10-04-2019, 02:41 PM | #46 | |
VIP
41
Rep 151
Life is not measured by the number of breaths you take but by the moments that take your breath away...
10-04-2019, 03:36 PM | #48 | |
Rep 4,856
10-04-2019, 03:59 PM | #49 |
Rep 1,077
You are confused. M340 comes standard with M sport brakes that are 348mm in diameter and fit 18 in h wheels
Optional coolong pack gives you larger 374 mm front rotors so the 18 inch wheels do not fit. Only 19 and up |
10-05-2019, 07:14 PM | #50 | ||
Rep 4,856
10-05-2019, 07:27 PM | #51 |
Law Enforcer
25258
Rep 22,315
Drives: '22 Chalk Gray Porsche C2S
10-06-2019, 10:14 PM | #52 |
Rep 44
In other news, these brakes with stock pads held up just fine during a 2 day HPDE event, with plenty of pad left. Definitely better than the stock brakes in my old '16 340i: I had to replace both front and rear pads after 2 days on the same track. Impressive considering the added power of the M340i.
10-07-2019, 09:43 AM | #53 | |
Rep 1,077
How did the car do in general on the track? |
10-08-2019, 04:30 PM | #54 |
Rep 14,141
Drives: G82 M4C X-Drive
I don't see an oil cooler there, and if there was, it's not getting any airflow.
10-08-2019, 08:49 PM | #55 | |
Rep 1,077
Here is the radiator in US spec car, with self made cover |
10-09-2019, 12:49 AM | #56 |
VIP
41
Rep 151
Hmmm...
The car has larger brakes - picture is made on BMW Experience event on the race track. BTW, this is the picture from German G20 forum, from member who definitely has the M Technology package: https://www.g20-forum.de/index.php?t...3550#post13550
10-24-2019, 06:41 PM | #57 |
Rep 82
In case we need more pix, I just crawled under my US-spec M340i w/ ZTK. Looks exactly like llyam5's pix (w/o the DIY screen, of course).
No protection, other than the 1" rubber air dam in front that you can see in the other pix. I'm not too worried. Above is with 10,000 miles on the car, including plenty of midwestern gravel roads. No signs of any impacts. |
10-24-2019, 06:59 PM | #58 | |
Rep 82
Here's mine, M340i RWD w/ ZTK on its winter setup; BMW-recommended, dealer purchased & installed Pirelli Sottozero's on 18" 796M wheels. Rotor and caliper clearance looks about the same as with the 792M's. 19" 792M's (front) 18" 796M (front) Maybe you'd just need to watch the front size & offset? I noticed the front 796M's are 18x7.5 w/25mm offset, vs 792M 19x8 w/27mm. Rears are closer in specs; 18x8.5/40mm vs 19x8.5/40mm. Last edited by Delta5; 10-24-2019 at 07:13 PM.. |
02-11-2020, 02:45 PM | #59 |
Rep 142
On the BMW website , "build your own", you have the option to select the 19" Non run flat performance tire, with style 792m, for $600. I am assuming you get the "standard" M Sport brake. Do you still get the Michelin PS4's? I really dont want the extra cooling, but do want the Michelins!
02-12-2020, 12:31 PM | #60 | |
Rep 95
04-05-2020, 01:48 AM | #61 |
Rep 43
Drives: 2017 BMW 640d; 2023 X7 M60i
side radiators?
I haven't had my M340i delivered yet, but if the M Technology trans cooler is one radiator sitting horizontally, are the two vertical radiators on either side of the front bumper standard on the 340? or only with Tech pack?
eg https://group1.imgix.net/used-vehicl...&auto=compress |
04-05-2020, 02:07 AM | #62 | |
Rep 14,141
Just watch out for the bigger rocks and avoid what I went through in my F80: IMG_1982 by JMG, on Flickr IMG_1976 by JMG, on Flickr IMG_1970 by JMG, on Flickr Also damaged a laundry list of other parts like the front bumper, front headlights (attached to bumper), steering rack, MPE, rear diff etc... bill: <$30k Probably would have broke $50k if I had let the engine starve itself of oil.
bmwdrive464.00 |
04-05-2020, 03:14 PM | #63 |
Rep 2,007
SO, why did they not ventilate the front rotors? Also, what do you have to spec to get the staggered wheels, tires?
What does that oil cooler weigh? Not the best place to add ANY weight hanging over the front wheels. Can't imagine these cars on the track.... so what is the point? |
04-13-2020, 03:54 PM | #64 |
Rep 1,113
I don't know if this has already been mentioned but S33TA optioned vehicles also come with a 1000W cooling fan as opposed to 850W.
And oil pump An extra heat shield for the steering rack
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 04-13-2020 at 04:22 PM.. |
10-27-2020, 10:45 PM | #65 | |
Rep 171
Standard Brakes M Sports Brakes Performance Brakes The M3 has the Performance brakes and these front brakes that come with the extra coolant pkg look like they maybe closer to the performance brakes. |
10-27-2020, 10:51 PM | #66 | |
Rep 171
