komoornik
Drives: M440i G23
Did you really take your car for a warranty claim with JB4 connected? 🤔
      05-08-2024, 05:37 AM   #11
Stag77
Stag77's Avatar
97
Drives: '24 M340i XDrive
It's one thing to cite the law, but it's an entirely different thing to actually employ it. Expect BMW to deny any warranty claim for the powertrain. The B58 is a robust engine, so hopefully you won't run into any issues that warranty would've covered. Glad to hear your wipers are fixed.
      05-08-2024, 12:13 PM   #12
jpeckinp
It wasn't actully connected to the system. I had it disconnected from the ODB. I really wasn't expecting the JB4 to be blocking the wiper motor.
Her explanation was even if it wasn't seen with their eyes the ECU would still register that it had been adjusted by the JB4 and would be picked up by their scan.
Honestly not sure if she was feeding me a line or not. My first dealings with BMW, so I don't know if the ECU will actully register the mod or not.
      05-08-2024, 12:26 PM   #13
jpeckinp
She did say as of right now BMW doesn't know. Just her and the tech. They didn't read the ECU.
      05-08-2024, 06:23 PM   #14
Stag77
Stag77's Avatar
97
I imagine you may be able to slip under the radar with smaller warranty work, but rest assured, if you blow your engine, they will check, and they will find it.
      05-08-2024, 10:48 PM   #15
jpeckinp
That's what I'm curious about. I thought the piggyback setups weren't detectable if they are removed before service.
From the JB4 site " Installs and removes without a trace."
I mean obviously if I needed anything done that was powertrain related I would pull it off and reconnect back to stock. But if they truly are registering something in the ECU then isn't Burger MS using a little false advertising?
      05-10-2024, 02:44 AM   #16
Stag77
Stag77's Avatar
97
My information is all second hand, so I certainly can be misinformed, therfore I won't go so far as to make any assumptions about BMS. From my reading around, a piggyback isn't easy to detect, however, if they decide to dig deep enough, they will find what they are looking for.
