03-07-2023, 05:32 PM | #45 |
Rep 570
boostboy2357.00 |
03-07-2023, 06:25 PM | #46 | ||
Car'a'carn
473
Rep 751
vitipr171.00 |
03-07-2023, 06:29 PM | #47 |
Rep 2,700
What I wanted to say was more that the "best clutch solution" hasn't been found yet. I saw this on other platforms, it sometimes took years for a company to come up with a model that was spot on. Surface material and finger design/tension have a huge impact on feel.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
curtdragon473.00 |
03-07-2023, 06:36 PM | #48 | |
Car'a'carn
473
Rep 751
03-07-2023, 06:46 PM | #49 | |
Rep 744
Clearly clutchmaster didn't put enough time/money into development before selling these clutchs for this platform. Customers are paying for it. |
PLF693771.50 |
03-08-2023, 09:54 AM | #50 |
mTekMods
2169
Rep 2,922
if this is still a version of the gs6-53 gearbox architecture its possible to use a concentric hydraulic slave cylinder. in motorsport with this gearbox when moving to a twin and triple plate non self adjusting clutch you can adapt a concentric slave cylinder with a mounting ring inside the bellhousing. it should provide the right amount of release movement. bmw used to make the part oem its 21517750966 and the ring is 21518321627.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
PLF693771.50 |
03-08-2023, 12:08 PM | #51 |
Rep 570
Is this MT the same one from the f8x gen? I thought I read somewhere it was.
Long shot and I doubt it, but I wonder if any of the upgraded clutch options for the f8x will bolt right up. |
03-09-2023, 09:53 AM | #52 | |
Rep 35
03-09-2023, 11:38 AM | #53 | |
Rep 190
Keeping an eye on this thread as I want a G80 MT in the future.
:::: 2017 AW M2 :::: (SOLD)
03-09-2023, 06:54 PM | #54 |
mTekMods
2169
Rep 2,922
You need to have the gearbox pulled back out and figure out what is actually happening. Obviously you don’t want to fix the problem is it’s clutchmasters problem but you need to start by measuring the clutch stack height compared to the oem your problem may be there. How much heavier is the pedal with this? If the g80 is using a plastic slave cylinder I switched Over to a older style metal slave cylinder with my twin disc on my older m3 and it solved an issue I was Having with a really funky clutch engagement. I know You don’t want to have to reverse engineer this but you’re already involved and in the hole at this point.
PLF693771.50 |
03-09-2023, 10:40 PM | #55 |
Beware of cheap bait!
714
Rep 715
Could you pull the slave for me and check the free play of the clutch fork? Do you know what orientation the throwout bearing was installed in? If the free play of the throwout is more than say a quarter inch it is way too much. The throwout bearing in the car from the factory is of a single position type in the "low" position. The unit that comes with the clutchmaster kits is of the dual position type which has a low and a high position. Unlike the factory setup, the new unit requires the throwout bearing at the high position because the stack up height is much shorter than that of the OEM clutch and flywheel.
I had personally lost my documentation for the installation of the FX350 and found that clutchmasters support gave me the wrong information, in using the throwout bearing at the "low" position mirroring the OEM setup, requiring me to remove the transmission again and put the throwout bearing in the correct setting. The car was slipping the clutch and not disengaging fully, as the slave was running out of stroke before the pedal even hit the floor. The pedal also felt extremely funny. Never getting that over center feeling you get with a correctly operating pressure plate. Best way I can describe it is a brake pedal with some air in it. The easiest way I found to check this was to remove the two bolts on the slave cylinder and see how far the helper spring pushes the slave cylinder out of the transmission. If the throwout bearing at the incorrect orientation it will only push itself out about half way. The correct way will push it out of the trans most of the way and be a huge fight to get back in. The other method will be be measuring the position of the clutch fork relative to the mounting flange of the slave on the bellhousing. I should have that measurement tomorrow night. Let me say it this way, it's not an issue with the slave cylinder. If somebody is inexperienced with the BMW tilting clutch fork and the older two stage throwout bearing it's easy to understand why this error occured. You'd completely expect the throwout bearing would go in the exact same height as it came out. Sorry about the word salad boys and girls. |
PLF693771.50 |
03-09-2023, 10:53 PM | #56 | |
Rep 35
I am not a mechanic and all of this has taken a lot of my time. I’m done with clutch masters at this point I am moving on and just going to wait for something better. I am not supposed to be doing any of this. Waiting for a refund at this point. |
03-13-2023, 07:31 AM | #57 | |
Save the manual
65
Rep 84
So the throw out bearing that comes with FX350 has two settings? And it needs to be adjusted to high setting rather than the OEM like , low setting? Did you try this and did it work ? |
03-13-2023, 07:48 AM | #58 |
Save the manual
65
Rep 84
Here is the best part about clutchmaster’s website. I posted a review for FX350 and it won’t even show up on their website….. fellow G8X manuals, buyer be aware.
I wish I saw this forum before pulling the trigger and buying the clutch master’s product. DO NOT WASTE YOUR MONEY. This has not been properly tested before releasing it to public. The fact that we have reverse engineer their product to figure out what’s wrong with the throw-out bearing or the clutch it self where the clutch doesn’t actually disengage, is really bad |
Tall Tom Cruise1013.50 |
03-13-2023, 07:51 AM | #59 |
Rep 35
[QUOTE="kaveh_h;29930299"]Here is the best part about clutchmaster’s website. I posted a review for FX350 and it won’t even show up on their website….. fellow G8X manuals, buyer be aware.
I wish I saw this forum before pulling the trigger and buying the clutch master’s product. DO NOT WASTE YOUR MONEY. This has not been properly tested before releasing it to public. The fact that we have reverse engineer their product to figure out what’s wrong with the throw-out bearing or the clutch it self where the clutch doesn’t actually disengage, is really bad Nothing works the clutch don’t fit the car |
03-13-2023, 08:09 AM | #61 |
Save the manual
65
Rep 84
Btw does anyone know if the OEM BMW F10 M5 pressure plate and clutch will work with the stock flywheel for the G8X ? that clutch is designed to handle 575 hp and over 550lbs of tq.
03-13-2023, 08:11 AM | #62 | |
Save the manual
65
Rep 84
Sorry, do you mean it works fine after you change the "settings" for the throw-out bearing to high? I am trying to understand you correctly so that if it is in fact a setting within the CM FX350's throw-out bearing, ill have the dealership pull the gearbox back and adjust it to high setting. |
03-13-2023, 08:14 AM | #63 | |
Rep 35
One of the shops I used to try figuring this out said that all of these clutches don’t fit but the end user might not know it. Can you share a video of your engagement into first off a stop? |
03-13-2023, 08:15 AM | #64 | |
Rep 35
It’s supposed to be on high setting |
03-13-2023, 08:35 AM | #65 |
Save the manual
65
Rep 84
So it's adjustable manually? I'll admit that I never looked at it and I basically handed the entire kit to the tech at BMW .... if it is adjustable then ill have them pull the gearbox back and make sure it is on high setting.
