02-09-2025, 11:49 AM | #23 | |||
![]() 1384
Rep 2,666
98% of the time I charge in my garage, or at work (cheaper, but harder to find an available charging plug).
Most contracts stipulate minimum SOC % (state of charge) upon return, and charging to just the right amount in the nick of time is a PITA. You can rent an EV if on vacation, or if you want to try them out. But if you are on a tight calendar and want to get to the airport just in time before take-off, charging EVs can become a handicap. I went through that once, not doing that again. Quote:
Cold soaked batteries happen, same as cold soaked ICE engine blocks. Both will warm up as you drive. Quote:
My mom (not an EV person, can barely use an iPhone) can drive my Model 3 without issues. Same physical lever to put the car in gear, same pedals, same steering wheel. The rest is fluff that can be ignored. HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-09-2025 at 12:14 PM.. |
02-09-2025, 12:40 PM | #24 | |
![]() 2231
Rep 2,970
02-09-2025, 03:56 PM | #25 | |
![]() ![]() ![]() ![]() 766
Rep 789
From my understanding, you can not turn off traction or stability control 100%, unless you go into "drift" mode which is only the rear wheels when turning, then all wheels when straight so its really only good for doing donuts. Again, this is only in the performance model, unfortunately. Ive heard of people getting stuck in the snow because they cant turn off traction control. Slip start does not really disable it, it just gives you a little bit more at lower speeds, causing people issues in the snow. The brakes are more than undersized. The brake pedal feel is mushy. It doesn't bite as well as my BMWs or even my 2018 Camry if you can believe that. I spoke on the key fob in my post, do you have one? LFP battery does not like to be charged 100% either just like lithium ion. If you need a link i can probably find the scientific study. LFP also enjoys similar charges BUT doesnt take *as* much abuse when 100% charged, again, still not "good" for it speaking of longevity. |
02-09-2025, 04:06 PM | #26 | |
Rep 789
It isnt the charge cycles, its the age and stress of the cell which kills it over the years, many packs are lasting 15+ years which exceeds the average 12 year car lifepsan. Newer batteries are even better, but data is limited |
02-09-2025, 10:20 PM | #27 | ||||
![]() 1384
Rep 2,666
https://www.tesla.com/ownersmanual/m...70F5506FD.html Quote:
Personally, I've never had problems in snow in 3P on snow tires, until the nose starts plowing fresh powder. Soon after that the volume of compacted snow under the nose starts lifting front wheels off the ground, and things can get exciting. I remember having those exact problems in my 3-series as well. No, I do not. Even though all my other cars have them. I really appreciate the unlock-by-cell phone mode now. There are surprisingly many situations when you may want someone in your family get into the car when you are not near: shopping (drop off bags), leave the car for someone at train station / restaurant (and they hop into it whenever). Everyone in my family, including kids, have Tesla app with car unlock by proximity installed. The only downside is you HAVE to take the phones out of the car when you park, else the car wont lock itself. But the same restriction applies to the physical key fobs. Quote:
LFP is happy with 100% SOC levels. Unlike the other chemistries. Things get more interesting when you start discussing DC vs. AC charging modes, charging rates, temperature management, and whatever else I'm forgetting. A bit too much information is here: https://shop.driveprotected.com/blog...20occasionally. Quote:
There has been a bit too much doom and gloom spread about EV battery longevity. Sometimes out of ignorance, occasionally on purpose. I had run a deep-cycle Tesla battery test on my MY'19 TM3P with 68K miles last summer. The results were that battery was at 89.7% of the stated capacity. The rate of SOC degradation is an exponential decay function, with much degradation happening in the first year and then rate of decay slowing. I find my 6-year mark perfectly acceptable, and have zero worries about approaching 70% SOC warranty limit by 120K mile / 8 year. Maybe by 2x that, if ever. a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-09-2025 at 11:07 PM.. |
MaC-N54-E82627.00 |
02-10-2025, 12:39 AM | #28 |
Rep 923
Figured I should Chime in.
I have had 20 BMWs over the past 25 years. Generally smaller performance oriented cars, 135s, 335s, older 330, 435, M3s, M4s, M5, 550, 750, x3 and X6s so I’m a BMW fan boy of sorts. Everything has been moderately modded along with a handful of supercharged GM muscle cars, up to about 700 rwhp. Currently we have an X6M and M2, along with a ram pickup truck ICE vehicles. 21 S plaid and 22 Model Y Performance. Have had the model Y a bit over 2 years and the plaid just under 2 years. We live in the mid Atlantic. From Washington DC to NYC the Tesla network is very strong so range extended charging is never an issue. We do have chargers at home, 2 of them actually as I didn’t want to bother plugging and un-plugging cars. We rarely do charge outside of the home. I couldn’t imagine dealing with a EV without access to home charging. It’s great never having to go to the gas station and leaving with a full tank every morning. Heat pumps are great. Efficient and able to heat cool immediately if you forget to turn them on and the ability to flip them on from your phone. My phones (new Samsungs and my wife new iPhones) never have any problems. The S has fobs and both have the credit card keys. I can always have both keys in my wallet in case the phone fails. Can’t tell you how many times I’ve left my BMW or Ram unlocked as I’m spoiled by the proximity locking of the tesla. Plus no buttons to press once you’re in the car. The Model Y has the regular wheel, shifter and turn signal. It could use a few buttons instead of the screen, but I can say once you know the screen it’s all there and easy to use. Plus the screen is super fast, so much better than everything else I’ve been in lately. The S had the yoke (fighter jet) wheel. It’s stupid in this car where you have to turn it over and over with whatever it is 2.5 turns lock to lock. The adaptive steering on the cybertruck makes sense, but it was stupid in the car. I have put in a real steering wheel. The lack of turn signal is annoying, not having a horn where the horn goes also dumb. The slide to shift at least has been addressed by it now predicting if you are in reverse or drive, which works about 90 percent. What I like. 1. Incredibly smooth. No shifting at all, power delivery is so linear and smooth as well as stopping and slowdown. I find the regen setting and 1 pedal driving fantastic. Rarely using the actual brakes. 2. In the end it has every option that I would want other than heads up display. Heated, cooled seats, climate air, good headlights, great cameras/sensors, and all of the safety items, braking, cross path, blind spot, etc. All included, no expensive packages. Great stereo. I’ve never had a bang and olufsuon so I can’t compare that, but the HK in the X6, 750, M5 isn’t as good as the S, and the HK in the 2, 3, 4 series isn’t as good as the model Y. 3. The power in the Y. Instant on demand power is just wonderful. Even the model Y is great to drive in traffic, on the highway, etc. Just lean into a bit to accelerate dramatically to move, cut in and out, etc. 4. The power in the plaid. It’s not crazy, ridiculous, even ludicrous, it’s plaid. Imagine tuning up an M4 or M5 to max boost, the type that throws codes and limp modes here and there. Then drive around in 2nd or 3rd gear so you’re somewhere around 5000 to 5500 rpm at all times at the edge of peak boost and it still wouldn’t compare to the power under your foot. What’s crazy is when you want to go a bit crazy you realize you’re not even maxing it out. While the M3P and MYP as well as mustang Mach GT I’ve driven has a nice hard hit at low speeds, the Plaid maintains that kind of jump at 80 or even 100 mph. I mean low 9s at 150 plus in the 1/4, AWD, hatchback, room for 5. I think Motor Trend clocked it at 4.3 sec to 100, that’s respectable on the road to 60mph in ICE sedans. 5. The ride in the plaid is nice. Between adaptive dampers and ride height along with better sound deadening it’s a great place to spend highway time in. Plus the interior is pretty good quality, definitely nicer than the lower end BMWs, not quite as nice as M5, 750. The Y does feel a bit cheap inside, though the seats, arm rests and steering wheel are all quite fine. The Model Y is a bit choppy and sporty. M sport BMW, not comfort or Mercedes at all. In general I think they should have done a better job with the ride and road noise. What I don’t like. 1. Road trips, long rides. It doesn’t seem like stopping for fuel. 15 to 20 min of charging is way longer than the 5 min it takes to pump gas. Generally if we are going over 200 miles we drive a gas car, under that EV. 2. The turn signals, yoke and shifting on the S are stupid. 3. No buttons at all on the console is a bit of a drag. The one I would like would be a volume button and door lock. 4. AS noted without a charger at home I can’t see doing EV. 5. The model Y has the stupid door handle you have to push and pull. Not worth the look. The S at one point wouldn’t present the handle on the passenger door, that did require a trip back to dealer. I’m not sure what happened. Car went in for a windshield and recalibration after replacement at dealer and this didn’t work after. Needed to return next day and have them re’-flash something. Otherwise both cars have been trouble free. 6. Model Y Performance comes with low profile 21s (255/35 and 275/35). For the winter I have 255/50/19s on it. Rides better despite them being snow tires. I think it needs smaller wheels, like most BMWs for a better ride. Part of it is the suspension itself. Kind of reminds me of when BMW first switched to run flats, when the suspension was somehow both harsh and floaty at times. I bought the M2 as I miss driving a manual and I do like it better than my M4 that I had previously. The X6M 2018, has the stupid ZF8 that they make behave like a DCT. Unnecessarily clunky and cumbersome feeling. Makes the electric seem that much smoother. While powerful, that V8 does need a few RPM to get the torque up, so it just doesn’t have that smooth ride the EVs provide. My wife loves the X6. We’ve have 4 of them over the years. We do road trip it, but it could surely use some more space at times. The frunk is actually useful in the EV. My wife doesn’t like the look of the X5 which is the obvious choice for more room. I think where things are currently having both in your household makes sense. Road trips and manual transmissions are still some of the best driving experiences around and both best in ICE vehicles. The daily grind is wonderful in the efficient, powerful and smooth EVs. I calculate my electrics at about 100 to 110 mpg based on current gas prices compared to what I pay at home for charging. Feel free to ask any questions. I ended up buying the plaid used right after the big price drop in 2023, so I paid 75k for it with 12 k miles on it. Cheaper than a similar M5, and the Model Y performance to me is indeed cheaper than an X3m, similar to x3 M40. So value is there in my opinion.
18 X6M, 22 Tesla MYP, 21 Plaid, 19 Ram
beats245.00 |
02-10-2025, 03:43 AM | #29 |
Rep 29
I think people are misconstruing some of the noise levels. With no ICE engine to cover up noises an EV is really silent in the cabin where any little noise seems really loud in comparison, which makes the road noise really noticeable.
My 2020 M3P really improved going from 20” oem Pirellis to 18” Hankook Ion AS, much better noise levels than my boss’s M3 with 18” oem Michelin AS. I bought the M3P used, to put less commuter miles on my Z4. Even accounting for not having a charger at home this is still cheaper than my Z4 (oil, brakes, etc). I occasionally drive down to Socal for work and it’s nice expensing the miles on it. Single charge for lunch to make it to the hotel then charge during dinner to last me the week while I’m down there. Funny story, I drove to Vegas for a wedding and there was a truck that ignited the oversize load of commercial lithium batteries it was carrying that closed highway 15 for the entire day. Went from a 8 hour trip to a 20 hour trip due to traffic and detours. Thank god I was in an EV, lines for gas 3-4 blocks long or even longer, people running out of gas due to idling, a major shit show. There wasn’t even a line when I got out of that mess to charge. |
02-10-2025, 05:38 PM | #30 | |
Rep 789
Track mode DOES NOT disable Traction control, it reduces it to -10 whatever that equates to for teslas software. It also will not fully disable Stability control, which is the fun part when you are on track. Its unfortunate, but really, they should just allow people to fully disable the nannies, like other performance cars or the Hyundai Ionic 5 EV The Key Fob does not work as well as other car manufactures fobs, it has a lag effect at times from what i understand. This was one of my points about it. Last edited by natedog7700; 02-11-2025 at 06:06 PM.. |
02-11-2025, 06:05 PM | #31 | |
Rep 789
02-11-2025, 07:42 PM | #32 |
Rep 29
It was like 110f outside so that’s the main reason why.
