10-09-2022, 09:24 AM | #23 |
Rep 826
Drives: 2021 BMW X3 M
Near the fuel level part of the gauge.
2014 BMW 335i M-Sport - SOLD
10-09-2022, 12:51 PM | #24 |
Rep 55
Drives: M5 Competition 2019
10-16-2022, 09:10 PM | #25 |
n00b
47
Rep 14
Any more info for a n00b?
I started noticing the dimming gauge cluster display recently. At first I thought it was just me, but then I watched it get really bright and then go really dim again. Is there any more info on which adapter people use? There's a ton for the G80 here:https://bimmercode.app/adapters/?series=g
I'll pick one of these up soon because the dim display isn't as bothersome as the oscillating dim, bright, dim, bright. It's like I'm hallucinating. |
10-26-2022, 10:22 PM | #27 |
n00b
47
Rep 14
Got my enet cable and usb3 adapter today. Works perfectly ok my G80! I can use the thumb wheel to adjust brightness to my liking finally. I'll check it out tomorrow in the sunlight to confirm all is good. Thank you!
View post on imgur.com Last edited by CuzDawg3; 10-27-2022 at 11:29 AM.. |
10-27-2022, 08:19 PM | #28 |
n00b
47
Rep 14
Oh, I should also note that the panel is basically full bright during the day without nighttime headlights on. I drove around today and got confused that I couldn't adjust the brightness with the adjuster wheel until it got dark enough and the headlights came on. Then back to all is good, and works just like the vid I posted.
11-02-2022, 05:22 PM | #29 | ||||
Rep 43
Drives: G20
11-03-2022, 09:47 AM | #30 |
n00b
47
Rep 14
That's what was happening to me. I have 30% tint and even during the bright days it was still going super dim. Total cost out of pocket for me was $45ish for bimmercode and $36 for these cables:
12-07-2022, 11:35 AM | #31 |
Rep 53
So to confirm, this coding fix makes the instrument panel full brightness always during the day and then at night you can adjust the brightness manually with the thumbwheel? does the thumbwheel still control both the instrument panel, control panel and the button lighting?
12-11-2022, 02:32 PM | #32 | |
n00b
47
Rep 14
01-09-2023, 01:33 AM | #33 | |
Rep 1,529
I did all 3 code lines, but I was not able to understand why do we have to code this one too (DIM_TAG_NACHT_LICHT_EIN_ENABLE) I tried it with active and not active, and did not notice a difference. Any thoughts? |
01-17-2023, 03:29 PM | #35 | |
BMW Enthusiast
175
Rep 221
https://g80.bimmerpost.com/forums/fo...play.php?f=892 |
01-17-2023, 06:24 PM | #36 |
Rep 32
mr clone1008 much respect mine dimmed so much that i was about to take tiny off and it was 600 for the top of the line expel , how did you figure it out . i feel like there is so much more stuff we could code the expert mode has tons of menus then sub menus , but it worked for me my 21 m340i , i have 15% all the way around minus windshield. thanks again what else can you figure out lol,
01-18-2023, 02:26 AM | #37 | |
Rep 16
01-18-2023, 05:25 AM | #38 |
BMW Enthusiast
175
Rep 221
04-02-2023, 12:56 PM | #39 | |
Rep 1
04-06-2023, 10:17 AM | #40 |
2020 Mineral White 30d MSport
527
Rep 2,146
Drives: 2020 Mineral White 30d MSport
I was wondering if these fix can improve the quality of image of the rear view cameras at low light situations at night. There is a light sensor located on the bottom left corner of the cluster, I tested the sensor pointing my iPhone's LED light to it, after a couple of seconds, you see that the IDRIVE gets MUCH brighter improving also the quality of the rear camera at night. I do have very dark tinted windows, which I believe is not helping me either.
Any thoughts and tips will be rewarded with a big THANKS! Check this link: https://g05.bimmerpost.com/forums/sh....php?t=1778940
....Life is too short to drive boring cars
04-06-2023, 01:35 PM | #41 |
Rep 1,565
Getting windows tinted tomorrow, 15% all around and front windshield. Coded this and seems to work. I know in parking garages it dims a lot, assume same situation with Tints....thanks OP.
Update this def works. In essence it makes during the day full bright and still gives control with the wheel next to the lights at night to adjust for night. Basically turns day auto brightness feature off.
2020 M340i: Dravit Grey Mettalic. Loaded.
07-24-2023, 10:57 PM | #42 | |
Rep 34
11-17-2023, 05:00 PM | #44 |
Rep 65
Drives: 2021 Mineral White M440i
Did this for my 2021 M440i, worked but for some reason my auto high beam now doesn't work at night. I am going to revert back and see if it is having an issue with the auto high beams.
