05-20-2020, 01:34 AM | #23 |
Rep 50
UPDATE: I have found how to code it partially. Go to HU_MGU, search for "M EHICLE SP2018" and enable it. But just like victordura said, the car with green tires is missing.
05-20-2020, 01:36 AM | #24 |
Rep 20
05-25-2020, 01:00 PM | #25 |
Rep 1,481
Drives: 2020 M340Xi (G20)
Anything yet?
Al
05-25-2020, 01:02 PM | #26 | |
Rep 20
05-27-2020, 01:04 AM | #28 | |
Rep 20
Maybe some parameter that shows car with green tires can show also back template for this widget. |
IndotagSwizz524.50 akataka23.00 |
05-28-2020, 02:49 PM | #29 |
Rep 1,481
igorbutarev ,
First off, thank you -- I now have the instrument panel widget you started this thread with! I also discovered that, having made that widget active, I now can select either STANDARD (for my M340) or M heads up display from iDrive menu & let's me edit this view --except there is nothing there. I suspect if I activate more M widgets, there may be ability to display in HUD
Al
igorbutarev25.50 |
05-28-2020, 07:46 PM | #30 | |
Rep 56
we better check out KOMBI_HUD group in MGU module. Last edited by jaimeen77; 05-28-2020 at 07:51 PM.. |
05-29-2020, 08:32 AM | #31 |
Rep 36
Hi! I found some settings in expert mode. You can check if it work. I thinks is a laylout o head up display.
Here you can find widget group and HUD sport layout . It need be checked. Last edited by sztmek; 05-29-2020 at 08:39 AM.. |
05-29-2020, 08:23 PM | #32 | |
Rep 332
05-30-2020, 07:15 AM | #33 |
Rep 1,481
@sztmek ,
There is an entire section in the HU_MGU, M_GMBH, that has a lot of M HUD didplay widgets that bear further investigation as well The problem, at least for me, is that many of the function names are combinations of English & German, not just words (which I can handle, thanks to Google translate), but rather abbreviations -- so it's a matter of trial & error & and I tend to err on the side of caution so I don't cause a problem. What would be great if someone can provide a full meaning of these abbreviations-- in either English or German -- perhaps even worthy of a "sticky" post on this thread Hope a moderator picks this up FWIW (with due apologies to Buffalo Springfield)
Al
05-31-2020, 07:20 AM | #34 |
Rep 1,481
Hi,
Does anyone know what the prefix CB_ stands for or means? Seems like there are many functions with that Thanks
Al
05-31-2020, 03:47 PM | #35 |
Rep 1,481
Well, using Bimmercode, in Insyrument Cluster (DKOMBI) I coded active: HMI_MVIEW_ENABLE, CB_HUD_MVIEW_SPORT, CB_HUS_MVIEW_NAVI & CB_HUS_MVIEW_SLI.
I now have not only option of selecting STANDARD or MVIEW in HUD, but also can pick Speed Limit & Nav Info -- not sure what Sport does?
Al
VipinLJ1950.50 |
05-31-2020, 06:14 PM | #36 | |
1951
Rep 3,520
06-01-2020, 12:18 AM | #37 | ||
Rep 332
06-01-2020, 09:17 AM | #38 |
Rep 1,481
VipinLJ , tommytexter ,
OK, when I enable M view HUD, I now can edit what's in this -- both Nav & Speed Limit info have check boxes -- BUT none for Sport (which leads to believe there's more to this feature. Also, as you'll see in pictures below, Nav info doesn't show up in M view HUD -- again, more to it. Pictures are in garage hence the background; first ones should be iDrive showing HUD menu screens, then STANDARD HUD -- note M view HUD lacks Nav. Also, not in pictures, Driver Assist info doesn't show up in M view--yet More work ahead, but it's a start
Al
VipinLJ1950.50 |
06-01-2020, 09:19 AM | #39 | |
Rep 332
06-01-2020, 02:01 PM | #40 | ||
Rep 1,481
Al
06-01-2020, 08:32 PM | #41 | |||
Rep 332
06-02-2020, 05:47 AM | #42 |
Rep 1,481
@tommytexter ,
I have not seen any of the M car HUD Items yet -- probably because there are a myriad of functions with M or MVIEW in both HG_MGU & DKOMBI. Will have a lot of trial & error ahead
Al
07-07-2020, 05:04 PM | #43 |
1951
Rep 3,520
So I was snooping around the display settings to try and turn off the rev light thing in the HUD and it seems that option has disappeared for me. Under Display > HUD setting, it used to be in the edit option. As per the car's built in manual, it's supposed to have a third option there that lets you turn it on or off in the HUD. Now, I don't see that option there. I know it was present before because that's how I enabled the rev light in the HUD. I think coding M vehicle for the tyre pressure widget probably removed the option from idrive for me because I have an option for M HUD but it doesn't work.
Does anybody else have this issue? I still have the shift lights in the HUD. Just can't turn it off to see if the shift lights in the live cockpit pop up instead.
BCD-53551.50 |
