03-15-2024, 09:21 PM | #1 |
Rep 28
what engine oil for tuned engine?
I have a stage 2 m340 and I was wondering what type of oil I should use? before I would use molly 0w30. should I change that ?
03-15-2024, 10:44 PM | #2 |
Rep 472
Boy I wouldn't run a 0w30 or lighter oil in these cars unless it's sub-zero all year round.
I'm in Australia and BMW state 5w30. That's the lighest oil I'd use. The only reason BMW states a 0w20 or 0w30 oil in some countries is for emissions, but it ain't doing your engine any favors. I'm running MHD "Stage 2" and have a dp, and colder plugs. So nothing wild at all. I continue to run 5w30 LL01 oil which is factory spec for this car here. I have a 2020 M340iX. Last edited by cyam; 03-15-2024 at 10:50 PM.. |
kingm3403.00 |
03-16-2024, 09:45 AM | #3 | |
Rep 472
May I ask which plugs you are running? Thx |
kingm3403.00 |
03-16-2024, 11:00 AM | #5 |
Rep 472
I read that these ones are more for the Gen 1 B58 and that ngk 96206 are the ones for the B58TU.
Did you know? Did you do any logs? I'm curious cause I done the same and maybe thinking switching for the right ones. They actually go deep 2 mm in the combustion chamber but does it make a difference.... Thx |
03-16-2024, 11:16 AM | #6 |
Rep 472
From my understanding they are the plugs for the TU.
Yes done logs, all good once I got the fuel and tune right. I am in Australia and fuel quality is bad. I gapped slightly wider at .026" than the 0.022 tuners say. But narrower than the factory 0.030" |
03-16-2024, 11:32 AM | #7 | |
Rep 472
https://youtu.be/Gvnqp3PuCw0?si=Y4z6Mfizh8f4U3Wi And thanks for your input mate! G'DAY |
03-16-2024, 08:05 PM | #8 |
Rep 472
I removed a spark plug - the NGK 94201 I am currently using and compared side by side with the OEM/BMW/Champion ones I replaced.
The photo shows they are exactly the same. Same length etc. Only difference is the NGK has the electrode slightly more exposed, because thy are slightly colder plugs. |
03-17-2024, 08:58 AM | #9 | |
Rep 472
03-22-2024, 12:32 AM | #10 | |
Rep 241
