Technical Topics Wheels and Tires Wheel Spacers
      02-21-2021, 05:15 PM   #67
ultrared93
Drives: '21 M340ix '93 300zxTT QX30
Originally Posted by njfoses View Post
You can fit any 245 tire on an 8" rim. Whether you like the look or not is a different question.
Yep, Michelin lists rim width for both AS3+ and PS4S in 245/35x19 as min of 8", max of 9.5".
      02-22-2021, 11:55 AM   #68
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
From the images you shared I like it.
Curious about brand of tire tho because each are a few cm/mm wider/skinnier depending on brand. 245 isn’t always 245
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      02-28-2021, 10:08 PM   #69
M340Brizzy
Drives: 2021 Bmw M340i xdrive
Exclamation new guy in the house!
new guy here making my first post. looking for info on anyone running a square set up. got my 21 M340i xdrive arriving at the end of the month! Im unsure if i should go with the BMS 13mm all around or 15mm. The cars coming with the style 792m 19x8.0 in cerum gray.
Brizzy
      03-11-2021, 04:30 AM   #70
franky818
Drives: e90 2010 , g20 2020
I need spacers I was thinking 10 in front and 12 in back ... what u guys think? I'm lowered on h&r springs
VipinLJ1950.50
      03-11-2021, 06:16 AM   #71
njfoses
Drives: 20 M850i, 22 X6 M50i
Assuming you are not running a staggered setup, my vote would be 12mm or even 15mm all around.
      03-13-2021, 08:42 AM   #72
Newyen
Newyen's Avatar
Drives: 2021 M340i
Originally Posted by Brett240 View Post
standard,
with the Burger 10mm front and 13mm rear
What's up Brett! I just went with the same setup as you, and also went Burger. No vibration or rubbing which is great. Feels a little more "controlled" than stock. I like to run my car aggressive from time to time. Possibly like to take it to the drag strip in the near future.
Question is, have you had any issues since your 10/13mm Burger setup? I'm kind of apprehensive on launching the car now, from a safety perspective. I guess I've watched too many YouTube videos where the tires falls off during a drag race. 🤣
Thanks man!
      03-13-2021, 08:57 AM   #73
Newyen
Newyen's Avatar
Drives: 2021 M340i
As a matter of fact, has anyone run into any issues driving aggressively with their spacers? I'm running 10mm front and 13 in back. Thanks in advance!
Thanks to X-PH for the quick delivery and flawless transaction! mike@x-ph.com
      03-16-2021, 09:04 PM   #74
RedKloud
RedKloud's Avatar
741
Drives: BMW i4 M50
12.5F / 15R
///Mobbin1478.00
      04-21-2021, 11:35 PM   #75
purplehearttags
Drives: bmw m340i xdrive
Lowered and spacers
Recently purchased some h&r lowering springs What's y'all's thoughts on running 15mm spacers in the front and rear I have a staggered setup
      04-22-2021, 02:27 AM   #76
franky818
H&r springs
Future classic 12mm front 15mm back
      04-22-2021, 02:30 AM   #77
franky818
I would probably go 15mms infront too if I could go back instead of doing 12mm
      05-10-2021, 10:09 AM   #78
R12ax7
R12ax7's Avatar
120
Drives: 2021 340xi
2011 328i  [0.00]
Originally Posted by RedKloud View Post
12.5F / 15R
These look perfect to me - are you running the square or staggered wheels?
Does anyone know if BMS spacers for an e90 or f30 will work on the g20? I know e90/f30 were interchangeable.
Current: 2021 340xi
Retired:
2018 330xi | 2016 340i 6MT | 2013 335i 6MT |
2011 328i 6MT (N52) | 2008 335xi (N54)
      05-10-2021, 10:54 AM   #79
chenry
Drives: BMWs
12.5F / 15R
Different bolt pattern they will not work
      05-10-2021, 06:07 PM   #80
RedKloud
RedKloud's Avatar
741
Drives: BMW i4 M50
12.5F / 15R
Staggered.
      05-17-2021, 12:06 PM   #81
Punkwrock
Punkwrock's Avatar
Drives: 2020 BMW M340i-X
I just got my Burger Motorsport 13MM spacers installed all around. Square tire setup of 225/40/19. I find these are perfect and for my car I wouldn't go any thicker.
      05-17-2021, 03:47 PM   #82
GD1981
Drives: 2021 BMW M340i
ECS 12.5mm all around + staggered stock wheels wrapped with PS4’s + Dinan Springs (and Handling kit)
Appreciate 7
      06-04-2021, 12:01 AM   #83
TKGT81
Drives: BMW G20 330i
Am looking at this set locally
https://modeautoconcepts.com/product...-330i-340i-g20
Interesting that for the 'flush' look, they suggest 15mm front and 12.5mm rear, whereas others say the other way around. Anyone comment on 15mm front and 12.5mm rear?
      06-04-2021, 06:39 AM   #84
njfoses
Are you looking to be flush front and rear equally, or more aggressive in the rear? Stock rims or aftermarket? If stock, staggered setup or square? If aftermarket, size/offset? Tire size?
Answering those questions will help with recommendations.
      06-04-2021, 06:51 AM   #85
TKGT81
Good question! They are the stock 19 inch 791m m sport wheels that came with the car. Looking for the flush look, not planning to have a staggered setup and not looking to do anything other than drop the car with the eibach pro kit.
      06-04-2021, 12:07 PM   #86
njfoses
I believe by default the m-sport trim comes with 8.5" wheels in the back and 8" up front. If that is the case i would go 15 all around. The rears will be a tiny bit further out than the fronts, but hard to notice, and would look good.
TKGT8112.00
      06-04-2021, 07:43 PM   #87
TKGT81
Thanks! Booked in next week to get the eibach springs installed. Will play around with options when there. I agree though that 15mm in rear would look better. Will decide what I do with front
      06-09-2021, 04:07 AM   #88
TKGT81
Update: After trying a couple of options, the 15mm front and 12.5mm rear actually worked really well to get the flush look. Mechanic said 15mm in the rear stuck out a little too far. Also had the Eibach pro kit installed. Very happy with outcome
Appreciate 8
