06-05-2023, 09:07 AM | #23 |
No 55mph
1623
Rep 8,479
M440iX G23
Wheels: APEX Forged VS-5RS Satin Bronze, Staggered 19x9 ET 25 Front 19x10 ET 38 Rear Tires: Michelin PS-A/S 4 235/40-19 Front 265/35-19 Rear Suspension: Stock Spacers = NO Rub = No Flush Fitment
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
Expert@ApexWheels3593.00 peelo80128.50 |
06-05-2023, 03:17 PM | #24 | |
Rep 57
If you want to play it "safe", you could run 275/35 rear and 245/40 front... |
09-21-2023, 12:49 PM | #25 |
ncskibum
11
Rep 17
track day set up: m340i xdrive
2020 m340i xdrive with the ZTK tire and cooling package
Dinan lowering springs Millway camber plates -2.5 deg front Apex sm-10 race silver 19 x 9 et28 front and rear Tires Bridgestone potenza re-71 rs 255/35/19 square clears everything with no rub. Keeping stock wheels for everyday driving. |
CSBM52756.00 |
09-21-2023, 07:24 PM | #26 |
Rep 602
11-20-2023, 11:38 AM | #27 |
Rep 42
ApexWheels I am looking at ordering a set of FF SM10s for my M340i xdrive. I have stock height. Why not 285s in the rear? I see you all recommend the 245/40 and 275/35 setup which put the diameter a little taller. The 285 keeps close to same height but is wider in the rear. Can you comment on this?
Ben
_____________________ 24 X5 50e - 24 M340i xdrive 22 992 GTS - 14 F-Type V8S |
11-20-2023, 04:40 PM | #28 | |
Rep 6,819
We recommend 245/40-19f, 275/35-19 to most customers because it has a taller sidewall which gives more ride comfort and has good availability so chances are someone can find this setup at their local distributor or tire rack. It isn't the only option and just because something is not on the guide doesn't mean it will never work. but for anyone going will a setup not on the guide, you'll need to be more well-versed in xDrive-compatible setups and the differences in widths than you would otherwise be going the easy route. -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
AM340iMiami219.00 |
11-20-2023, 08:27 PM | #29 | |
Rep 42
Ben
Expert@ApexWheels3593.00 |
11-21-2023, 02:47 PM | #31 | |
Rep 6,819
This one is right on the edge of xDrive compatible in my opinion, but it's a better fitment in terms of pairing the width of the front tire to the rear and reducing understeer relative to the 245 front/285 rear. If you were going to run a 245 in the front, the 275 in the rear with the larger sidewalls would be my pick, hence its place in the guide. -Tom
M50iStiller48.50 |
11-21-2023, 03:26 PM | #32 | |
Rep 55
12-18-2023, 01:41 PM | #33 |
Rep 1,699
255/35/19 DWS06+
Feel great, nice to finally have some grip! This is my 5th set of Apex wheels across multiple cars, always a quality product. |
Pinkykillaz22.50 |
12-18-2023, 05:46 PM | #34 |
Rep 89
I’m getting an alignment on Wednesday.
Tires: 265/35/19 ADVAN V601 Wheels: 19x9.5 +25 Apex VS-5RS (Front has 13mm spacer) Suspension: Bilstein T1 Coilovers Vorshlag Camber Plates (I pushed it in some but just guessed) |
05-14-2024, 06:30 PM | #35 |
Rep 6,819
BMW G20 3 Series with 19" VS-5RS in Motorsport Gold Wheels: VS-5RS in Motorsport Gold Front: 19x9" ET25 Rear: 19x10" ET38 Tires: Michelin Pilot Sport 4S Ultra High/Max Performance Summer Front: 255/35-19 Rear: 275/35-19 Fitment Guides We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our G20 3 Series guide.
