BIMMERPOST Universal Forums General BMW News and Cars Discussion Run flat/No run flat
      11-10-2024, 05:15 PM   #23
IanH
Drives: '25 M240xi
Originally Posted by Mavus View Post
From Michelin
“Note: While non-winter tires featuring the three-peak mountain snowflake (3PMSF) symbol may provide additional longitudinal snow traction beyond what all-season (M+S) tires not bearing the symbol can deliver, they do not match the capability of a true winter tire in all adverse weather conditions.”
They are talking about it not performing as well as studless and studded tires in the most extreme conditions.
But the actual test results across brands show the cc2 ranking in the top half of the "true winter tires" on the market in snow driving.
I've used them in deep snow and challenging conditions and had no perceptible difference in capability from a real winter.
The thing people REALLY get wrong is that a snow tire is only best at driving ON SNOW. You lose critical performance, especially in braking, on any dry surface of any temperature. So unless you live on a dirt road in the far north of America there is really no rational reason to run a snow tire compared to what else is available thse days.
Both weatheractive and cc2 putting up the best all around performance numbers, and good tread wear, and good rolling resistance.
2025 M240i Xdrive TNM/Cog
      11-10-2024, 05:43 PM   #24
wizardofOz
wizardofOz's Avatar
1690
Drives: M135i
This may/may not help you..
      11-10-2024, 06:32 PM   #25
Mavus
Mavus's Avatar
2326
Drives: E90 335i, F80 zcp
I've used them in deep snow and challenging conditions and had no percentile difference in capability from a real winter.
It does look like cc2 is more of a winter compund than all season and is compromised like most all seasons for 4 seasons. There are also perf winter tires that work very well in dry and cold but also when weather changes quickly like freezing rain.
      11-10-2024, 09:07 PM   #26
jkoral
Drives: 2017 M2 LBB 6MT
Doesn't look like the winner of that video test above, the Cinturato All Season SF3 is available in the US (at least I don't see it on TireRack)
      11-10-2024, 09:33 PM   #27
IanH
Drives: '25 M240xi
As I mentioned above, I called around. Sf3 not available in the US with no known planned release.
You can get the cinturato weatheractive, which has a different tread design and compound.
jkoral1151.00
      11-11-2024, 12:32 PM   #28
da@davidarriola.com
Drives: X7 '23 4.0, X5 '15 3.5d, 535d
Tire Mileage Ratings in Arizona, or Elsewhere
While shopping for tires you've likely noted not many give a mileage estimate. The climate and the high performance nature of bimmer driving doesn't help. I have nearly nine years on two bimmers we own (both 2015) and we have tried every manufacturers size appropriate models. They're all similar, but you may like the look and feel of one better than the other. Initially I was unenthusiastic about the RF offering, but have adapted concluding that it's a plus with cars your spouses or children drive. The mileage will be about 20K on all if you're lucky. Enjoy!
