10-30-2022, 02:39 AM | #24 |
Rep 16
I've watched this video before. Thanks for advice. I did not buy from bimmertech so did not have their bracket. Anyway, I find somewhere on the storage panel as shown below. Will try to sit on top and before that, I just want to ensure everything is fine before I put back all the screw.
10-30-2022, 02:57 AM | #25 | |
Rep 1,009
Bimmertech authorized dealers in HK (you can probably source the other bracket from them, as shown in the video): Green Engine Motors Service No. 1 Pitt Street Yau Ma Tei, Kowloon, HK +852 9333 3207 BMW X5/6 Group Fortune Factory Bldg., 40 Lee Chung St. Chai Wan, , Hong Kong SAR China 999077 85261881638 Audiotec Fischer distributor in HK: BLH RM 301, Lincoln Center,20, YIP Fung Street, N.T tel:+86 852 90916419 Don't risk damaging the computers in your car by making an install mistake & consult an expert in your area. Good luck.
Georgesm9.00 |
10-30-2022, 04:19 AM | #26 | |
Rep 16
10-30-2022, 07:39 AM | #27 | |
Rep 13,023
You bought the UP 8DSP. You need the 1.7 RAM harness for the UP 8DSP. |
10-30-2022, 07:41 AM | #28 | |
Rep 13,023
Bimmertech bracket is for their PP86DSP amp, not for the Match UP 8DSP.
1WickedE90199.00 |
11-08-2022, 08:38 AM | #29 |
Rep 15
Nope. They now offer UP 8 DSP amps with the appropriate bracket. Some are multi amp compatible e.g. PP86/UP7/UP8. As an example a G30 MGU.
09-22-2023, 01:56 PM | #30 | |
Rep 426
The amp does have a MEC slot, came with the PP ISO2 cable, and has 6 channel high level speaker input. My understanding was that the bimmertech amp is a PP 86DSP with a custom harness for plug and play. Part of that customization being that they are supplying power through the 20 pin molex adapter. To be clear, the amp i bought is not the bimmertech version, its the Fischer PP86. Any chance you'd be able to help me understand if this amp will work in my car? I didn't want to lose any functionality or pull the headunit. I just spent a lot of money going for plug and play and convenience. I'd like to understand what exactly makes the amp not compatible if it really isn't... |
09-22-2023, 03:45 PM | #31 | |
Rep 13,023
Your 3-Series is an F30, not a G20. The PP86DSP works with the F30 HiFi system 4ch inputs.
09-23-2023, 11:41 AM | #32 | |
Rep 426
It seems you confirmed the regular/non-bimmertech Auditotec Fischer PP86 DSP is compatible with F30 S676A HiFi. Are you 73mustangconv on ebay? Or is someone else selling your harness? |
