View Poll Results: Does your G20 require constant small steering corrections to drive in a straight line | |||
Yes, I have noticed this issue. | 59 | 32.60% | |
No, the car requires little to no steering input in a straight line at highway speeds | 122 | 67.40% | |
Voters: 181. You may not vote on this poll |
07-16-2022, 09:09 AM | #45 | |
Rep 1,814
The X3's when misaligned also exhibit the same issue - https://x3.xbimmers.com/forums/showthread.php?t=1937763 Which would make sense given they are the same platform. |
07-16-2022, 12:08 PM | #46 |
Rep 300
Yes, it is based on my own experience. That's the only evidence I have. But what GWIZ experienced, even after alignment, is what I experienced. My alignment was checked twice - and they said it's perfect. Maybe they were wrong; I don't know for sure. But there is this manifest dead spot on center that allows the car to drift - ever so slightly - requiring contact micro corrections. It really only took a toll me over long trips.
07-16-2022, 04:00 PM | #47 |
Rep 4,073
Drives: 2020 M2C, 2019 330xi, 2017 Q7
In my 2019 330xi, I have noticed that the return to center is not as "automatic" as it is in my other BMWs of the past 20 years. Something is certainly different. The steering wheel needs to be returned to center manually, more so than other BMWs
07-16-2022, 08:34 PM | #48 |
Rep 300
Bigkutta, some people say it can be fixed with an alignment and have posted their alignment specs on this forum - so take a look at that.
My issue was exactly what this reviewer described starting at 22:35, and my dealership was never able to correct it. https://g20.bimmerpost.com/forums/sh....php?t=1774603 |
BigKutta3945.00 |
07-18-2022, 12:37 AM | #49 |
Rep 98
Steering Update: Seeking Advice
Attached is the spec sheet for the alignment I had done prior to my recent trip. I first contacted two different BMW repair shops in Dallas (not dealers) and mentioned zeroing out the toe adjustment. Each shop's reply: "We align per BMW specs." End of conversation. There are five dealers in the DFW area. I spoke with three that weren't interested in making adjustments that weren't to BMW spec. The dealer where I purchased the car (at least the service tech that went on a drive with me) offered only justifications but no solutions. I had the alignment done at at the remaining dealer where I've received quality service/work over the years. We discussed the issue in detail. They said they'd look into the toe adjustment with additional scrutiny. What resulted is the spec sheet shown. Result: steering issue unchanged.
I'm willing to try an alignment once more. My question: Given the specs shown, what specifically do I need to tell the next service tech/mechanic to do so that I arrive at the same solution as jg4c and Montaver? |
07-18-2022, 07:03 AM | #50 | |
Rep 1,814
07-18-2022, 11:55 AM | #51 |
Rep 98
I am truly a lay person when it comes to alignments... Do the current specs indicate the wheels are toe in?
07-18-2022, 01:45 PM | #52 |
drives cars
272
Rep 350
Drives: '23 IS 500, '23 X3
Positive toe = toe in, negative toe = toe out. So, yes.
2023 BMW X3 | Phytonic Blue | Black Vernasca Leather | Dark Wood Trim 2023 Lexus IS 500 F Sport Performance | Infrared | Black NuLuxe |
07-18-2022, 07:33 PM | #53 |
Rep 98
Thanks. According to Montaver these specs should remedy the issue being discussed. Unfortunately, this is not the case with my car. Short of a different solution, I'll have to decide on a new course of action.
Per Montaver's poll, a growing percentage of owners (now 32%) have reported experiencing this steering issue, a 5% increase since I took the poll about a month ago. I understand the difficulties in making reliable inferences from such informal research; nonetheless, a poll is a poll and I am intrigued by the number of those reporting this issue. If, say, only 3% of respondents had confirmed a problem, I'd think that perhaps I bought a lemon or had a hardware/software malfunction. But at 32% (as of this writing), the percentage of forum members affected by this issue seems rather high to me. If not caused by the tires or alignment, then the problem I'm experiencing with my car is, I assume, a design feature or some other yet undiagnosed part or process that is in need of redesign or recalibration. Last edited by GWIZ; 07-19-2022 at 05:01 PM.. Reason: updated poll stat |
07-18-2022, 08:06 PM | #54 |
Rep 300
Good luck. I'd say discard the poll. If your brand new car is experiencing this kind of an issue that can't be easily fixed, then stop trying to fix it. Contact BMW NA and ask for a regional rep.
If you are willing to get into another new BMW they may very well accommodate you without much (if any) loss on your 3 series trade. (From what I've read the constant micro correction steering issue, is limited to the 3 series - 330 and 340.) If you are not willing to get into another BMW, they probably won't be receptive and you may be left with having to pursue a lemon law claim which can take a long time. Show or email the rep this video and focus on 22:35 forward. https://g20.bimmerpost.com/forums/sh....php?t=1774603 |
07-18-2022, 10:16 PM | #55 | |
Rep 98
It was unfortunate that at the time I purchased this 330ix, no dealers in the DFW area had one on the lot for a test drive, so I custom-ordered, the same with my 230i. Had a test drive revealed this issue, I am quite certain I would have looked at different models. At any rate, this is where I'm at now. |
07-25-2022, 11:21 AM | #56 |
Rep 648
Drives: Little of this, little of that
BLUF
BMW engineered the steering to lessen the "Numb" feel when you make a car that checks all of the boxes. Result: Artificially improved performance handling. Downside: Some people, a certain percentage of the population, have a hard time adjusting to it. Why? NFI. Why does cant my wife tell the difference between HD and 4K? Why are some people sensitive to fluorescent light while it does not bother others? You can counter some of this with an alignment, better tires and drive mode adjustments but it will never 100% go away. There is a common theme with the people experiencing this, why it occurs for some, not others. Perhaps some data scientist or someone really fucking bored can put together all of the common facts and data points, spelling out the problem. Until that time, the only REAL solution is to Test Drive. Not 5 min around the block, real world your test drive. I certainly would not fork over 50-100k plus on ANYTHING that I did not 100% know I liked and fit my use case. Don't think for a second I didn't fuck that rule up. I ordered a 2018 Infinti Q50 Red Sport AWD without testing all the options because I "had one before" . Steer By wire. You all think your steering sucks....you have no idea how bad it could really be. vr
"It's not how fast you go, it's how you go fast"
springerdrive290.50 |
08-12-2022, 08:48 PM | #57 |
Rep 98
More common facts and data points would certainly help to understand this problem better. I see it is being discussed in the BMW X3 (G01) / X4 (G02) Forum as well https://x3.xbimmers.com/forums/showthread.php?t=1937763. If you are aware of it being discussed elsewhere -- other car forums, car reviews, etc., please share.
08-13-2022, 04:55 AM | #58 | |
Rep 15,857
What the cause and where the solution lay, BMW haven't got there yet. Alignments sort some examples, does this offload the rack? Taking away sensitivity, or add to it, to give a solution? Is it software? Steering torque sensor too wide a calibration, or over sensitive? Who knows? We have an example of a user who has swapped from a bad G20 to a good G01. Now rid of the issue. With what we are reading, we could as easily move from a good G20 to a bad G01. I've got a good 'steering' example of an F11. I did have to slightly adjust the steering wheel position to bring it altogether for optimum precision. Over the years we've had similar discussions from F10/11 users with poor steering, vague on-center, wandering and pull. Some users never got an acceptable solution, even with BMW involved. Other users did get improvements with alignments, component changes and/or adjustments. |
10-21-2022, 02:47 AM | #59 | |
Rep 1
10-21-2022, 05:58 AM | #60 |
Rep 815
Just had mine on the highway for about 6 hours last week and didn't notice anything like this. Then again, my other vehicle is a lifted Jeep that floats so much it's terrifying over 70mph.
10-21-2022, 10:30 AM | #61 |
Rep 1,067
No issues- in fact over the course of the 3 years i had the car i had the opposite problem- That annoying dead spot on center where you move the wheel left and right and nothing happens.
2019 G20 330i RWD
2014 F30 328i RWD 2009 E90 328i RWD 2006 E90 330i RWD 2002 E46 330i RWD |
11-09-2022, 03:11 PM | #62 |
Rep 6
Hello,
I have all these problems as mentioned above. So, maybe anyone have it solved? I also need do the micro adjustments at highways, also the steering wheel is quite heavy and it is difficult to change the lanes |
12-30-2022, 12:57 PM | #63 |
Rep 7
same problem, 330D, RWD, made 10/20, m sport not active suspension, 225+25519" bridgestone turanza rft, all steering intervention off all the time
wheel alignement did not help a lot, tried twice (bmw and workshop) finally went for eibach springs, improvement +60 to 70%, but still scared to drive faster than 220kmh, before eibach bearable limit was 170kmh before buing car i tested 320d xdrive from bmw dealership, extremely unstable, and 330ix with active m suspension, was ok Last edited by hellbivoy; 12-30-2022 at 01:02 PM.. |
12-30-2022, 03:38 PM | #64 |
Rep 300
Good luck!!!
FYI - these links: This reviewer describes it best at 22:35 of the video https://g20.bimmerpost.com/forums/sh....php?t=1774603 At 22:35 of the video This thread: https://g20.bimmerpost.com/forums/sh....php?t=1865372 And this thread. https://g20.bimmerpost.com/forums/sh....php?t=1855230[/QUOTE] |
07-08-2023, 01:17 AM | #65 |
Rep 17
Hi, as I mentioned in another thread,
I recently got a certified 2020 330i but I feel like I'm driving "the ultimate driving boat" in the highway as it drifts, floats, wanders and never settles. I took it to an independent shop for alignment. I'm not sure, but I feel it got better for a short period of time but it's bad again. Maybe going over a pot hole ruined the alignment or something. Attached are my alignment specs. First time that they aligned the car, the steering wound't center so I had them to do it again. I'm taking it to the BMW dealer that sold me the car to check, but I don't have high hopes for a fix. |
07-08-2023, 07:26 AM | #66 |
Rep 300
99.9% it has nothing at all to do with the alignment, tires, balancing or pressure.
It’s the way the steering was engineered. Most get used to it. |
