01-04-2025, 02:10 PM | #45 |
Rep 16
Thank you! You must have been posting this when I was replying to another message. Just popped up on refresh. I'll give your file a look and compare how I can improve or change mine to perform better. Hoping to learn from your configuration for future reference.
You're also welcome to the files in there although they are for the G30 and aren't configured for having the MEC installed. They are mostly the base tunes provided to me, except the ones with modified in the name. |
RCM7857.00 |
01-09-2025, 03:38 PM | #46 |
Rep 25
What under-seat subs are recommended to use along with the AlphaOne amp/dsp? Just installed the amp and working on tuning but I’m quickly learning the BMW HK subs just won’t do it. I’d rather not go with a box in the truck, just keep things located where they are. Any input is appreciated
01-09-2025, 08:26 PM | #47 | |
Rep 16
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
I800C0LLECT228.50 |
01-09-2025, 08:35 PM | #48 | |
Rep 282
snekjumpr111.00 |
01-11-2025, 01:38 PM | #50 | |
Rep 55
Drives: 2021 M440i X-Drive
These Helix shallow subs are direct replacements with the correct adapter. They will provide a huge improvement over the factory subs. https://www.audiotec-fischer.de/en/h.../ci5-s200fm-s2 |
01-11-2025, 02:34 PM | #51 |
Rep 282
I don't have any distortion plots but I can get them pretty crispy. I know the rear speakers get very distorted though. I have the system balance all the way forward. Mine are 50Hz to 200Hz with 24dB slopes
snekjumpr111.00 |
01-11-2025, 10:10 PM | #52 | |
Rep 135
01-11-2025, 11:12 PM | #53 |
Rep 55
The 4 series has less room under the seats than the 3.
I bought these adapters https://www.ebay.com/itm/18608836934...mis&media=COPY Installed them upside down and they worked. Problem is getting the factory grills back on. The TM8’s sit too high to clear the grill. They sound fantastic though. |
I800C0LLECT228.50 m440i80452.50 |
01-12-2025, 12:06 AM | #54 | |
Rep 117
The upside-down installation is a good idea. The woofer is out of the box. Do these adapters fit the factory screw locations? Is the assembly well sealed? |
m440i80452.50 |
01-12-2025, 01:19 PM | #55 | |
Rep 55
The adapter fits perfectly. Just drill pilot holes to avoid splitting the MDF. I also cut soundskinz to serve as gaskets below the adapter and under the speaker flange. I have zero resonance from the under seat speakers. |
