09-17-2022, 06:35 AM | #45 | ||
Rep 1,516
09-19-2022, 11:58 AM | #46 | |
Rep 1,516
The main issue resides with the front sway bar. Neither the M340i xDrive or 330i front sway bar options from H&R will install - confirmed by H&R. Additionally, the BMW part numbers are different in case someone was curious. I guess we shall have to wait and see which manufacturer designs a front sway bar option for the M340i RWD, but for now there are no current options from either H&R or Eibach. |
09-19-2022, 02:16 PM | #47 | ||
Rep 1,396
Guess I'll wait too until both front and rear can be installed at once.
Chubbiejones909.50 |
09-19-2022, 02:23 PM | #48 | |||
Rep 1,516
Agreed, all we can do is sit and wait. |
09-22-2022, 07:57 AM | #49 | |
Rep 561
:-D
(Retired 2020 - M340i RWD | Executive)
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
09-22-2022, 06:17 PM | #50 | ||
Rep 1,516
TheJungatron374.00 |
10-28-2022, 12:47 PM | #51 | |
Rep 64
My perception is that the front is very planted and doesn't really roll much at all, while the rear has more roll and wants to "wander" to the outside of the curve - not what I like. Based on that and the fact that it seems the H&R sway bars add 2mm thickness both front and rear, I was thinking that only upgrading the rears might achieve exactly the balance one would want. Planted and pleasant in the front and stop the "wandering" and roll on the rear. Not sure if others have the same evaluation... By the way my set-up is 2023 M340i standard suspension with high-performance tires. |
Chubbiejones909.50 peelerec1247.50 |
10-28-2022, 12:49 PM | #52 | ||
Rep 1,516
10-28-2022, 11:29 PM | #53 | |||
Rep 1,396
10-29-2022, 08:59 AM | #54 | ||||
Rep 1,516
peelerec1247.50 |
11-07-2022, 12:06 PM | #55 |
Rep 64
Sway vs Oversteer
The amount of work to install the sway bar has been a definite deterrent for me as well.
Last week I installed a high-flow downpipe (APEX Built) and a front strut tower brace that mimics the Cusco brace for the Supra (ordered on eBay). I have to say that with the added power and the brace, it seems to easily get into an oversteer situation around tighter bends. Given that, I am reconsidering putting a stiffer rear sway bar on as that would just add to the oversteer issue. The brace by the way has made the steering response a little more immediate and crisp. Not that one would expect huge changes from an already very well-dialed-in steering and suspension, but to the discerning driver of curves, there is a slight improvement. |
11-07-2022, 01:05 PM | #56 |
Rep 378
11-08-2022, 03:32 PM | #57 |
Rep 64
11-08-2022, 03:45 PM | #58 | |
Rep 378
11-10-2022, 08:42 AM | #59 |
Rep 561
Hurry up Chubbie and install this bad boy ;-)
11-10-2022, 08:46 AM | #60 | |
Rep 1,516
11-15-2022, 08:47 AM | #61 |
Rep 64
Tires...
I just switched my tires and rims to my "winter" set - here in Texas that means all-season tires, to deal better with rain and cooler temperatures than performance summer tires. I put on Michelin PS AS4s versus the factory Goodyear Eagle F1 Asymmetric 5.
The differences in driving characteristics of the car are significant - it's almost as if I had made some noticeable suspension changes. The car steers more crisply and directly, the rear end track very precisely, no more drifting feeling where the rear wants to "wander" to the outside of the curve. If you're running anything other than Michelin PS4S or Michelin PS AS4 you might try switching to those tires before spending the big bucks on sway bars etc. - you may find it tightens up the drive sufficiently to forego those other more involved modifications. |
11-15-2022, 08:53 AM | #62 | |
Rep 1,516
PhantasticDad33.50 |
03-12-2023, 05:47 PM | #63 |
Rep 64
Just thought I'd add a recent experience on this topic... I installed an Ultra Racing brace for the rear lower frame that helps stiffen the rear subframe. It was extremely early to install and has made a noticeable difference in handling. The car tracks better around turns which is especially noticeable at higher speeds and also has less body roll, presumably because it helps the sway bar work more efficiently.
This was a much more affordable upgrade than aftermarket sway bars with very pleasing benefits. |
03-12-2023, 05:55 PM | #64 | |
Rep 466
https://ultraracing-usa.com/bmw-3-se...ower-2-points/
IG: jpowers36 |
03-12-2023, 08:10 PM | #65 | |
Rep 1,516
03-12-2023, 09:11 PM | #66 |
Rep 378
does https://ultraracing-usa.com/bmw-3-se...trut-2-points/ actually fit the m340ix?
2022 M340 Xdrive, aFe CAI, AA Catted Downpipe, 13mm wheel spacers. 51,000 miles on the odometer
