05-16-2014, 01:49 AM | #134 | ||
Rep 7,484
05-16-2014, 02:04 AM | #135 |
Rep 3,178
Too far away to get upset about any possible downsize in cylinders.
Although not surprising if it goes that way given the trend to seek out greener options, could be a good thing with the use of ERS-type technology, could allow for some interesting power unit setups
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
05-16-2014, 05:44 AM | #136 | |
Rep 1,935
But it will sell
My 1st love was 2006 BMW 325i Sport + Prem 6MT but I married the 2016 M3 BSM MDCT.
05-16-2014, 06:40 AM | #137 |
Fitness Gene
1113
Rep 2,413
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
if M division can squeeze 500 hp of out of turbo 4 plus make it sound real then why not.
Here is what some of you are missing, 4 turbo plus electric motor => i8
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
05-16-2014, 06:51 AM | #138 | |
Rep 3,218
Drives: 2018 BMW 440i GC
05-16-2014, 07:22 AM | #139 |
Rep 185
Drives: BMW
Won't happen. It's like salary.
LOWER Salary but better benefits at equal value. How does that sound? :P A turbo 4cyl sounds like a good candidate for M2 or Z2. Cylinder cut off maybe for the next M3?
[E30 325i | E39 528i | E46 M3 | E70 X5 | E90 M3 | F25 X3 | NA1.5 NSX | 718 GT4]
05-16-2014, 07:44 AM | #140 | ||
Moderator
7515
Rep 19,368
And the ICE in that setup is only a ~230hp I3. An I4 with the same specific power output would be over 350hp and BMW has already said they will hit 200hp/L in the relatively near future. Quote:
I don't see M Division taking the lead on the hybrid powertrain. It's not a cost effective way to make use of the technology. They need to be able to use the same formula as today - take the series car and modify it for performance. Once we have hybrid 3 and 5 series being sold as the volume product (not the special ActiveHybrid models they are today), only then the door opens for M Division to go that route as well. |
05-16-2014, 07:51 AM | #142 | ||
Rep 8,626
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
05-16-2014, 08:26 AM | #143 | |
Rep 9
2) I'm not too sure where you have gathered all your ideas and philosophies on 4 cylinder motors, but they can handle GOBS of torque. With a quality tune the engine isn't even the breaking point (4G63 I'm referring to in this case). The clutch, transfer case, rear diff, and transmission are more of a concern then the properly tuned motor. Trust me when I tell you, these little 4 bangers that I had been around for 8+ years will do a better job at breaking your neck then most cars out there will. Including all the 6 and 8 cylinder motors. The v8s were always my favorite to upset in the real world. You would be shocked at what stock turbos can do. As a matter of fact there are quite a few stock turbo Evos running 10 seconds in the quarter mile. I will tell you right now, BMW was very wise in choosing Mitsu turbos for the new Ms as well. They clearly have done their research. 3) We are referencing older motors here for the sake of this discussion, I want to be very clear with you. The point is to speak on behalf of the possibilities of the newer technology when applied to a 4 cylinder turbo motor, and what that new technology can do in combination with battery/hybrid power. You can create a 4 cylinder motor that utilizes a "larger" stock turbo. Volumetric Efficiency is what matters here and the reason why a larger turbo would be beneficial (Cooler, more condensed air), which doesn't need to be Overworked to provide additional power. Nor will it fall flat on its face like most stock turbos do in the upper ranges of the RPMs. This will provide the incredibly flat torque curve we all wish for on the street/track. Paired with electric battery power, which will ADD horsepower to the entire combination, it will fulfill the duties of torque-fill early on, where yes, you will with out a shadow of doubt, experience turbo lag in the 4 cylinder turbo motor ONLY application (Non hybrid). 4) NVH was never a topic of concern when it came to these motors. The CLA Motor itself wasn't Ever the primary concern of this car, it was the transmission. Like every other Mercedes. Not hating on Mercedes, but come on now, get with the times and fit in a proper auto/dct type clutch in there already. We are all entitled to our own opinions. Where you believe our automotive technology will be in 7 years, is not even close to where I believe it will be. The only thing I can share with you are my own personal experiences with 4 cylinder vehicles. I didn't borrow these thoughts and ideas from somebody else's experiences. I have seen, experienced, and applied many MANY combinations with a turbo 4 cylinder setup. Also, I just want to reiterate that the entire point of my first post was to imply that yes, BMW would be using Hybrid Tech with the upcoming M in combination with a 4 cylinder turbo. Hypothetical: 4 cylinder turbo Hybrid Motor 350+ hp developed by the 4 cyliinder turbo petrol motor (Simple and completely SAFE as a DD) 100+ hp developed by battery/hybrid technology Clearly all the cars are headed this direction. You ask me how in the world would BMW be able to create this Million $$ technology and fit it into a $75K package? Well... #1 The Majority of expenses incurred on the development of new technology happen at the very beginning, because it is well....New. #2 So far I have seen a $125K vehicle created by BMW that contains the Exact technology we are referencing. It's called the i8. #3 There is this other $45K car that BMW recently rolled out as well, it's called the i3. I'm not trying to be funny here, but it's the truth. 7 years down the road will BMW be able to figure out how to combine a 4 cylinder turbo with electric power? Hmmm...my answer with absolute certainty is, Yes. Last edited by Evoixiaoni; 05-16-2014 at 10:06 AM.. |
05-16-2014, 08:55 AM | #144 | |
Rep 9
This is clearly NOT an apples to apples comparison, but it is a way to demonstrate what a 4 cylinder motors curve can look like with a Large Turbo setup. BMW would NOT need to use a turbo charger of this size, nor would they need to use a twin scroll design, because they will have electric battery power to fill in all the gaps of the initial turbo lag. Where we used a twin scroll design here, we wanted to for this setup to aid initial turbo lag on the street. Where twin scroll designs help with spool, they will suffer on the back end, or rather, the upper reaches of the RPM curve. BMW can use an open volute turbo setup here, paired with electric battery power, and yes the car would be an absolute street monster. Love it or hate it, if it does happen, which obviously there a HUGE chances it will, it can be a significant street machine. And to GRUESOM3, in the next 5 years, yes that probably will be the case, but I believe in 10 years, there will be COMPLETE silence on the streets except the sound of tires! Last edited by Evoixiaoni; 05-16-2014 at 09:25 AM.. |
05-16-2014, 08:55 AM | #145 |
Moderator
7515
Rep 19,368
The I8 has an inline three cylinder with 235hp. We are talking about an I4 for the M3 with at least 300hp and possibly up to 400hp. The point of the I8 example is to demonstrate the type of technology that could be used for a future M model, not to suggest we literally drop the exact same (years old, by that time) powertrain into the M car.
05-16-2014, 09:31 AM | #146 |
Rep 8,626
@evoixiaoni
I agree with many points that you made other than there is a ton of assumption in there about the pairing of the motor with an electric system and how far 4 bangers can still come. The trap speed, turbo sizing and VE comments are spot on but once again... there will need to be a performance pairing that currently doesn't exist to get rid of that lag and improve responsiveness. The dyno curve you posted is incredible for the track but I do not want to drive that car on the street. I'm an FP green type of guy ... I am sure you understand it's TQ constraints on a 4g63. The electric pairing is merely an assumption at this point. Also, I highly question paying 80K for a 4 banger... that may be a mindset but its a pretty strong one just as I would not buy a 528i with a 4 banger.
05-16-2014, 09:34 AM | #147 | |
Rep 8,626
05-16-2014, 09:53 AM | #148 | |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
From a technology standpoint, I see two likely paths forward for higher specific output: 1) Higher boost levels (larger turbochargers) on smaller displacement engines, coupled with electric components for torque-fill. Look for a ~2.0L I4 with >1.8bar of boost pushing even higher specific output than Merc's M133 and a smallish (compared to the current crop of hybrid-hypercars) electric assist motor pushing 75-100 HP. 2) Electrical-scavenging/electric-assisted turbochargers. These exist, but we've not seen one in a production car. The energy recovery systems on current generation F1 cars have a generator unit attached to the turbocharger (this is called the MGU-H). This allows them to directly generate electricity from what would normally be wasted exhaust energy. Instead of a wastegate, they allow all of the exhaust energy to drive the turbocharger, and regulate turbine-speed/boost level with electrical charging resistance. This keeps turbine pressures up, even under moderate engine use, which alleviates lag. It's also possible to run current through a generator in the reverse direction in order to spool the turbo (they don't currently do this in F1). IMO, option 1 is more likely. Option 2 involves some very advanced turbo technology that is complex, and difficult to make reliable. We've seen other complex turbocharger technology fail in the marketplace, giving way to related, but less complicated advancements. I'm talking about variable geometry turbos versus dual-inlet geometry turbos. Dual-inlet geometry (branded TwinScroll) turbos beat variable geometry turbos on expense and complexity. We also have to consider that, arguably, all-electric is the future. Investing in turbocharger technology is investing in the near future. Investing in electric drive train components is investing in the long term.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
05-16-2014, 10:06 AM | #149 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
I think I might have omitted a third (and most disappointing) option.
BorgWarner has a system called eBooster that is basically a twin-sequential turbo setup where one of the turbos is electrically driven. I deem this one the most disappointing because it's a half-measure, IMO. In order for it to make sense from an efficiency perspective, you'd need to drive it from recovered energy, rather than drawing from engine power to push it. Otherwise it's just an electrically-driven supercharger (which directly robs engine power). If you're going to introduce the weight of an energy recovery system, the most complete solution is to use a hybrid drive train. In a hybrid drive train, the genset is directly attached to the drive line; usually an electric motor. In that case, it makes the most sense to send recovered energy back through those motors, rather than using it to drive a turbo. I suspect the eBooster system could be implemented more cheaply though. BMW could change to lithium batteries, increase the cell capacity, and use their current alternator driven energy recovery systems. This system attaches the alternator to the serpentine belt system at the front of the engine. The recovered energy is far less, because the system only works while the car is coasting, and most of the energy is eaten up by engine braking. A lot of people are excited about the electric-assisted turbo setup, but I'm skeptical.
05-16-2014, 10:51 AM | #150 | |
Rep 9
It doesn't take a technological genius to understand the complexity of having a 4cylinder ~2.0liter motor spool up a turbo charger (large or small) from the onset of pushing the gas pedal to the floor. In the real world, we all know this is next to impossible without some SERIOUS advancement in turbo/hybrid technology. The "lag" will, without a doubt, be apparent in the brand new M3 as well. BMW already knows that. So, my assumptions are just that, assumptions. You have made that clear and I have as well. Unless BMW is willing to spend significant money on the development of some crazy hybrid turbo technology or create an anti-lag turbo motor (this would go against the Green Emissions direction however ;-)), which they probably won't (like you have stated previously), they will absolutely combine the technology that is already at the forefront, in which they have already invested in developing in the i3 and the i8. All this is to say that although they are my assumptions, they are based of real world data and the current direction of automotive technology that exists today. Oh yes, the good old FP green turbos. Great street turbos! I would have been more of a FP Red/Black guy though. The low end torque provided by the smaller stock and green turbos is great for the street for sure. The high revving nature and power provided by the larger compressor/turbines turbos, however, ohhh so fun. And you certainly need that power up top when dealing with Zo6s and such at higher speeds. I can understand everybody's "concern" regarding paying $75K+ for a 4 cylinder, but as you said, that is just a mindset. The Evos have already proven that 4 cylinder motors can be ABSOLUTE BEASTS. That is a fact. I paid 36K for just that in my Evo: the motor and drivetrain (Ok maybe the Momo steering wheel and the Recaro seats as well, haha!) I didn't buy the Evo for the high quality interior and awesome plastic/fake carbon fiber everywhere. You pay for an Awesome (cast iron block) 4 cylinder motor and drivetrain, not class and luxury, that is for sure! In BMW M3s, you don't just pay for a quality motor/drivetrain, you pay for all the tech and luxuries that complement the motor/drivetrain. I'm with you ASAP, I wouldn't buy the 528i either. Just one question for you though, what do you mean when you say this? "there will need to be a performance pairing that currently doesn't exist to get rid of that lag and improve responsiveness." Last edited by Evoixiaoni; 05-16-2014 at 10:59 AM.. |
05-16-2014, 11:00 AM | #151 |
Rep 3,446
Total BS. Our leaders tell us it is climate change, I think it is weather.
See my photography at http://ronscubadiver.wordpress.com
05-17-2014, 01:47 AM | #153 |
Rep 3,446
Kind of hard to imagine. I think we need to quit worrying about C02 and enjoy life.
