05-07-2024, 05:30 PM | #23 |
Rep 390
Bumpinjeep5667.50 |
05-07-2024, 10:30 PM | #25 |
Rep 1,153
05-07-2024, 10:49 PM | #26 |
Rep 923
AZG871030.00 two_three_two636.50 |
05-08-2024, 08:17 AM | #28 |
Rep 179
Here is my car with a hair under half a tank.
19x9.5/19x10.5 apex forged wheels with 285/35/19 re71rs Added a skid plate and front grill protectors, everything else including a small cooler (maybe 10lbs) is in the car. 23 M2, carbon pac, auto |
Geighty71662.50 |
05-08-2024, 09:38 AM | #30 | |
Rep 923
zero213266.50 |
05-08-2024, 09:47 AM | #31 |
Rep 179
starlord722.00 playswcars3689.00 |
05-08-2024, 10:08 AM | #32 |
Rep 1,821
AA single midpipe saves about 27 pounds, for those that care about numbers adding up
(It also sounds better). I'm shooting for very close to 3,600lbs with my build.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
LAGWAGN289.00 |
05-08-2024, 10:09 AM | #33 |
Rep 923
05-08-2024, 10:44 AM | #35 |
Rep 507
Sooooo the OPs weight is pretty close to what BMW lists as the curb weight for the manual w/default config (sunroof and comfort seats) ~3747lbs. BMW is being accurate here.
I made a spreadsheet to see how easy/difficult it is to reduce weight in this car. I believe that you can get a manual under 3600lbs (at a 1/4th tank) without too much effort or expense assuming the car is spec'd appropriately. - BMW carbon buckets = -22 lbs (11 lbs per seat) - Carbon roof = -48 lbs - lighter wheels (826M) with the same tires = -27.2 lbs - Lithium-Ion battery = -39 lbs - Midpipe = -15 lbs That puts us at 151.2 lbs of weight reduction. Sooo using the OPs weight of 3729, minus the weight of the mods above, puts us at 3578 lbs. Last edited by Celestion; 05-08-2024 at 10:54 AM.. |
05-08-2024, 10:50 AM | #36 | |
Rep 923
-Replaced exhaust to the OEM downs (Milltek catback) -20’ BBS LM 2 piece forged wheels (305 rear) -Mishimoto skid plate -Lightweight Performance Poly blend lip Maybe I need to do the battery? |
05-08-2024, 10:56 AM | #37 | |
Rep 507
05-08-2024, 10:58 AM | #38 |
Rep 923
05-08-2024, 11:08 AM | #39 |
Rep 1,821
I'd personally get a lithium battery from an M3/M4 to replace the M2's AGM battery. It still saves about 30 pounds if I remember the figure correctly, without risking issues with your electrical system or your warranty. Anti-Gravity batteries are great, but I'd only put them on a track car.
05-08-2024, 11:21 AM | #40 | |
Rep 923
05-08-2024, 11:32 AM | #41 | |
Rep 1,821
https://www.getbmwparts.com/oem-part...10-61217908325
Geighty71662.50 |
05-08-2024, 12:07 PM | #42 |
this is the way
18467
Rep 8,589
Aside from finding ways to shed weight the next best thing you can do to improve handling is lower the car which lowers its entire center of gravity.
So used to lowered cars that when I drive one on stock suspension it feels like an SUV. |
Kevin_The_Clean13429.00 |
05-08-2024, 12:16 PM | #43 | |
Rep 507
05-08-2024, 12:23 PM | #44 |
this is the way
18467
Rep 8,589
You need to register the battery and if the new battery has different Ah rating, you'll need to code that in as well. BimmerCode only has the ability to change the Ah rating while only BimmerLink can register the battery. I believe the Carly app can do both but that's a subscription whereas with BimmerCode/Link you pay for the apps once.
