Technical Topics Suspension / Chassis / Brakes M340i knock in front suspension / steering rack on expansion joints 45mph or under
      07-17-2022, 01:45 PM   #23
teknic90
teknic90's Avatar
Drives: G20 M340i
2020 G20 M340i  [0.00]
2016 BMW 340i  [0.00]
Originally Posted by transcendid View Post
Originally Posted by teknic90 View Post
Wow. Ok, in the same boat. For sure a metal on metal clunk just like everyone else is reporting. Forman was finally was able to replicate when I told him to leave it in the sun for a few hours as it's only apparent when it's hot out and the car has been sitting.
Turns out the previous owner had Dinan monoball joints installed on the tension struts. Of corse the Forman said this was the problem but couldn't inspect the monoballs as they were not qualified.
Took it to a Dinan authorized dealer and had them take a look as it would be covered under the Dinan warranty. They said the monoball checked out just fine and I had to pay $185 for the inspection. :
So back to square one. This is not a normal sound and it's concerning.
My car is also a 2020 M340i with adaptive suspension.
Does your noise also eventually stop after driving a little while?
Yes! It does. For the most part after ~10 min of driving.
      07-17-2022, 04:10 PM   #24
transcendid
transcendid's Avatar
51
Drives: 2020 m340i RWD
2020 BMW M340i  [0.00]
Same thing here. And it's not consistent. Doesn't happen every day or every drive. So frustrating!
      07-20-2022, 08:33 AM   #25
bimmerboy71195
bimmerboy71195's Avatar
79
Drives: alpine white 340xi
I have the same knock/clunking feeling and noise coming from my front wheels (feels like left wheel) I notice it as low speeds while going over slight bumps. Did a visual inspection of steering components everything checked out. Has anybody gotten to the bottom of this?
      08-09-2022, 08:00 PM   #26
22Black
Drives: 22’ 330i
Hey I have the same thing on my 22' 330i..what year is your vehicle?
Kenz8.00
      08-09-2022, 08:22 PM   #27
transcendid
51
It seems that it's impacting g20s of all years. Mine is a 2020 and I have this issue.
      08-09-2022, 09:33 PM   #28
22Black
Drives: 22’ 330i
Did you ever bring it in for service? If so what was the outcome?
      08-09-2022, 09:39 PM   #29
transcendid
51
Dealer could not replicate. They put my vin in for SIB 31 01 20 and replaced the lower left control arm. This did not fix the issue. Otherwise they have been unable to replicate it - and to be fair - it is not super consistent for me. For now I'm living with it. If it becomes more consistent I will try again. I'm hoping that as enough people have the issue, bmw will issue a TSB specifically for this problem.
      08-09-2022, 09:49 PM   #30
22Black
Drives: 22’ 330i
I agree with you. Its super sporadic for me as well..maybe ill notice it 3 times a week. So yours is happening at low speed as well? For example I noticed it today pulling out of my street when the car went over a small imperfection in the pavement. Seems like conditions need to be just right to replicate..maybe a slight turn of the wheel, slow and over an imperfection
      08-09-2022, 10:02 PM   #31
transcendid
51
Mine is almost exclusively low speed. Bumps that cause a small upward movement in the suspension.
I just checked my paperwork from the previous repair and they list replacing this part (https://www.onlinebmwshop.com/oem-pa...rm-31106888855). Problem is- this part is listed as the left REAR lower control arm. Going to follow up now to see if they keyed in the wrong part number in the paperwork or if they really repaired the rear of my car when they were supposed to do the front ….
      08-13-2022, 11:49 AM   #32
Dompax440i
Drives: BMW G26 M440i
I have the same problem on my G26. The clunk noise can be heard during the warm days, on low speed, driving over minor road imperfections and it usually stops after 10 minutes of driving..
Kenz8.00
      08-13-2022, 12:25 PM   #33
transcendid
51
Drove 150 miles or so last night. Temp around 64F. Highway fine, but local roads 10-40mph the knocking/clunking was really prominent and noticeable. Did anyone with the issue have this TSB fix done?
https://static.nhtsa.gov/odi/tsbs/20...81218-9999.pdf
teknic90115.00
      08-15-2022, 09:42 PM   #34
teknic90
teknic90's Avatar
Drives: G20 M340i
I don't think anyone has mentioned the wishbone. I'm having my tension struts swapped at the end of this week and will try again to get this noise to go away. If that doesn't work then I'm going to mention this to my SA. Thanks for the contribution!
      08-15-2022, 09:55 PM   #35
transcendid
51
It looks like this TSB says wishbone or tension struts. Hope this fixes it for you- please report back!
      08-22-2022, 02:46 PM   #36
teknic90
teknic90's Avatar
Drives: G20 M340i
Tension struts replaced and wishbone inspected but no visual signs of failure.
Got quite a bit cooler here in TX so of course the noise went away since it is normally present when it's hot. Will wait till it warms up in a few days for a diagnosis.
For what it's worth, I've found that leaving it in the sun on a hot day almost always guarantees replication of the sound, at least for the first ~5 min of driving. Hope that helps anyone else playing the " technician can't replicate" game.
      08-22-2022, 03:19 PM   #37
peelerec
peelerec's Avatar
1454
2022 BMW M340i  [9.92]
MY 22 m340i here. I purchased the car in December of 21, and first noticed the clunk while on stock suspension after 2 months. I then had Dinan springs installed and notice the clunk here and there, randomly but only during slow driving (5-10mph) sometimes while simply turning the steering wheel pulling out of my driveway, or going over a small speed bump. Does not occur daily. Random.
Due to the current supply chain issues and dealership not having loaner cars readily available, I will most likely continue to live with it as it does not occur on a regular basis. Unless of course this develops into s TSB that actually fixes the issue.
      08-22-2022, 08:05 PM   #38
teknic90
teknic90's Avatar
Drives: G20 M340i
Yeah, that's kind of the direction I might go. Been waiting to lower the car on H&R springs until I got this fixed but there doesn't seem to be a fix yet.
      08-22-2022, 11:24 PM   #39
transcendid
51
From what I've been reading, the only thread with seemingly one solution is this one :
https://g20.bimmerpost.com/forums/sh....php?t=1856199
The video on this thread has the same exact noise I have.
You'll see one person talk about a tie rod ends replacement fixing his issue.
As for me, I drove with my dealers foreman last week and it didn't happen enough for him to "recommend any repairs at this time." He inspected the car on the lift, and didn't see anything wrong. But it's interesting that there was a tie rod recall on this model… maybe we have non-recalled but still somehow faulty tie rods..
And I tried contacting BMWNA by email and got this unhelpful reply:
BMW Customer Relations is unable to provide repair instructions as we rely on the technical expertise of the service teams at our authorized BMW centers to maintain, diagnose, and repair vehicles correctly, therefore we suggest to continue working with the service team at your authorized BMW center. I would suggest to speak directly to the Service Manager, as they are in the best position to discuss your concerns further.
      03-11-2023, 09:38 AM   #40
teknic90
teknic90's Avatar
Drives: G20 M340i
PSA:
This could be the fix:
https://www.bimmerpost.com/forums/sh....php?t=1999946
      03-11-2023, 08:17 PM   #41
transcendid
51
Got an email in to my dealer. Fingers crossed this is it!
      03-11-2023, 10:54 PM   #42
teknic90
teknic90's Avatar
Drives: G20 M340i
Lol. Literally had mine in for a sunroof problem and got this notice and notified them about the SIB. So hopefully they will just replace it. Problem is, I put H&Rs on after chasing this for so long and I bet they will just come back saying it’s the lowering springs…
      05-23-2023, 11:53 PM   #43
Kenz
Drives: 2023 M340
Hi all
I have just picked up my 2023 M340, only 1 week down the road. Have been experiencing mild knocking/rattling sound on my steering/front suspension while going on uneven road at slow speed. But does not seem to happen when intentionally going through bumps at slightly higher speed. Anyone having this issue and what’s the fix if you manage? Appreciate your advise 🙏🏻🙏🏻
      05-27-2023, 09:14 PM   #44
Kenz
Drives: 2023 M340
Originally Posted by SuprBmwG20 View Post
Im also having the same issue with my M340i with adaptive suspension. Took it to the dealership and replaced the front upper guide support. However this did not fix the issue. If anyone has any recommendations to what it can be that would be great. The noise is coming from the front passenger side and I can feel a very slight vibration on each thump/click noise.
Same issue here on my 2023 M340
