08-24-2023, 03:59 PM | #46 | |
Rep 436
No point in going over the 128Gb as the camera does not 'recognise' the extra (at least, not yet) A 128Gb will give circa 12 -14 hrs for front and rear before overwriting happens. While BMW state you must go with their card for warranty (I think £48 for the 128 which is bonkers ) I honestly cannot see them being better than SanDisk. If you go for a non BMW card, just be sure to get from a reputable source, so many knockoffs out there. |
08-24-2023, 04:56 PM | #47 | |
Rep 2,212
The Sandisk ones are about thirteen quid or so on Amazon from 'the Sandisk store' so I'm sure they should be OK. They come with an 'SD card adaptor' which I assume means I can use them in the Apple SD card reader I have for my camera SD card so I could view the footage on my iMac (the iMac version I have doesn't have an SD card reader slot). Would that be right? (I'm not too well up on all this techie stuff!) |
08-24-2023, 05:39 PM | #48 |
Rep 1,234
On Amazon just make sure you aren’t buying from a dodgy marketplace seller (even on products linked to from the sandisk store). There are soooooo many fakes around.
bmnut842.50 The_Tok'Ra124.00 |
08-25-2023, 03:21 AM | #49 |
Rep 539
WRT to recordings, I contacted the ACE 3.0 Support Team - here's what they said.
Hello, The original BMW 32GB SD card can save 78 minutes of driving recordings – when both the front camera and rear camera is on. Incident recordings are saved 26 minutes, and manual recordings are 8 minutes, and the parking recordings – when the shock is detected while parking mode – are 46 minutes. 64GB SD card can save 157 minutes of driving recordings when both the front camera and rear camera is on. 53 minutes of Incident recordings are saved, and manual recordings are 17 minutes, and the parking recordings – when the shock is detected while parking mode – are 92 minutes. 128GB SD card can save 316 minutes of driving recordings. Incident recordings are saved 107 minutes, and manual recordings are 126 minutes. Also, the parking recordings - when the shock is detected while parking mode - are 153 minutes. After the time allocated for each part, it will be overwritten from the beginning. Thank you and best regards, Your ACE 3.0 support team. |
08-25-2023, 03:50 AM | #50 | |
Rep 539
BTW - I'd recommend using the Thinkware Viewer on your Mac (see the link I gave in an earlier post in this thread). Last edited by sjb993; 08-25-2023 at 10:56 AM.. |
SonD325.00 |
08-25-2023, 08:34 AM | #51 | |
Rep 2,212
Might see what leading electrical stores price them at which should offer a bit more 'consumer protection' or for the sake of 'spoiling the ship for a ha'peth of tar' as my grandfather would have said, may just say 'sod it' and get the BMW one from the dealer and try and wring some discount out of them! |
08-25-2023, 08:35 AM | #52 | |
Rep 2,212
08-26-2023, 02:44 AM | #54 |
Rep 66
I get mine from Amazon no problems with them have used the same seller on numerous times, link below:
https://www.amazon.co.uk/gp/product/...e?ie=UTF8&th=1 |
08-26-2023, 03:20 AM | #55 |
Rep 116
OK, first impressions are it is very, very good, looks neat and tidy, not too much "in your face" and the screen stays off... in fact if you tap the screen when driving it gives a message saying it cant be used when driving, which is good
Video quality is also excellent for the front camera, used in both daylight and night and it is clear.. the rear camera needed to be brightened as it looked a little dark and at night it does show the glare but it is a lower resolution camera.. The APP is good lets you do all the settings, view the footage and download easy.. APP is a bit slow compared to the unit but that was mentioned in the video I posted.. but not too bad.. This is it on the screen from the drivers seat when I picked it up...
2020 BMW 320d M-Sport xDrive Touring
paulockenden585.50 bmnut842.50 |
08-26-2023, 05:20 AM | #56 | |
Rep 1,234
08-26-2023, 07:30 AM | #57 |
Rep 66
Hi It was Zara Services who I have used in the past. I see its showing Alivo on the link try this one it has opened each time on Zara services
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 |
08-28-2023, 07:27 AM | #58 | |
Rep 2,212
Good to hear that it lives up to the expectations and pleased you are so happy with it. Could you possibly post a photo of what it looks like from sitting in the front passenger seat? I'm undecided whether to go for the 3.0 or the Pro, my wife on the other hand is more inclined to want the 3.0. I think she's conscious of how it will look from the front passenger's viewpoint! |
08-28-2023, 07:41 AM | #59 | |
Rep 3
I have had both fitted to my M135i. Dealer made a mistake & fitted non Pro version when I’d asked for the pro.
Only difference is that the pro has a screen. Cameras & mount are exactly the same. The dealer corrected their mistake by swapping the head/front camera unit. I find the whole system generally ok, but the process of connecting my phone to the camera via the app a faff. You have to disconnect the connection to the car (apple play, Bluetooth & Wi-Fi) then once finished viewing/downloading ant footage you have to reconnect. Quote:
08-28-2023, 11:45 AM | #60 | |
Rep 539
08-29-2023, 01:57 AM | #61 | |
Rep 116
This is the passenger view, looks a lot larger than it actually is in the picture..
bmnut842.50 |
08-29-2023, 05:16 AM | #62 | |
Rep 2,212
My local dealer is in the process of fitting them to all their demonstrator fleet but have yet to fit the Pro version so I was curious as to what the difference would be looking at them from inside the car. Once I get my car repaired, which is still looking like another couple of weeks yet, been off the road now for three weeks now already I'll be arranging to have one fitted to my car then will get the wife's car in to have a one fitted to her car. Thanks again, much appreciated! |
xDrive320D50.50 |
08-29-2023, 05:35 AM | #63 | |
Rep 116
bmnut842.50 |
09-16-2023, 03:43 PM | #64 | |
Rep 22
Id by a cheaper and probably better unit from elsewhere. |
09-17-2023, 04:02 PM | #65 |
Rep 2,212
Can I ask what functions of the camera did you find were really poor?
09-19-2023, 04:06 AM | #66 |
Rep 22
Perhaps i was not informed enough before buying.......
Transferring data, quickest method is removing the sd card and transfering by pc/laptop. In order to ensure i dont lose data whilst doing so, i bought two 128gb cards and just use them. This also worries me about taking the card out regularly and damaging the unit. There is no warning when you have reached your cards storage limit, the device just overwrites the previous stored data. You can connect to the device remotely, i say remotely, you have to be in the car to do this, it also makes the "live view" on the app pointless. This is also how you would download the saved data to your phone..... you can look for incidents easily, so if you want to just save these, then all the data to your phone then you can. Parking sensor can be hit and miss, sometimes activates when expected, sometimes it doesnt. Bmw installed mine per guidelines, but the front cam is in front of the passenger , so if they are of average height it is in direct sight of them. Some positives....... Picture quality is good Able to manually change sensitivity of recording Reply from support team are prompt- i think based in china - ive sent a few questions to them in the past, if i can find them i will forward to you. |
