07-26-2020, 10:25 AM | #23 |
Rep 1,480
Drives: 2020 M340Xi (G20)
Joedeejay ,
Agree that Bimmercode is wicked fast with ENet cable!! Under Settings and clicking on the adapter, there is no ENet adapter listed -- that's why I tried MHD ENET (Black) -- which worked fine. As a beta user, I have Bimmercode 2.26.1-6177
Al
07-26-2020, 11:00 AM | #24 |
1949
Rep 3,520
Mine doesn't work. Stupid OnePlus. I tried both the enet adapter option as well as Mhd enet. No luck. I need a new phone
And RSnic. Mine has the option for enet.
07-26-2020, 11:55 AM | #25 |
Rep 1,480
VipinLJ ,
I'm loving my Samsung S8 even more -- not only is a car key, but also watch MLB.TV from phone to TV -- and Ethernet connection! BTW, under Settings, Connnecttions, More Connection Settings, Ethernet (at bottom of list) is greyed out, until I connect adapter
Al
07-26-2020, 12:28 PM | #26 | |
1949
Rep 3,520
RSnic658.50 |
07-26-2020, 01:48 PM | #27 |
Rep 120
Im running the Public version and on the exact same version. Odd that you don't have Enet cable though. Maybe uninstall and reinstalling the app might work if you are bothered about getting the option for it. Just keep a copy of your coding backups first.
RSnic658.50 |
07-29-2020, 05:13 PM | #28 |
1949
Rep 3,520
Just checked BC using my new S20. Holy hell. It’s unbelievably fast!!! I finished coding a couple of times in the time it would've taken the Bluetooth adapter to read the module. I so love it!
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige Last edited by VipinLJ; 07-30-2020 at 11:16 AM.. Reason: Typos |
07-30-2020, 01:23 AM | #29 | |
Rep 120
So far only Samsung and anything on Google OS seem to have ethernet options for static IP. Other phone makers don't seem to have ethernet options. Next phone is definitely a Samsung now, tablet will do for the mean time |
VipinLJ1949.00 |
09-14-2020, 09:53 AM | #31 |
Rep 1,480
Updates
Hi,
When coding with Bimmercode, I have switched to ENet cable with an Anker LAN to USB-C adapter; and, as many have already commented, it is lightning fast compared to either its use with a Bluetooth OBDII adapter or even E-Sys. Yesterday, after getting my car back from a service that included a software update, I set up to code the items I had previously coded and discovered something that I'd like to pass along. A few days ago, I got a Bimmercode App update from the Google Play store; of course, all that really is a shortcut that has the app update its coding info just as you connect to the car. Here's the rub. For some reason with ENet cable & adapter, it couldn't receive the update. After 3 attempts, I grabbed my Bluetooth OBDII adapter and plugged it into OBDII; then opened Bimmercode app and tapped on CONNECT. App updated perfectly. I then disconnected and reconnected the cable adapter and went about my coding without a hitch. BTW, the software update was for version 07/2020.45. Interestingly, it now includes as Climate rules/Habits the automatic steering wheel heating and river's seat heating that we had to code until now -- among several other good things, like Drive Recorder, Android Auto, tail lights included in DRL (please see Android Auto thread). Hope that helps!
Al
09-14-2020, 02:30 PM | #32 |
Rep 122
Well i best hold on to my Bluetooth OBDII adapter then... just in case... great to see that the update is including seat heating distribution
09-14-2020, 05:51 PM | #33 | |
1949
Rep 3,520
RSnic658.50 |
09-15-2020, 06:40 AM | #34 |
Rep 120
It won't update when you have the enet cable connected because that method turns Internet access off from the phone and hence can't download the update from Bimmercodes server. The OBD adapter will have worked because that's Bluetooth with mobile data still active/WiFi connection.
10-07-2020, 04:20 AM | #35 |
Rep 2
Unable to get BimmerCode working on an ENET Cable (Android)
Hi all
I am trying to get BimmerCode to work on my Android - it's a Levono TAB V7 on Android 9. I have an E-NET cable and I bought a USB to LAN adapter (this one) I tested if the USB-LAN adapter works properly on my tablet by plugging it into my router and turned on Airplane mode - sure enough it worked well - I was able to browse the internet with the Wi-Fi switched off My tablet has the option to assign static IP etc I followed the guide on the bimmercode website (LINK) But I'm unable to connect to the car (an F07) Here are some screenshots My tablet has a separate settings page for the ethernet connection There is an option to assign static IP I used this app to see more info about the wired ethernet connection to the phone Here are some screen shots when it's connected to my router: It picks up other devices on the network Here is the screen shot when connected to the car I tried another android tablet (a MiPad 4), but that did not have any option to set a static IP, though the LAN adapter worked on it. Am I doing something wrong or is it a limitation of my tablet? Thank you for your inputs Best Regards |
10-07-2020, 12:20 PM | #36 | |
1949
Rep 3,520
10-08-2020, 04:22 AM | #37 |
Rep 440
Just tried it with mine.
I have a Note 8, I configured the ethernet settings to what Bimmercode specified. At first try it did not connect and gave me an error. After a few tries, I decided turn off airplane mode and try to reconnect. That did the trick and the car connected immediately! As an aside, forget the wireless connectors. Coding with the cable took me a couple of seconds!!! Access to the modules is super quick and actual writing time are super quick.
E36 318ti
10-10-2020, 04:11 PM | #38 | |
Rep 24
I am experiencing the same ENET/LAN-USB C adapter connection issue using the latest Samsung phone and the newest BimmerCode version. Have you found a solution?
10-28-2020, 11:53 AM | #39 | |
Rep 2
I mailed BimmerCode support and shared all the details of the connection problem with them - their advice was to lock the car, let it rest for a while and then try again - I tried it - but to no avail. So, I gave up on the wired ENET connection and bought a modBMW Wi-Fi ENET adapter (it's basically a wireless E-NET cable) Got BimmerCode to connect with it on the first try - I highly recommend this adapter to anyone facing wired connection issues like I did - no more praying if the USB to ethernet works is compatible with your phone and changing IP settings etc As a bonus, you can use this adapter with ISTA-D (not tested it myself, but seems nice to have) Here is a link to the adapter if anyone is interested modBMW WIFI ENET adapter I recently bought my mom a new Samsung phone - I'll try the USB to ethernet connection with her phone one last time to see if it's a manufacturer specific issue Best Regards |
Merami fan376.00 |
10-28-2020, 11:56 AM | #40 | |
Rep 2,250
11-11-2020, 05:07 PM | #42 | |
Rep 8
11-11-2020, 07:27 PM | #43 | |
めらみぽっぷ fan
376
Rep 345
12-31-2020, 06:59 AM | #44 | |
Rep 147
Once i received it, i tried to connect it to my car using Xiaomi Mi6 rooted Phone. But i am getting Connection error. What can i do ? where is the problem ? i tried all the options in Bimmercode app ENET canle, mhd Black/orange... no use Is it because i didnt buy the Products from above 2 links ? i can see the both the lights in Ethernet socket blink when i connect the cable to my car. but even then i am getting connection error. Any help would be highly appreicated. |
