01-19-2023, 11:30 AM | #67 |
Rep 46
I dug around and found some eq settings in another thread and tried them and it really brought the sound stage together. Wish i could find the thread to share. I do hate how the screen doesnt give the eq +/- settings and is just a solid bar, kinda hard to adjust properly.
01-19-2023, 12:05 PM | #68 | |
Rep 406
I can't remember how it worked, but if that's true then unfortunately I won't be able to provide those specific settings as requested earlier in the thread. I thought it had precise increments of 10 above and below center but maybe it was just a slider. |
01-19-2023, 01:47 PM | #69 | |
Rep 83
Drives: '04 E46 ZHP 6MT, '22 G22 RWD
Soul_Glo13388.00 |
01-19-2023, 02:18 PM | #70 |
Rep 109
If break-in is a real thing, I hope my HK breaks in asap because it is currently not very good. Is there anything I can do to speed-up the break-in process short of leaving the radio on all night??? I can always charge the battery if it dies.
I have tried adjusting the settings with all of the suggestions on bimmerpost, and still it doesn't sound that great. having experienced the Mcintosh in Jeep and Bang and Olufson in Audi that are similarly priced upgraded stereos, and so many others over the years, I am used to hearing great sound day 1 and w/o much setting adjustments or break-in. Reality is I never went to an Internet forum to try and make my car stereo sound better until I got the 3 series with the HK. Hopefully, after the "break-in" period, I will be able to post that it sounds better, which would be great as I don't have the 4 grand to spend on an upgrade a car audio place. I will also say that I was a little worried whether an audio upgrade would void any warranty, and service told me it would not as long as it is done properly. If I do upgrade, I will keep the Harmon Kardon speaker screens so it looks like stock. |
01-19-2023, 02:19 PM | #71 | |
Rep 15
01-19-2023, 03:17 PM | #72 | |
Rep 73
Agree!!! When it comes to the so-called Harman upgrade that BMW offers on the new 3 series, that makes 2 of us. I would definitely pay for a better upgrade, but don't feel like removing the system that came with the car. |
01-20-2023, 12:20 PM | #74 | |
Rep 406
01-20-2023, 02:42 PM | #75 |
Rep 1,805
I coded B&W and use it along with the eq settings posted across the forum. It works well with the STUDIO profile. However if I remove my coding but leave the eq settings I can’t hear much of a difference but I left the code in there anyway.
HK does a decent job and those bashing it probably can opt for other solutions. But for the average listener I find it sufficient. Certainly not as powerful as my B&O home system but it gets the job done when driving. From outside the car (with doors closed) I can hear the bass while music is playing and it’s very clean. |
01-21-2023, 08:51 AM | #76 |
Rep 288
I also tried the code for the Bowers, and found it sounded a bit different, maybe better with ktreble and voice , but not significant enough to really change the overall sound when playing most genres.
01-21-2023, 12:20 PM | #77 |
Rep 140
Also somebody around here proposed to send the fader somehow to the rear and that helps a lot the way it sounds. He was right IMO. Bass magnified nicely.
upstate650308.00 |
01-21-2023, 01:41 PM | #78 | |
Rep 406
And although this part is subjective, I've never loved that the sound comes only from the dashboard in a default setup. With the fader moved a bit toward the back, the front passengers get a more encompassing sound. Fuller and more 3D. It's win/win, imo. FWIW, this is not to be confused with Surround mode which separates and distributes audio in a very different way. One I don't much like in most cases. (though Meridian handled it quite well in their mobile systems) |
01-21-2023, 03:35 PM | #79 | |
Rep 140
Well... Thanks a lot... made my music enjoyment a lot better inside my m440i!
02-18-2023, 11:06 PM | #81 | |
Rep 2,897
Now having said that, the overall sound is still terrible compared to the HK on my F30 340i I dont know if I have a faulty amp which is a common issue for the 20 and 21’s M340 or if the system is really this bad!! I’m going to start by fighting with the dealer to try and get the amp replaced, then I’ll try to upgrade the bass by adding a secondary amp / LOC and changing the under seat subs. Not sure if this will solve everything but it should be much better, at least I hope! |
02-19-2023, 07:30 AM | #82 | |
Rep 1,805
To your point about CONCERT, I tried them all but finally settled on the more natural option. |
02-21-2023, 05:20 AM | #83 |
Rep 147
[/QUOTE]Now having said that, the overall sound is still terrible compared to the HK on my F30 340i
I dont know if I have a faulty amp which is a common issue for the 20 and 21’s M340 or if the system is really this bad!! I’m going to start by fighting with the dealer to try and get the amp replaced, then I’ll try to upgrade the bass by adding a secondary amp / LOC and changing the under seat subs. Not sure if this will solve everything but it should be much better, at least I hope![/QUOTE] Is it possible to just get a new 22 or 23 "improved" amp and switch out the old amp like a straight plug and play? |
02-21-2023, 10:35 AM | #84 |
Rep 73
When it comes to the HK sound in the 3 series, I would say that nothing short of swapping out the amp, speakers etc will give you a good sounding stereo. I tried everything under the sun in terms of setting changes, codes, etc... to get my HK to sound half way decent and nothing worked.
The amp issue was something that was fixed by BMW a few years ago. It's not the amp that''s the problem. It's that the whole HK system is not good to begin with in terms of sound. It comes down to 2 choices, 1) read a million posts about setting choices and play with the settings for months on end and tell yourself it now sounds better (when it really does not), or 2) bite the bullet and spend 3000 - 5000 and really have a good stereo. |
james1138125.50 |
02-21-2023, 11:51 PM | #85 | |
Rep 2,897
02-23-2023, 12:40 PM | #86 |
Rep 236
For what it’s worth, I used the settings listed in this article, which I found linked somewhere on this site and it took the system from sounding bad to good.
https://totallyev.net/bmw-ix3-audio-...harman-kardon/ I did some adjustments from what the article recommended. I turned the bass up and turned down the treble because I tend to prefer a warmer sound. Even with the treble turned down, I did experience a little bit of listening fatigue after a while. I’m excited to try the settings listed in this post and adjust the fader towards the back in hopes that it will make the sound even better. I feel like the sound of the drums gets lost in the settings that I currently have. The tom and snare drums don’t hit as hard as I would hope they would. My gut tells me that the system can sound good but never great. My first love was home theater and hi-fi so I spend a lot of time listening to quality music and have a nice set up at home. I knew before buying this car that the stereo quality was going be a trade-off for me. I came from an Acura, which had an amazing stereo set up in it. Interestingly, there’s a great article about how car stereos are set up for optimal performance in this months Road and Track. The whole issue is worth reading, especially if you like music. One question I do have is does anybody know what impact the adjusting of the HK has on the car’s Iconic Sounds? I’m assuming adjusting the sound settings will impact the engine notes that are pumped through the speakers? I haven’t spent enough time with my car to figure out if there is a correlation with it yet, but I plan to. |
02-23-2023, 12:58 PM | #87 | |
Rep 354
Drives: 2023 M340i
You can test it in Neutral or Park. You will hear a clicking when you toggle it on and off. |
james1138125.50 |
02-23-2023, 01:37 PM | #88 | |
Rep 236
There is an element of the engine sound that goes to the speakers, right? Thanks |
