01-25-2025, 08:47 AM | #24 |
Rep 137
If it’s what’s sometimes referred to as the high end being a little too bright, I think adding the 120 high pass filter to the doors and center speakers per the Audiotec Fisher recommendation might be helpful.
It’s fairly easy in the DSP tool, under the Outputs tab, where it says Highpass, you set Frequency to 120, Slope to -24db, and Characteristic to Butterworth or Linkwitz. What that should do is keep the lower frequencies out of all those mid and tweeter speakers, cleaning up the high end. Worth a shot as I thought it helped a lot. |
01-25-2025, 11:06 AM | #26 |
Rep 135
01-26-2025, 10:54 AM | #28 |
Rep 137
I found that if you give the under seat channels a 3db gain boost in the DSP PC-Tool, you can feel a slight vibration in the seats, which is nice. You can find the slider on the righthand side of the Subwoofer 1 and 2 Outputs tab labelled Output Gain and Output Level.
m440i80452.50 |
01-26-2025, 02:03 PM | #29 | |
Rep 55
Drives: 2021 M440i X-Drive
m440i80452.50 |
01-26-2025, 02:06 PM | #30 |
Rep 100
There are several thing that could help you guys.
1. Factory input signals. I have an X5 with HK. iDrive 7. So my system might be a little bit different. The factory signals in my car are already "EQd". Meaning they already have crossovers applied. Green - Woofer input signal / Red - Front Full range speaker. That said, I am using a LP of 170Hz, 24dB/oct on the Woofers. 2. EQ Ideally, you want your Woofers (Left and Right) EQd the same way. If they are not EQd the same, then in some areas they will help each other, while in other areas cause dips (or even nulls). 3. Time alignment Speakers should be time aligned. If the sound from the Woofers arrive to you at different time, it will not sound good. Time alignment is relatively simple in PC Tool. You have to measure the speaker cone's distance to your listening position, and then enter the values in PC Tool. 4. Levels You want to level match the Left and Right Woofers. They should be playing the same level (Left and Right side), measured from your listening position. 5. Check the Woofer's polarity. This is also critical. The Woofers will have areas where they overlap with the Mids. If the Woofer's polarity is wrong, then the Mids and Woofers will cancel each other out. This will result in weaker "Bass" in that region. You can try to play just the Front L + Woofer L for example, and flip the polarity of the Woofer. You might notice the Bass sounding better in one way or another. Usually, if the Woofers were wired corretly, then the other Woofer should have the same polarity setting in PC Tool. But verify this by listening to them. These are the basics. If you want to make the system sound great, all these things have to be set for each speaker. But since you guys are only talking about Woofers, these points might help you look for ways to improve the sound. Ideally, when your speakers have the correct crossovers, are EQd, time aligned, level matched, with the correct polarities... you should have a pretty decent sound. If you want to tune the system, then you might want to look into getting a measuring Mic, like the UMIK-1. Then with REW you could set and verify all of the above... |
01-26-2025, 02:08 PM | #31 |
Rep 137
I think that's probably right. When I added the Front Full input to the Subwoofer signal, I could hear the higher frequencies going to those 2 woofers (the Ci5s can play up to 500hz), but I didn't think it was worth it. They seem to hit harder if you use only the subwoofer 1 and 2 signals.
m440i80452.50 |
01-26-2025, 02:43 PM | #33 | |
Rep 55
01-26-2025, 02:47 PM | #34 | |
Rep 137
Basically I think they're best run as subwoofers only and not as dual sub/mid drivers. YMMV |
m440i80452.50 |
01-28-2025, 12:07 AM | #35 |
Rep 135
Are the front mids on your cars actually mounted into an enclosure in your door, or just kind of mounted to the bracket like free air?
I pulled my front door cards off today on my 440 and was surprised that the mids were just mounted to a bracket with nothing behind them. I think it will be hard to get any bass out of them that way. Seems like a bad design for performance. Have a set of es100ke’s enroute but probably won’t use them. |
01-28-2025, 12:54 AM | #36 | |
Rep 100
This is not so easy to do without measuring the speaker's responses. Depending on the situation, overlapping crossover regions can make the sound muddy. Or even weak (if there are cancellations). Subs are usually not played very high for various reasons. They are most efficient, and sound the best in the lower fr. regions. The LPF 80 is generally where people cross them at. So lowering the LPF on the Sub sounds about right. But without measuring, you won't really know what the situation is in the crossover area. |
01-28-2025, 01:01 AM | #37 | |
Rep 100
01-28-2025, 01:14 AM | #38 |
Rep 135
01-28-2025, 07:09 AM | #39 |
Rep 137
Yea that’s the plan with my umik mic. I may bring them up to 120 to blend with the doors HPF. I was just going by ear while muting all the other speakers for the time being.
01-28-2025, 05:39 PM | #40 | |
Rep 282
**I really have no idea** what you're running the 4" mids down to, 160Hz? You could probably hit 120Hz @ 24dB but they're running out of steam due to xmax. Without a trunk sub there's physical limitations due to the size of the drivers under the seat. Most of these aftermarket drivers can't do much below 50Hz (same as factory). If you can put a filter at 40Hz and 24dB slope on the underseat speakers you will find that you can push them much harder without reaching their xmax and it sounds great. Matter of fact, I'm thinking about downsizing and removing my AuiodFrog GB10 subwoofer. That's how good the underseat speakers can be. There's just way too many rattles in this car to keep me happy down to 20Hz. I'm not in the mood to track down all the vibrations either. |
snekjumpr111.00 |
01-28-2025, 05:45 PM | #41 |
Rep 137
Yea I set a high pass on all the doors at 120 per the Audiotec rec.
I800C0LLECT228.50 |
01-29-2025, 08:07 AM | #42 |
Rep 85
Drives: G20 M340i xDrive
I really like the design of those Helix subs. How do they compare to Earthquake SWS-8xi? Better? Worse? About the same?
01-29-2025, 09:36 AM | #43 |
Rep 137
I didn’t see the frequency response on Amazon, but the Xmax looks more impressive on the Earthquakes, almost 1 inch in each direction. My guess is you’ll feel more air displacement with that kind of movement of the driver.
Raghza23.00 |
01-29-2025, 05:26 PM | #44 | |
Rep 282
here ya go...
https://f30.bimmerpost.com/forums/sh...cal+K2&page=40 EDIT: Bill Fitz is a hero...but these aren't in-car measurements. You will get a better response in car due to cabin gain but the performance gap will remain Quote:
Raghza23.00 |
