02-06-2024, 05:31 AM | #23 | |
Rep 151
Kirill @ OdinTuned
02-19-2024, 10:00 AM | #24 |
2022 M4 Comp Xdrive
1024
Rep 1,538
2022 M4 Comp XDrive | Femto unlocked | BM3 Stage 2 OTS FLEX tune 93 octane (at the time with out sensor), Intakes, downpipes, single midpipe, XHP trans flash Stage 3 (v1.5) with Drag mode and Line pressure bump enabled| Ambient temperature 35 degrees|
https://www.bootmod3.net/log?id=65d2...dbeb79e1300cbb *Update* Now i know why boost was low on this. This was a Flex tune and I didnt have the Flex fuel sensor installed at the time so the ethanol content read 0. As such the DME was unable to scale it correctly. Last edited by Dawgz; 04-01-2024 at 08:44 AM.. |
TopJimmy5539.00 |
02-27-2024, 09:09 PM | #25 | |
Rep 4,633
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
03-01-2024, 11:40 PM | #26 |
2022 M4 Comp Xdrive
1024
Rep 1,538
03-04-2024, 04:25 PM | #27 |
Rep 661
Here’s a 3rd and a 4th gear pull.
2022 G80 xdrive - BM3 stage 2 OTS custom rom - 94oct - ER HFC w/ MPE rear - BMS drop-in filters - CS trans https://bootmod3.net/log?id=65e642ddc1bd12726f5aa8e8 https://bootmod3.net/log?id=65e64314c1bd12726f5aa8f0 |
03-31-2024, 10:37 PM | #28 |
Rep 46
2022 G82 Xdrive, down pipes, BMC filters, FEMTO unlock, BM3 flexfuel kit, BM3 OTS e50 stage 2 map.
This was a 1/4 mile pass. I ran a 10.8 on this one which was slower than my other passes on an OTS Stage 2 flexfuel tune running an e30 blend where I ran 10.5 (unfortunately I didn't log that pass). I did flash this tune and go straight to the line so it may have needed more time for the dme to learn adaptations and allow full power. (Just what I've read online, please let me know if it's true that car needs to do a few drive cycles on a new flash before full power is available. I noticed on this log that throttle closes alot, and the boost target trails off quiet a bit as the rpms get higher which seems weird to me, but I'm still learning a lot. https://bootmod3.net/log?id=65fe65704b90142b266a3420 |
04-01-2024, 09:02 AM | #29 | |
Rep 338
04-01-2024, 07:13 PM | #30 |
Rep 46
hellcat2m4230.00 |
04-03-2024, 07:05 PM | #32 |
Rep 46
I tried something a little different today. I filled up drove for a few miles (2-5) to make sure the ethanol percentage reading in bootmod3 had stabilized at e50. Then I pulled into a parking lot and flashed the car to the Stock Custom Rom map. After the stock map finished flashing I flashed the e50 stage 2 map. (It's the same that I posted the log for above.) I did a short log as I pulled out of the parking lot. The log shows the boost target peaking at around 40 psig and the MAP reading about 36.9 psig which is about 15 psi more than when I was at the dragstrip.
It looks like to get the most out of the bootmod3 e50 ots map you have to flash it back to the stock custom rom map first. I can wait to get it back out at the track and see what it does now. Here's a map I did of a pull from a standstill after driving about 45 miles on the map. Looks about the same as the short pull map mentioned above. https://bootmod3.net/log?id=660dd24192122b3ec77a799f 2022 M4 Competition Xdrive Downpipes Drop in air filters Flex fuel Bootmod3 OTS e50 stage 2 map. Last edited by M4Martin; 04-03-2024 at 07:07 PM.. Reason: Add car details |
04-04-2024, 06:10 AM | #33 | |
Rep 151
Kirill @ OdinTuned
TopJimmy5539.00 |
04-04-2024, 09:22 AM | #34 |
Rep 338
I agree something is weird here.
The regular Stage2 E50 OTS map usually targets much higher timing than this. (15-16degrees), and I want to say roughly 25-26psi. https://www.bootmod3.net/log?id=65b9...29f5128a3bf411 This is mine on the OTS E50 for reference. (the pull is at the end) |
TopJimmy5539.00 |
04-04-2024, 11:13 AM | #35 | |
Rep 46
04-04-2024, 12:21 PM | #36 |
Rep 151
The “(RAM) Rel. Fill. Limit Flag” parameter shows the exact reason of why the target load has been reduced from initial setpoint.
Kirill @ OdinTuned
04-04-2024, 01:05 PM | #37 | |
Rep 46
Just so I understand better, the numbers that show with "(Ram) Rel. Fill. Limit Flag" are basically reference codes to the issue the DME is seeing and correcting for? So 1 is related to boost and 4 is related to the lpfp? Is it the same with the Torque Limit Flags? Is there somewhere I can find a list of what the different flags mean? I tried googling it but couldn't find the answer. Last edited by M4Martin; 04-04-2024 at 01:19 PM.. |
04-05-2024, 02:37 AM | #38 | |
Rep 151
Load and Torque calculations are interconnected so the same "flag" thing applies to torque limiting as well. Load Limit flags: 0: Standardbegrenzung 1: Kondensat 2: ATL Bauteilschutz 3: Grenze HDP-Ansteuerung 4: EKP Förderleistung 5: Tans, KR, Fahrverhalten 6: ATM Bauteilschutzregler 7: Partikelfilter 8: Einspritzdauer Torque Limit flags: "Bit - Dec - Description" sets as follows. 0 1 Superklopfer 1 2 kalter Kolben (intern Rf-Begr. bzw) 2 4 Bauteilschutz Ansaugtemp. 3 8 TMC Schutzkonzept 4 16 Flexfuel 5 32 Mdi-Applikation 6 64 Emissionsbegrenzung 7 128 Bauteilschutz Fettgrenze 8 256 Faktor Kuehlung/Fettgrenze 9 512 Notlauf Zylinderausblendung 10 1024 Mdk-Applikation 11 2048 SG-Slave 12 4096 Begrenzung Kraftstofftemperatur 13 8192 UL-Variante 14 16384 Kraftstofftemp. 15 32768 Notlauf 16 65535 Standard 17 131072 Kondensat 18 262144 ATL Bauteilschutz 19 524288 Grenze HDP-Ansteuerung 20 1048576 EKP Förderleistung 21 2097152 Tans, KR, Fahrverhalten 22 4194304 ATM Bauteilschutzregler 23 8388608 Partikelfilter 24 16777216 Einspritzdauer
Kirill @ OdinTuned
TopJimmy5539.00 |
04-21-2024, 01:48 PM | #39 | |
Rep 661
Updated logs with an E blend of 34% Logs look relatively clean with little timing correction with the exception of run 4. Any thoughts on why timing went apeshit on run 4? Run 1: https://bootmod3.net/log?id=662551e34f444e12992f343a Run 2: https://bootmod3.net/log?id=662553399d6af508eb0b2ac2 Run 3: https://bootmod3.net/log?id=6625536155de0817d926d062 Run 4: https://bootmod3.net/log?id=662553e59d6af508eb0b2ac8 |
TopJimmy5539.00 |
05-08-2024, 05:48 PM | #40 |
Rep 5,213
BM3 OTS Stage 2 E50 (not the flex map, dedicated E50 map)
Looks like timing maxes at 15.5deg and boost at 23.5PSIg on 4-5-6 rips. https://www.bootmod3.net/log?id=652d...90c657b34a9cee https://www.bootmod3.net/log?id=652d...0b434a9cd74a6c Paul's custom E50 (not flex, dedicated too) a few revs in... I see 18.5deg of timing and 30+PSIg on 4-5-6 rips. https://www.bootmod3.net/log?id=6635...5a7112cb7ee933 https://www.bootmod3.net/log?id=6633...5a7112cb7edcdb I'm still doing revisions and will have to keep final logs private. |
05-08-2024, 07:56 PM | #41 |
Rep 661
For comparison purposes here’s recent logs on an OTS stage 2 93 flex-fuel map on 47-48% ethanol. Seems like timing is down 1-2 degrees and boost is bumped 3+ psi.
https://bootmod3.net/log?id=663a61773ce2f903cd920a04 https://bootmod3.net/log?id=663a620661bd5c26d0f661ca |
TopJimmy5539.00 |
