Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Add more bass to H/K system?
      01-06-2023, 02:38 PM   #23
Technic
Technic's Avatar
2487
Drives: 2025 Countryman S, 2024 i4 M50
Originally Posted by Rodriguezw92 View Post
I’m runing the match 10 amp with 1.9 HK harness while the overall sounds is a lot better but I didn’t achieve the punchie base I was looking for would I be able to run the sound stream rs1200 for the underneath subs along with the match 10 if so what would I need?
Are those the OEM woofers?
      01-06-2023, 02:58 PM   #24
Rodriguezw92
Rodriguezw92's Avatar
Drives: 18 San Marino Blue F80 M3 ZCP
  [0.00]
I replaced the the oem subwoofers with bavsoud under seat subwoofers.
18 SMB F80 M3 ZCP
      01-06-2023, 03:38 PM   #25
Technic
Technic's Avatar
2487
Are they 8, 4 or 2ohms?
      01-06-2023, 03:45 PM   #26
Rodriguezw92
  [0.00]
They are 8 ohms.
18 SMB F80 M3 ZCP
      01-06-2023, 03:49 PM   #27
Technic
Technic's Avatar
2487
They are 8 ohms.
Post screenshots of your DSP inputs, and EQ screens of each channel, please
      01-06-2023, 08:50 PM   #28
Rodriguezw92
  [0.00]
Here are the screen shots I appreciate the help.
18 SMB F80 M3 ZCP
      01-07-2023, 01:12 AM   #29
Technic
Technic's Avatar
2487
Need the inputs screen snapshot, please.
      01-07-2023, 03:12 AM   #30
Technic
Technic's Avatar
2487
Sample setup, Driver-center tune - adjust to taste:
Out A/B = Front components (left/right front door tweeter/mid):
- Hight pass frequency : 150Hz
- Characteristic : Chebyshev
- Slope : -18dB/Oct
- Distance : 36 inches (left), 60 inches (right)
- Output level : +2dB
Out C/D = Rear components (left/right rear door tweeter/mid):
- Slope : -18dB/Oct
- Distance : 24 inches (left), 65 inches (right)
- Output level : 0dB
Out E/F = Rear surround components (left/right shelf tweeter/mid):
- Slope : -18dB/Oct
- Distance : 70 inches (left), 80 inches (right)
Out G = Center component (dash tweeter/mid):
- Hight pass frequency : 200 Hz
- Slope : -24dB/Oct
- Distance : 48 inches
- Output level : +2.5dB
Out I/J = Under seat woofers (left/right):
- Hight pass frequency : 30Hz
- Low pass frequency : 160Hz
- Slope : -24dB/Oct (HP) and -18dB/Oct (LP)
- Distance : 0 inches
- Output level : +4dB
      01-07-2023, 04:12 PM   #31
Rodriguezw92
  [0.00]
Is this the correct one?
18 SMB F80 M3 ZCP
      01-07-2023, 04:13 PM   #32
Rodriguezw92
  [0.00]
- Slope : -18dB/Oct
- Slope : -18dB/Oct
- Slope : -18dB/Oct
- Slope : -24dB/Oct
Thank you so much I’ll try this out
18 SMB F80 M3 ZCP
      01-07-2023, 05:09 PM   #33
Technic
Technic's Avatar
2487
Input setup:
  • Input A = Front Door Left + Woofer Left = Front L Full (50%) + Front Subwoofer L (50%) = Virtual A
  • Input B = Front Door Right + Woofer Right = Front R Full (50%) + Front Subwoofer R (50%) = Virtual B
  • Input C = Rear Door Left + Woofer Left = Rear L Full (50%) + Front Subwoofer L (50%) = Virtual C
  • Input D = Rear Door Right + Woofer Right = Rear R Full (50%) + Front Subwoofer R (50%) = Virtual D
  • Input E = Rear Shelf Left + Woofer Left = Surround L Full (50%) + Front Subwoofer L (50%) = Virtual E
  • Input F = Rear Shelf Right + Woofer Right = Surround R Full (50%) + Front Subwoofer R (50%) = Virtual F
  • Input G = Front Door Left + Rear Door Left + Woofer Left = Front L (33%) + Rear L Full (33%) + Front Subwoofer L (33%) = Virtual I
  • Input H = Front Door Left + Rear Door Right + Woofer Right = Front R Full (33%) + Rear R Full (33%) + Front Subwoofer R (33%) = Virtual J
  • Input I = Center = AUX L = Virtual G
Please read labels in these blue wires and post what is written on them:
      01-07-2023, 11:09 PM   #34
Rodriguezw92
  [0.00]
Input setup:
Input I = Center = Front Center Full = Virtual G
It reads center in +
18 SMB F80 M3 ZCP
      01-08-2023, 12:47 AM   #35
Technic
Technic's Avatar
2487
Center = AUX L = Virtual G = Amp Output G
      01-12-2023, 09:35 PM   #36
Rodriguezw92
  [0.00]
I Turly appreciate all you’re help the sound overall definitely sounds better but I just feel like the base is no where near what I had in my F80 with HK, would you maybe recommend just runing the AudioControl ACM-2.300 just for the subs and maybe taking out the match 10 amp?
18 SMB F80 M3 ZCP
      01-13-2023, 01:01 AM   #37
Technic
Technic's Avatar
2487
I don't think that you understand how to set and tune a DSP. Good luck.
      01-13-2023, 06:16 AM   #38
Marc R
Mr Anderson,we've been expecting you...
Marc R's Avatar
38
Drives: X3 M40i
Everybody has their own taste on how things should sound, therefore it is much better to just take the basic settings and fiddle around until you have a sound that you like.
Thats not as easy as it sounds
I always like to work from the front to the back, each separate speaker at a time and when I am satisfied with one speaker then mute it and move on to the next.
When all speakers are done then its time to join all channels and make them work together.
With the G20 the weak point for me are the 2 underseat subs, they sound horrible and get distorted very easy.... but a good external sub will solve that.
      02-09-2023, 10:46 PM   #39
snopyy
Drives: M340i
Originally Posted by kapa1122 View Post
Helps if I plug the harness in to the booster and not the ram...lol. This definitely satisfies the bass for me, no need for a big trunk sub that takes up space.
Had some leftover plywood and ordered some speaker box felt from ebay and mounted the amp off the rear deck.
Which LOC did you used for RS2.1200?
It seems RS2.1200 itself has a high level input port (250mV – 8V) and I wonder LOC is necessarily required. But I'm not sure HK BASS outputs below 8V.
      02-10-2023, 11:12 AM   #40
Technic
Technic's Avatar
2487
HK Booster outputs in the 26V peak level.
      02-12-2023, 01:07 AM   #41
kapa1122
Drives: 2023 M340i
I bought the one technic posted early on in this thread, Wavtech Link2 LOC.
      02-18-2023, 11:06 PM   #42
Ramos
Ramos's Avatar
Drives: G20 2020 M340
Anyone know a shop in so cal that can help me with the install for the add on amp and the earthquake under seat woofers?
      03-20-2023, 12:09 AM   #43
pdxdbo
pdxdbo's Avatar
338
Drives: G20 330i xDrive M-Sport
We suggest powering the OEM woofers with a Soundstream Reserve RS2.1200 2-ch amp ($150 at Crutchfield), with a Wavtech Link2 LOC ($70 at Crutchfield) for a low cost bass upgrade for a HK system. The Bass Boost feature of this amp can get a deeper and louder bass from the OEM woofers without the need of replacing them.
If you are not satisfied with the extra bass of this aftermarket amp setup then replace the OEM woofers with SWS-8Xi and the Soundstream amp.
Bumping this to see if you or anyone else has any other amp suggestions since it appears the Soundstream Reserve RS2.1200 is out of production and not available anywhere.
      03-20-2023, 03:51 AM   #44
Technic
Technic's Avatar
2487
Check eBay…
bass, h/k
