07-09-2014, 03:39 AM | #45 |
Rep 1,131
Mate, I am still in awe of you predicting the F8x performance numbers so accurately back in, what was it, 2011? Always pay a lot of attention to your analysis, even though that tome above got pretty heavy going
07-09-2014, 05:43 AM | #46 | |
General
21132
Rep 20,742
Drives: 2021 911 turbo
Regarding transmission types, mostly front engine rear wheel drive cars, where the transmission input shaft is on the same axis as the output shaft, can get that benefit on the 1:1 ratio. I have personally not seen it on a FWD transaxle and I am not sure it could be done on a mid/rear engine car. It is also possible that some FR cars don't have a direct drive, but that would be a rather inefficient design as it introduces an additional set of gears. I have also seen sketches of a 7 speed DCT with a 5th gear direct drive, so it is possible. I cannot confirm how the ones in the ///M models are configured though. Looking at cutaways or cross sections and counting the number of gear sets would tell us (8 gear sets equates to one direct drive gear, 9 gear sets equates to no direct drive). The losses in the direct drive gear is probably less than half of the other gears in a MT. Since the power for other gears needs to go through two gear sets (from the input shaft to the the layshaft and then from the layshaft to the output shaft), the only losses left in the direct drive are the parasitic losses of oil churn, the gears spinning with no power transmitted and the losses in the bearings. On the DCT, the oil pump still needs to be driven even in the direct drive gear, so IMO there might not be as much reduction in losses (less than half) in the direct drive of a DCT. Last edited by CanAutM3; 07-09-2014 at 10:43 AM.. |
07-09-2014, 05:55 AM | #47 |
General
21132
Rep 20,742
That is a very good point that I wanted to bring up. The F8X dyno was likely done in the more efficient 1:1 fifth gear while the the E9X was most likely done in a less efficient gear. That can explain a ~2% difference. Further, because of inertial impacts, the E9X would probably show lower power in 7th gear (assuming the dyno could take the speed) even if there are less drivetrain losses.
07-09-2014, 06:08 AM | #48 | |
General
21132
Rep 20,742
It does not take away CatPat8000's point that Dynapacks can be significantly more accurate, they just need to be operated properly. |
07-09-2014, 06:46 AM | #49 |
General
21132
Rep 20,742
Another great thread. I really appreciate those discussions. They force me to think, learn from others and expand my knowledge. Thank you Swamp .
I agree with Swamp that the S55 and other BMW engine are most likely not "underrated", I seriously doubt that would be accepted by the regulatory agencies. I also agree that the "power plateau" provided by the FI engines are a significant contributor to the improved acceleration performance. It however does not explain what we see on dynos. I think that there is more to it. I will be the first one to say that dynos in general do not provide accurate or repeatable numbers. However, I believe that we will see a general trend where the S55 will produce more than the advertised 11hp difference over the S65 and that does tell us something. As I have stated in other threads, I believe this has to do with the testing standards and methodology combined with the new technologies introduced in the powertrains. First of, the S55 powertrain has very likely less overall inertia that the S65 powertrain. Smaller crankshaft, two less camshafts, one less timing chain, CF driveshaft, lighter wheels and less mechanically driven accessories (more on this below). Those will all contribute to higher readings on chassis dynos. An other example is the ever increasing use of electrically driven accessories over mechanically driven accessories. When establishing the "official" power ratings, IIRC, all accessories need to be driven and loaded (alternator, AC compressor, power steering pump, water pump, etc) thus lowering the rated power output. On an engine like the S55, most of those accessories are electrically driven. A bigger alternator, the AC compressor and the oil pump are probably the only mechanically driven accessories left. During an acceleration run, the ECU disconnects some of the accessories reducing the parasitic losses. Further, since there are less mechanically driven accessories on the S55, it also reduces the overall inertia of the engine. This will show as more power to the wheels on a dyno operated in transient mode. The above is only speculation on my part trying to understand what is being observed. It probably does not explain the whole difference but IMO, at least covers part of it. Last edited by CanAutM3; 07-09-2014 at 10:38 AM.. |
07-09-2014, 06:53 AM | #50 | ||
Rep 3,099
Ed: only loa bearing dynos (mustang, dynamics) have controllable variables and calibrations Inertial dynos (dynojet) don't. Inertial dynos are effected more by wheel weights and gearing, yes.. But as long as the operator is honest, picks the right gear etc. the numbers are legit. |
07-09-2014, 06:56 AM | #51 | ||
Rep 3,099
I'm talking a base tune s65 or n54 etc on bms's dyno (for example), similar conditions To a base tune s55 The s55 made more peak power untuned on the same dyno in similar conditions, than an s65. That's all i'm saying there. Remember, we're talking dynojet... Dynojet DON'T vary (much), they're a fixed load that's the beauty of them The numbers may not be 100% accurate depending who you talk to... But as a comparison tool, as long as atmospheric conditions are the same, it's the only dyno's you CAN compare.. Ish. |
07-09-2014, 08:48 AM | #52 | |||
Rep 5,110
07-09-2014, 10:35 AM | #53 | |
General
21132
Rep 20,742
My guess is that the error is still high, but with enough statistical data points, I believe that, on average, we will see F8X put more power down at wheel than the 11hp rated difference with the E9X M3. Last edited by CanAutM3; 07-09-2014 at 10:50 AM.. |
07-09-2014, 10:35 AM | #54 |
Rep 8,679
I think it's very simple... two cars were dyno'd on the same dyno. S65 vs S55.. one showed considerably higher power and tq... trap speeds have backed this up so far. Everything else is mumbo jumbo that means nothing in the real world and to most people.
Also... not to be a pain... but I would change those 60 ft numbers immediately to prevent myself from looking like a fool lol. 1.6s and 1.7s on rwd cars on street tires are laughable at best.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
07-09-2014, 11:08 AM | #55 | |
Rep 5,396
the merc m157 (new 5.5l turbo v8) the audi s4 3.0 SC the 335i n54 all of which also dyno'd at much higher than advertised numbers using the standard 15-20% DT loss. none of those had a CF driveshaft or the like I don't know the answer, im asking
07-09-2014, 11:33 AM | #56 |
Rep 10,407
Thanks, yes, long/heavy. Again when recanting a strongly held prior position significant evidence is needed.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
07-09-2014, 11:35 AM | #57 | |
Rep 10,407
07-09-2014, 11:42 AM | #58 | ||||
Rep 10,407
Not according to the above...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 07-09-2014 at 11:54 AM.. |
07-09-2014, 11:53 AM | #59 | ||
Rep 10,407
Honestly, if you think simulation is "mumbo jumbo" you should just stop driving your car (and throw away your computer and mobile phone, and never ride in an airplane, etc., etc.). Do you have any idea how much simulation is used to design modern cars? I work in this field and what is simulated spans every major subsystem of the vehicle and includes huge efforts by the OEM and all tiers of suppliers. It is a major predictive enabler that makes modern cars as good (and continually improving) as they are. These techniques increase understanding, speed development, save cost, reduce and in some cases eliminate test. They are almost always compared to test though to insure correspondence, strengths and weaknesses. The simulation techniques used in CarTest and Quarter Pro are simply much more simple version of those type of simulations. Quote:
The traction models clearly allow wheelspin at launch, during shifts, account for weight transfer and decreased tractive force during wheelspin. The fundamentals are all there, sure they aren't prefect and seem to represent more like a drag tire on a drag course. Care to comment on the E9X M3 simulation results vs. test. Pick any number you like other than the 60' time. Ever hear of not throwing out the baby with the bathwater. It applies here. I'd rather have poor 60' numbers and wonderful everything else than some bogus test telling us that the car makes 425 rwhp... Of course, as you should know, I can't and won't just "change the numbers". They are what they are as the result of the inputs, physics and algorithms used by the tools. Anything else would be massively dishonesty.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 07-09-2014 at 11:59 AM.. |
07-09-2014, 12:07 PM | #60 | |
Rep 8,679
07-09-2014, 12:17 PM | #61 | |
General
21132
Rep 20,742
Regarding the EAS dyno output of the M4, I believe it showed 412~414hp corrected to SAE standards, not 425hp. Not a huge difference, but one nonetheless. |
07-09-2014, 12:26 PM | #62 | |
Rep 10,407
Also 405-410 whp does not match current traps. 11.9@117 is 425 hp * (1 - 15% loss) or around 360 whp. I could run a simulation with 410 whp but since you think all of these results are useless I suppose I won't bother. Also as posted below, the 121 trap was for 417 whp, not 425. This car performs like a 360 whp car with 360 whp available from 5500 rpm to redline (along with massively more hp than the S65 below 5500 all the way down basically to idle - as per published BWM documents). You just can't compare cars with similar peak power when their power curves look as different as the S55 and S65, completely nonsensical comparison. You know this - modern turbos are a "different beast". Nothing wrong with some healthy debate. I'd like to think of this as debate rather than argument...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 07-09-2014 at 12:42 PM.. |
07-09-2014, 12:32 PM | #63 | |
Rep 10,407
Good luck on the ongoing dyno investigation. If you can "solve" this, it will be a huge success.
07-09-2014, 12:46 PM | #64 | |
Rep 8,679
07-09-2014, 12:50 PM | #65 | |
General
21132
Rep 20,742
Note that the CF driveshaft is only one small part of the total equation in the total powertrain intertia. On the engines you referenced, do they also leverage electrically driven accessories? |
07-09-2014, 01:08 PM | #66 |
Rep 1,264
The car will trap 120-121 when the weather cools some more and the cars are fully broken in. Just IMO. EAS didn't do a 1/4 mile yet and Terry has only done VBOX times in the heat. I would wait to see some actual 1/4 mile times in nice weather.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
