11-16-2023, 09:50 PM | #265 |
Rep 38
Drives: 2023 M4 Competition xDrive
For G22/G82, I tried coding with bimmercode instead and you will not need
LIC_EDGE_CUTTER_RULE_ASSIGNMENT G20_US_code -> G20_ECE_code |
11-30-2023, 09:59 PM | #266 |
Rep 198
i coded everything with Bimmercode for my G82 using the CSL Style Tail Lights with Sequential Turn signals and also the CSL Replica Lights with the Euro Turn both working perfectly - But here's is what I found a lot of the information or coding is somewhat right and wrong - But I figured it out
12-08-2023, 04:40 PM | #267 | |
Rep 85
12-08-2023, 09:13 PM | #269 |
Rep 85
12-08-2023, 10:52 PM | #270 |
Rep 2,047
I don't use bummerutility but you need to edit the fa, look for the type code section change to ECE LL then save the fa. Use the fa to vo code the modules.
Its better to look at the differences between stock fa and ECE one and transfer the required manually since vo coding will affect others parameters not only the rear lights. I can guide you remotely if interested. |
12-17-2023, 09:20 PM | #271 |
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
Quick Question. I have G22 Canadian version. I have tried to code following the instructions from prior posts, but I got hyper flashing front signal with nothing in the rear. Will not coding LIC_EDGE_CUTTER_RULE_ASSIGNMENT solve this problem? Thanks.
12-18-2023, 11:25 PM | #272 |
Rep 38
Yea, I would definitely try not coding the edge cutter. I only did the coding changes after I installed lights that have euro turn signals so thats something to keep in mind.
12-18-2023, 11:33 PM | #273 |
Rep 38
https://youtu.be/Od_lQ-rUMVc
shameless plug - link to a video a made demonstrating the sequential in action and my overall thoughts on the whole process. |
12-30-2023, 09:00 PM | #274 | |
Rep 85
12-30-2023, 11:19 PM | #276 |
Rep 85
12-31-2023, 01:20 AM | #277 |
Rep 2,047
It should work but it will change some parameters which might affect other functionalities of the vehicle. The vehicle would still work but mostly light related functions will change. You can try vo coding and see if you can get away with it.
01-03-2024, 10:38 AM | #278 | |
Rep 132
Calvindubois42.00 |
01-08-2024, 11:31 AM | #279 |
Rep 112
Drives: 2023 BMW 330e LCI M - Sport
01-28-2024, 04:15 PM | #280 | |
Rep 9
Hey I followed this, the cornering lights are working but I'm not getting any tunneling nor are the lights moving when I turn the wheel. Also I couldn't find KAFAS04 on BimmerUtility so I was just wondering where that was? Is it under BDC?
The only reason I see this not working is because I removed S5AP under the VO code with BimmerUtility, I don't know if that affects it. Quote:
02-05-2024, 11:16 AM | #281 | |
Rep 84
E92 335i/G20 330e
02-05-2024, 02:49 PM | #282 | |
Rep 464
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
EvanL36.00 |
02-06-2024, 07:43 PM | #283 |
Rep 84
Good call; that fixed the issue. Thanks.
E92 335i/G20 330e
02-09-2024, 12:06 PM | #284 | |
Rep 6
CLI_CLW_PSD_ASSEMBLED > aktiv_CLW, but I don't have that. Maybe you know a solution to the problem? |
02-09-2024, 07:39 PM | #285 | |
Rep 464
If you are trying to code EU tail lights, see post#282. This method is much easier and does not require any additional FDL coding (if using Esys) compared to the method I originally used in the post you referenced.
02-12-2024, 09:26 AM | #286 |
Rep 5
Is this just coding ? thanks
LE: from my research the EU/UK rear lights have the same PN, so both small rear lights have the fog lights ? Last edited by almar; 02-12-2024 at 02:44 PM.. |
