12-27-2023, 03:53 PM | #397 |
![]() 68
Rep 204
Does anyone know if and how to activate the auto seat heating function. I’ve done the steering wheel but miss the auto seat heating from when I had my G12.
EDIT: Found it. For anyone else wondering it’s done via expert mode in Headunit: AKT_AUTO_SITZE_FRONT, value: heizung AKT_AUTO_LENKRADHEIZUNG, value: aktiv BDC: LHZ_CCM_IKF – aktive IKF_ENABLE – IKF_ALLE_SITZE Works a treat. Last edited by RaptorStrike; 12-27-2023 at 05:30 PM.. |
lebaaron439.50 |
12-30-2023, 06:13 AM | #398 |
![]() 12
Rep 39
FSC codes for the G05 KAFAS4
12-30-2023, 11:44 AM | #399 |
Rep 2,046
01-06-2024, 02:29 PM | #400 | |
![]() 2
Rep 30
Unfortunately I believe it doesn't work this way. I have a 320e sport from 2021. We have 163hp plus 111 on the electric motor. It should have 274hp. I don't know where the rest of the power is.. 330e have 184hp plus 111. But I dont know where it gets the rest of the power. Xtraboost I believe its more a reprograming that we don't have. If you somehow know how to do it without having to reprogram the ecu, hit me up! |
01-08-2024, 08:50 PM | #401 |
![]() 1096
Rep 1,788
I have a 2022 340i and my Tachometer cuts off at 6,000 RPMS after changing the gauge settings - previously I was using the M Instrument Cluster and I had messed with some settings to get the yellow pre-redline shift leds in place.
Anyone know where the setting is to get my RPM gauge to go to 7k or 8k since it clearly revs over 5500 where the red hash marks start? For that matter I think it revs over 6000 where the entire gauge ends if you're really on it too. Pics tomorrow. I also figured out how to get 4 distinct colors in the g20 2021 platform LEDs (its nothing ground breaking) but I haven't yet seen a post describing how the "White" main light HEX code actually somehow seperates from the LED strip and only into the door lights. . . I feel like some nerdy lighting folks will like this.
![]() m340ix Mineral Grey/Tacora Red |
01-10-2024, 02:24 PM | #402 |
![]() 1096
Rep 1,788
Updated with photo - need to know how to change the RPM x 1000 to like 7,000 or more, as my car clearly revs higher than 6000 (m340i).
01-10-2024, 06:12 PM | #403 |
![]() 1096
Rep 1,788
Okay FYI its DZM Variante, and I decided to go with B58 "ohnte" which cuts off at 7,000 RPMS even (hashed lines go 6,000 to 6,500). B58 standard appears to have the endpoint at 7,400, with the hashed lines beginning at 6500 and ending at 7000 or so.
02-04-2024, 08:52 PM | #405 |
![]() 90
Rep 165
I have tried everything but cannot get LIC_FEATURE_2 to work on the G20... Does anyone know how to make the SML act as DRL/Parking Light???
I want the side mirrors to be constantly illuminated while driving (not only blinking when blinker is on). I tried similar things to: https://www.bimmerfest.com/threads/b...ys-on.1428699/ https://x3.xbimmers.com/forums/showthread.php?t=2054475 https://cartechnology.co.uk/showthread.php?tid=71437 But something else is different and it's not changing anything... I tried changing the LIC_NIVEAU_OVERRIDE_INDEX and LIC_NIVEAU_OVERRIDE_DATA_0 from US spec to ECE spec and still didn't work.. Anyone know how to do it on G20?? |
02-10-2024, 06:56 AM | #408 |
Rep 1
I was wondering that all posts mention bimmerutility, but then all the codes are listed in the posts.
I downloaded Esys 3.39.1, PSdZ files and got myself the OBD2 enet cable. Can I not just do these edits on expert mode in Esys? Do I need bimmerutiliy? Also is there any resources to read up on adding FSC files mentioned in the previous posts? I would like to activate traffic sign recognition in my car too. Thank you very much in advance, this whole thread is filled with gems. |
03-09-2024, 01:51 PM | #410 |
Rep 8
Hello friends. I have bmw f34 lci 2018 with digital cluster and speedometer to 260km/h. Is this posible to change to 330km/h with bimmercode or not? Please help me I realy want to change it because its much better with that.
03-10-2024, 06:23 PM | #411 |
Rep 1
Has anyone been able to code side mirror turn signal to DRL’s on the g20 on g30 It’s Lic_Features2 in expert mode anyone know what the coding is for the new g20 body style
Reference photo is a 540i(g30) |
03-31-2024, 06:15 PM | #412 |
![]() ![]() ![]() ![]() ![]() 204
Rep 677
Hey Guys,
Looking for a little advice. I bought an ENET cable from Amazon (UK) and it has a 1.5K Ohm resistor between pins 8 and 16. I've read that it should be a 510 Ohm resistor to work properly, but that was for a F series car. I have a G series car, a G21 M340i XDrive. Will the cable still work for me, or do I ned to change the resistor to a 510 Ohm resistor (1/4 watt) Thanks! |
03-31-2024, 11:40 PM | #413 |
Rep 2
04-03-2024, 09:23 PM | #414 | |
![]() ![]() 15
Rep 75
Drives: 2020 bmw 330i
04-07-2024, 07:38 PM | #416 | |
![]() ![]() 15
Rep 75
04-08-2024, 01:15 PM | #417 |
Rep 21
Hi guys , is it easy to code sport plus mode to 2019 G20 model without it ?
Also is it possible to code fog light to go on while turning into corner and how to code brake force to blink 5 times while hard braking . With bimmer code Last edited by Adict; 04-08-2024 at 01:22 PM.. |
05-14-2024, 11:26 AM | #418 |
![]() 9
Rep 57
I coded:
DKOMBI4, Anzeige_Configuration> 10Seglen_In_Comfort_Modus, Change to active HG_MGU, Global_Conf_Sailing, Change to active. Eff_Dyn_Sailing, Change to active. Sailing_Counter, Change to active because I want to be able to turn off the sailing mode in Comfort and Eco mode. There is an option in the general settings "Idle speed", which is enabled by default every time you turn the car off/on. Is it possible to code a memory for it? Like the start/stop memory so it remembers the setting to off? |
