09-17-2020, 04:16 AM | #23 |
2JZ-GTE
3072
Rep 4,022
No manual transmission
stein_325i25178.00 scotty_g12.00 |
09-17-2020, 05:00 AM | #24 |
Rep 908
Love my M340i however a few gripes I have are;
1. Lack of steering feel 2. Huge gaps between the wheel and fenders 3. Steering wheel too thick 4. Tach display - WTF 5. Rear bumpers have a weird design line/crease on each of the sides which looks out of whack |
09-17-2020, 06:04 AM | #25 | |
Gone Fishin’
7318
Rep 12,125
I have a 2009 e90 328 beater and it kills just about every new car from all brands in steering feel. Why did every manufacturer go to EPS anyway? Cost? |
stein_325i25178.00 |
09-17-2020, 06:35 AM | #26 | ||
Rep 109
440xiGCMSport2283.00 |
09-17-2020, 10:28 AM | #28 |
Rep 1,205
Same but I'm 37. And the Auto Start Stop button you have to press everytime.
20 M340xi White Mocha
17 340i/M235i/E92 M3/135i All 6spd Chicago-Lake County-Milwaukee-Shorewood |
09-17-2020, 10:32 AM | #29 |
Rep 6,607
09-18-2020, 04:31 AM | #30 | |
Rep 109
09-18-2020, 08:24 AM | #31 | ||
Rep 372
09-18-2020, 09:30 AM | #32 |
Rep 6,607
09-18-2020, 09:36 AM | #33 |
Rep 372
It takes 5 minutes, a $30 app, and a $10 cable. The other options and customizations you can unlock are WELL worth it!
09-18-2020, 09:40 AM | #34 |
Rep 6,607
09-18-2020, 10:33 AM | #35 |
Rep 372
It is. You'll need an adapter (wired ones are faster and cheaper than wireless).
09-18-2020, 12:05 PM | #36 |
Rep 271
The thing that bugs me most about the car is a pretty minor change from G20 -> F30.
Anyone notice how you can't turn your headlights off while the car is moving? The headlight controls have been changed to a set of buttons, as opposed to a dial on the F30 which allows this. It's a small regression in the amount of control you have over the car's interface, but it still bugs me a bit. |
09-18-2020, 02:41 PM | #37 |
Rep 242
I miss a couple of very minor things from my F30:
1) I wish my new car had the elastic band on the wall of the trunk to hold bottles. I kept detailing spray there in case of bird bombs. I also really miss the "secret" compartment under the trunk liner. I kept all kinds of emergency items in there and it made not having a spare almost acceptable. 2) I would still like to be able to double push the ignition button to turn off the head unit (?) once I park the car and turn off the engine. 3) I wouldn't mind having the door unlock button in the center of the dash again. It's been two months and I still reach for that space to unlock all my doors. |
Ikester192125.00 |
09-18-2020, 03:40 PM | #38 | |
Rep 6,607
Not ejection, apparently |
09-18-2020, 05:56 PM | #39 |
Rep 1,481
Drives: 2020 M340Xi (G20)
@MGM340i,
The car encircled in green under iDrive is for the safety systems -- like lane keeper, blind spot, etc. That button allows you to turn all off or all on or adjust some
Al
09-18-2020, 08:13 PM | #40 |
Rep 6,607
09-20-2020, 05:27 PM | #41 | |
Rep 15
When I'm in manual it usually means I'm flogging it. I can't and shouldn't be looking down at the dash, especially if I'm cornering. In a real manual you know what gear you're in because of the last shift or you when you drop your hand on the stick in prep for the next shift. I always feel disoriented without equivalent feedback on the HUD when driving hard in manual. |
09-20-2020, 09:17 PM | #42 | |
Rep 6,607
09-21-2020, 03:10 AM | #43 |
Rep 440
Yes, theres an option to show the RPM as a bar and a slider. its pretty small though, i didnt find it useful honestly.
E36 318ti
09-21-2020, 03:15 AM | #44 |
Rep 440
I made a post about this somewhere else some time ago.
For the steering feel I found something very disturbing. I was on a longer drive and I had changed driver profiles. I did a quick lane change and I felt the most disgusting steering feel ever. I had never felt the steering so bad, I thought something had broken or failed. It felt like an elastic band being pulled when i did adjustments. I went into the settings for the "safety" features. Found the culprit. Turns out, if you have the lane departure warning with assist, it turns your steering into jelly. Horrible. I turned that that assistance off and used the reduced mode for the vibration/intervention. MUCH better. Seems like the EPS system changes calibration when all of that is active. So weird.
E36 318ti
