12-29-2023, 08:37 AM | #133 | |
Rep 2,203
Considering your question, I don't think swapping them out would be a particularly viable proposition. The cameras themselves detach from the mounting pads which can easily be replaced (BMW offer them as a replacement part for a few quid) this is mainly to facilitate refitting the camera, the front one most likely, in the event of a windscreen replacement since the high impact adhesive pad on the mount will most likely be buggered if you tried to peel it off and re-stick it to a new screen. I'm not sure whether or not the cameras themselves are separately available. The biggest problem I'd envisage would be removing the wiring as the harness runs from front to rear of the car if both front and rear cameras are fitted and obviously a much shorter harness if just the front camera is fitted. Still there would be a significant amount of pulling trim apart to remove the harness or harnesses, which again I don't know whether or not they are available to purchase separately either. |
05-05-2024, 03:34 PM | #134 | |
Rep 5
Hi. Does this mean if someone hits you from behind when parked, it won't record anything. Does the rear only activate when the front activates? If so thats no good for me so will get the U3000 instead. |
