Technical Topics Cosmetic and Lighting Modifications (exterior & interior) vicfalc09 | BMW M Performance Carbon Fiber Mirror Cap Installation
      04-15-2023, 03:07 AM   #45
Tango22
Tango22's Avatar
51
Drives: 2021 M340i Touring
I'm a bit confused reading this topic. The original posters guide states there are a number of screws which need removal in order to remove the mirror caps.
But then the second guide says you pop tabs with a trim tool to remove the caps.
What are the screws for? Why does the second method not require those screws to be removed also? Just asking as there are a number of videos online showing techniques which either need the mirror glass removed, or it simply tilted down to expose the tab clips. But I can't recall reading about a load of screws needing removed?
I have carbon M caps on order so just want to be clear on how the best approach to fitting will be!!
      08-25-2023, 08:41 PM   #46
Conezz
Drives: G20
Originally Posted by NYC_340i View Post
Thanks! I got mine from that link after your suggestion and I just finished installing mine and its soo much nicer than the cerum grey ones which look disgusting the day after washing my car...
I was actually able to do the install in a different way that saved a bunch of steps and completely avoiding taking the glass out.
Props to this guy for showing this method:
Tried my best to take pictures but all I did was first tilt the mirrors all the way down and right (driver) left (passenger). Then I stuck a small slim flathead screwdriver in the gap between the black bezel and the glass and pushed the top tab up and the bottom one down while applying outward pressure with my left hand. Once the top gets release I stuck a pry tool at the bottom corner next to the camera and pried it out. Got the passenger side cap off without breaking any clips and I just broke one clip on driver side. Super easy and took me 10 minutes to do each side.
I know this thread is old, but are you saying that by dislodging those clips that the mirror cap comes off without have to remove the screws?
      08-26-2023, 01:26 PM   #47
Conezz
Drives: G20
Interested to hear this as well. What did you find out?
      09-07-2023, 01:21 PM   #48
Whack01
Whack01's Avatar
22
Drives: G20 330i
I just did this today. The 4 screws release the black trim/surround at the front of your mirror. By removing them I found it much easier to release the 2 tabs shown in above post. You don’t need to remove the black trim just the screws. The second set of 2 screws need to be removed as these fix the indicator to mirror cap.
I can only please one person per day.
Today is NOT your day....
...Tomorrow doesn't look good either!
      11-21-2023, 01:00 AM   #49
Lain
Drives: 21' M340i
Originally Posted by PortimaoMystique View Post
I've contacted the eBay dealer and can hopefully get a replacement
Did you ever end up getting a replacement? I got myself a pair from the same seller and the fitment is pretty bad...
      11-18-2024, 04:09 PM   #50
a_babyking3
a_babyking3 's Avatar
Drives: 2021 bmw 330i
I got these m style mirror caps for my 2021 330i, the left side is clipped in perfectly but the right side is giving me issues I tried pushing it in to clip but it’s not even moving anymore and the mirror cap is just stuck in the same position with a little gap. Does anyone know what I can do to make it fit?
