2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA 07/2020.60 update
      11-13-2020, 04:52 AM   #23
Bmwphile
Bmwphile's Avatar
Drives: 2020 G20 330i
Originally Posted by BlackShadowKiwi View Post
If only mine would start the update, has downloaded and is now sitting on the update prepared screen, you will be told when the update can be applied, 2 days now, WTF?
Had the same problem with my previous update. The cause was insufficient charge in the battery to complete the install. Due to COVID lockdown, car was seldom driven, so battery slowly discharged (but car still started, no probs). Once the battery was recharged at the dealer, install was completed.
BTW, just completed new install this evening. Eagerly awaiting to see the new goodies!
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      11-13-2020, 11:17 PM   #24
achk
Drives: BMW U11 iX1 Xdrive 30
OTA update to 7/2020.54 pushed to my car in the last couple of days. Downloaded to phone first and then upload onto the car. The process was pretty smooth this time as car is properly charged up this time. Now need to pull out BimmerCode and redo all the codings.
Also updated to 1-2020 Map.
      11-14-2020, 01:21 AM   #25
Bmwphile
Bmwphile's Avatar
Early days with the update 07/2020.54. Can open and close windows via voice control. Pretty much a useless feature..easier to press a button. Except you can specify how far to open or close a window which is cool: halfway or even "a little bit open"! This is easier than holding the window switch to the required window opening position.
Disappointed can't open or close sunroof or internal blind with voice command.
BMWphile
      11-14-2020, 02:32 AM   #26
NoSUV4Me
NoSUV4Me's Avatar
61
Drives: G20 330i M Sport
Whats new with the boot lid thing?
If you have comfort access, currently just wave ur foot underneath to open
So ?
      11-14-2020, 07:05 AM   #27
AustraliaG20
Drives: 2019 G20 330i. 2015 F15 M50D.
So ?
Good question.. but I think it's simply the fact you can turn it off completely. Anyone else?
      11-14-2020, 10:33 PM   #28
ToeJoe
Drives: 2020 M340i xDrive
No. I'm confused by that too. BMW's change log is frustratingly vague.
      11-14-2020, 10:39 PM   #29
ToeJoe
I'm also disappointed you can't open the sunroof via voice.
I do like being able to switch driving modes by voice though. I hate having to look down for the Sport button and cycle through the Sport modes. Now you just say, "Activate Sports Plus mode". Yerrrrrrssssss
      11-15-2020, 12:43 AM   #30
Ikester19
Ikester19's Avatar
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
Updated to 07/2020.54 a few days ago and it went smoothly. I locked the car after the update and the radiator/aircon fan turned on, thought it might be the auxiliary ventilation but it wasn't. Unlock/locked the car again thereafter and it happened again, remained for a few minutes then turned off, hasn't happened since - weird! Also found that the green 'exterior lights on' symbol on the tach display is permanently on now. This might be due to the auto headlights feature being active, so now cannot tell when the headlights are actually on. As other stated all BimmerCode settings were lost as were widgets programmed on the display panel. Apart from that all good, will play around with some of the new options over the coming days.
      11-15-2020, 12:50 AM   #31
NoSUV4Me
NoSUV4Me's Avatar
61
The sunroof is essentially a window so I don't get why it won't be voice controlled!
And yes I had the same fan problem. Not recurrent
      11-15-2020, 02:37 AM   #32
achk
It's cool to be able to voice activate sport mode. But it all seems a bit half-baked as it won't go into adaptive mode by voice. Just like no sunroof control by voice.
      11-15-2020, 08:59 AM   #33
digitallust
digitallust's Avatar
Drives: 2019 G20 BMW 330i M-Sport
Originally Posted by erawamai View Post
Hahaha
If anyone is doing the update and has 20 mins I'd recommend sitting in the car while it doesn't it.
Battery charge is too low. Mine did the same. Chucked the Ctek charger on it over night and it installed first thing the following morning
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
      11-15-2020, 04:56 PM   #34
BlackShadowKiwi
Drives: BMW X3 G01 LCI M40i
All done, two trips of 40k's each and after second trip, it was ready to install.
Just needed to recode a couple of things and was done
Current: BMW G01 X3 LCI M40i Phytonic Blue
Current: BMW F40 m135i xDrive Black Sapphire
Retired: BMW G20 330i M Sport
Retired: BMW F30 328i Sportline
Retired: BMW F20 125i M Sport
      11-15-2020, 06:09 PM   #35
phayze
Drives: BMW
Anyone with this version and have HUD? Is the sport display in HUD working when u select “Display sport display when in sport mode”?
      11-15-2020, 07:03 PM   #36
SteveAus
SteveAus's Avatar
Drives: G20 M340iX
Yes. The horizontal rev display in the HUD works in Sport Mode.
No change from the previous version as far as I can see.
      11-16-2020, 07:19 AM   #37
phayze
Drives: BMW
What version of software you were upgrading from? And now you using 07/2020.60? Mine 07/2020.48 & 07/2020.54 not working. Sport display only display in HID when set to always.
      11-16-2020, 10:21 PM   #38
7crwolf
Drives: 2019 BMW 330i G20
Anyone having this issue since the upgrade? Not happy.
The top view is messed up, and I notice that the "greyed out" lines when opening doors are reversed (open driver door, it makes it look like passenger door is open).
      11-17-2020, 05:38 PM   #39
skylinebmwm5
Drives: 330i G20
I found the auto high beam icon is gone from dashboard after upgrade, and the auto high beam on/off button on the indicator stalk seems not doing anything anymore, is it the same for everyone?
      11-17-2020, 06:21 PM   #40
7crwolf
I'll check tonight. That would be a very bad update if they killed auto-high beam.
Are you having the reverse cam issue I showed?
      11-17-2020, 07:15 PM   #41
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
Drives: M340i, Mineral White
2020 BMW M340i  [0.00]
2013 125i  [0.00]
My M340i upgraded last week to 2020.60.
Have just double checked and the Auto high beam indicator displays correctly. ( I have laser lights)
      11-17-2020, 07:18 PM   #42
TikiTourer
Old Member
TikiTourer's Avatar
New Zealand
65
2013 125i  [0.00]
just checked my M340i and all images are correct. I played aroud selecting the different cameras but could not get anything to look like your pic.
      11-17-2020, 08:43 PM   #43
7crwolf
Thanks. My OTA upgrade version is 2020/07.54, not .60... This was the first OTA upgrade I got, with the issues I have it seems more like a beta, I'm surprised they rolled it out.
I have to book a service in the next month or so, I guess I'll push them to load .60 while they are doing the service.
      11-18-2020, 03:13 AM   #44
ClearSkies
Drives: 330i
I’m seeing this too. I have the sport display set to ‘In Sport Mode’ but when switching to sport mode it doesn’t appear in the HUD. Only appears when set to ‘Always’
