10-19-2023, 08:32 PM | #1 |
Rep 14
Drives: BMW G20 330i MSport 7/20 build
Software version 07/2023.5
New over-the-air software available today. 07/2023.53.
The release notes are quite vague. "Functional updates and improved quality". Should I hit go? Anyone notice anything major? Good or bad? I've got a 2020 330i M Sport Thanks |
10-20-2023, 04:40 PM | #2 |
Rep 69
It came out earlier this month. I think the consensus is that there isn't much new in it for id7 cars. Mine won't install so I can't give you any personal experience feedback.
10-20-2023, 11:33 PM | #3 |
Rep 20
I installed the update this morning. No noticeable changes to the UI over a short drive so I'd say it's mostly updates to existing id7 features as the description spells out in the images. I'd recommend upgrading if you can. I agree, I don't anticipate much changing with the id7 interface other than minor improvements here and there, with the new OSs, OS 8 etc out on newer vehicles.
A note: in my case, after upgrading I noticed, the "sporadic change of date and time" issue described in the uploaded image occured - which then erroneously flagged (on my instrument console, and MyBMW app) that future vehicle checks (Feb 2024 vehicle and brake fluid checks) are now overdue , so I might have to follow the instructions in that section to reset the time & clear the messages. Otherwise all good. |
Tim 472340.50 |
10-24-2023, 06:08 PM | #4 |
Rep 1
Lost service history
After applying the update 07/2023.53 on a 220, the car lost its service history and is now telling me I haven't had any services done. Frustrating and will now need to book in a service so they can fix.
10-25-2023, 05:24 AM | #5 | |
Rep 20
Otherwise check with your service dept/dealer. The image below is what my date & time settings (incorrect) looked like right after the update. I corrected it to fix my issue, hope this helps. |
10-29-2023, 08:02 PM | #6 |
Rep 28
Yep mine flagged oil service overdue after the reboot and engine light on. Sh*t myself until 8 realised it was the date issue. Also was Oct 2024. Manually setting and then back to auto worked and cleared up the service history issues.
2007 BMW 525i, 2016 BMW 440i F36, 2022 BMW M440 XDrive Coupe G22
