09-16-2019, 09:27 PM | #23 |
BMW Client Advisor
3467
Rep 2,504
Mine doesn't show the head unit on my 2020 m340i
09-17-2019, 06:42 AM | #24 | |
Rep 67
Drives: 2019 330xi
Is Bimmercode working with iDrive version 07/2019.xx Do you know off hand if the ECUs you listed include any of these options? Auto start stop memory Turn signal in HUD Key FOB trunk open and close Legal disclaimer off Seatbelt Tug off |
09-17-2019, 01:42 PM | #26 | |
Rep 724
I was attempting to do the Boot/Trunk open close for him, but unfortunately it wasn't there, pretty disappointing actually compared to the things i can do on my F36 |
09-18-2019, 09:58 PM | #27 | |
Rep 8,364
G30 Pre-LCI is not same as G20. |
09-19-2019, 12:53 PM | #28 |
Rep 724
09-19-2019, 05:27 PM | #29 | ||
Member
17
Rep 19
Drives: Arctic White 650i, 2020 M340i
Option included : Auto start stop memory Key fob trunk open Legal disclaimer off. |
09-20-2019, 07:00 AM | #31 | |
Rep 67
Drives: 2019 330xi
Could you PM me with the correct way to contact talking master? Thanks |
09-20-2019, 11:50 PM | #32 | |
Rep 8,364
If he is busy or getting many requests, then response can be delayed. |
09-21-2019, 09:46 AM | #33 | |
Rep 67
Drives: 2019 330xi
************************* thanks oops, looks like these messages don't allow email addresses |
09-21-2019, 12:36 PM | #34 |
Rep 8,364
09-30-2019, 06:01 PM | #36 |
Rep 15
I paid for the full version and was able to code a lot of things on my 2018 530i but now own a 2020 M340i but quite a lot of things are either not able to read ECU or have data to code. E-mailed him about updates to ECUs for 2020 models since the demo mode has a whole lot of items listed which appear to be able to code on a 330i but not M340i. They responded by saying to look for updates in the future and nothing else.
10-15-2019, 01:11 PM | #37 |
Rep 15
Supported adapters
Recently visited the bimmercode website and saw this note under the supported adapters page:
'The latest Vgate devices do not function properly anymore, so these adapters are not recommended any longer. If you buy one of these devices it may or may not work, or even quit working after some time. If you have an older working device, you can continue using it of course.' Okay, so I have one of these devices and thought that this might be the reason why I am unable to get all of the coding options. So, I went ahead and ordered the OBDLink MX+ Bluetooth and thought maybe this will work. As soon as I got the obdlink I plugged it into the car and boothed up bimmercode on my ipad. Sure enough I ended up getting the same coding options as I did with my Vgate adapter. What I wanna know is why put a note like above and still not work with the supported adapters? These are the supposed coding options that they have listed: Supported coding options BMW 3 Series G20, G21 from 2019 Acoustical confirmation Alarm system Audio Auto Start Stop function Daytime running lights Display options iDrive system PDC Rear view camera Seatbelt reminder Video Warnings The one's in bold are the only ones I was able to do anything with on my 2020 M340i. My previous 2018 530i was able to code all of the listed items with my Vgate but don't see any updates with the G20s even though they are supported. |
10-16-2019, 07:47 AM | #38 | |
Rep 1,037
10-16-2019, 10:19 AM | #39 |
Rep 254
Drives: 2020 BMW M340i xDrive
Are you guys putting the car into diag mode before you connect to Bimmercode?
While the car is turned off, don't hold the brake and press the start button 3 times quickly - and within 10 seconds you should see on the dash that the car is in diagnostics mode. That should give you access to more ECUs. |
siegester346.00 |
10-16-2019, 01:54 PM | #40 |
Rep 821
10-28-2019, 07:07 PM | #41 | |
Rep 230
However as Jbrock said, if you send a support request to the authors they'll send you a link to download a beta version via TestFlight that will give you access to additional ECUs, including 'head unit'. Tonight I was able to successfully code several more options using the beta than are available in the app store version. Last edited by 2020g20; 10-28-2019 at 07:55 PM.. |
Liquid_Ice167.00 |
10-29-2019, 09:14 AM | #42 |
Rep 230
Confirmed working on my G20 with beta version of Bimmercode:
ASD disabled ASS remember last setting enabled Startup disclaimer disabled Volume Up/Down Popup disabled Instrument Cluster Style changed to blue Alpina Most pleased about removing ASD. Was really grating on my nerves in Sports mode. |
10-29-2019, 08:14 PM | #43 |
BMW Client Advisor
3467
Rep 2,504
Used the Beta today and added the M5 display /HUD as well as video in motion. Only down side is that Sport display went away in the HUD and the map display seems smaller.
10-29-2019, 11:25 PM | #44 |
Rep 425
