03-20-2022, 08:47 PM | #1013 |
Rep 7,539
Would ruin ferrari's chance at a constructors championship though, because the way max operates the whole team has to be based around him and pretty much screw the second driver and what they need. It would win drivers championships but probably not constructors because the second driver would be struggling.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
minn1914078.00 Killed by Death13191.00 |
03-20-2022, 08:52 PM | #1014 |
Rep 10,084
03-20-2022, 09:27 PM | #1015 |
Rep 7,539
Here's some more data from f1 technical about the engine difference between ferrari, merc, and rb:
Trap speeds aside we also have to remember each team is using different gear ratios, merc uses the shortest gear ratio, followed by ferrari, and then redbull. So technically merc should accelerate fastest, then ferrari and redbull the slowest while top speed should have redbull the fastest, ferrari in the middle then merc the slowest. It's hard to tell from the traces but speeds are very close, merc is not accelerating that fast vs. the other two and in places slower. Redbull keeping up with the ferrari quite well to despite the longer gears. Overall pretty similar traces but merc is behind a bit in some areas, I heard it could be because they had to run more wing to compensate for the increased ride height and the resulting loss in downforce. But so far it is really hard to tell where the w13 stands with how many issues they're facing along with traction issues. To judge a pu based on how powerful it is we should look at acceleration and intermediate trap speeds out of a corner (where drag hasn't become a factor yet). To determine "jet mode unraceable speed" that is peak trap speed. But to summarize it is really really hard to make a determination if the merc engine is behind as of right now, still too many factors at play between how many issues the merc faces and the limited data we have as a result. I still don't think the merc engine is too far behind, I think it is a chassis related issue that results in poorer cornering speeds, poor traction which means poor acceleration, and the higher drag setup they have to run to compensate. We will see soon, maybe merc has the worse engine, maybe they don't, myabe they still have the best engine I can't tell yet. But I can see ferrari and redbull are at the top, and it really does look like the redbull is the faster car in the straights right now.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 03-20-2022 at 09:42 PM.. |
Artemis30014.00 |
03-20-2022, 10:35 PM | #1016 | |
Moderator
30014
Rep 13,167
OK, driving any F1 car is very demanding and F1 drivers are athletes spending lots of time on working out. But it looks as if the current Merc W13 package (even when tweaked to reduce the 'porpoising effect') is not as 'comfortable' (or for the sake of better description: is 'more uncomfortable') than it used to be in 2021; for the time being it's a tougher work place, harder to drive. I don't know, but maybe statistics of HAM and RUS progressively losing ground vis-à-vis the Ferrari and Red Bull cars until the safety car stage kicked in (resulting from the GAS car retirement) partially reflect this.
///M is art ↔ Artemis
03-20-2022, 10:38 PM | #1017 | |
Rep 7,539
Artemis30014.00 |
03-20-2022, 11:54 PM | #1018 | ||
Rep 3,245
03-21-2022, 12:04 AM | #1019 | |
Rep 7,539
we will know more in the coming days.
Bubbles2756.50 |
03-21-2022, 12:09 AM | #1020 | |
Rep 3,245
03-21-2022, 12:13 AM | #1021 |
Rep 7,539
Seems like it. I have no idea why redbull didn't check it, other rumours were they didn't test long enough distances during testing so they never had these issues while other teams spotted it and learned to inspect. Again more speculation, but i'm sure redbull will never let this happen again. It is crazy how fast the e10 fuel eats through this resin.
03-21-2022, 12:22 AM | #1022 |
Rep 4,445
Italian-made Spec part caused RBR failures
Looks like the spec fuel pump part failed due to the E10 fuel, mclaren experienced this failure in qualifying and was allowed to swap in new pumps because it is a spec part (used by all teams). FIA checked all cars in part ferme for this issue and did not allow RBR to change the failing part because the data was inconclusive. Other teams were allowed to change the part.
Interestingly, if the spec part caused the ICE to fail should it count against RBR PU allowance? Bad luck, but it explains the RBR performance.
M5Rick61811.50 ///M Power-Belgium64695.00 |
03-21-2022, 12:27 AM | #1023 | |
Rep 7,539
But IMO if this part causes RB's engine to fail they should not be penalized for it, because it wasn't even their part. But we will see.
Bubbles2756.50 |
03-21-2022, 01:24 AM | #1024 | |
Rep 3,245
03-21-2022, 02:21 AM | #1025 |
Rep 7,539
Ok so far what I have gathered is the race's analysis which I initially quoted post race, is wrong, they thought redbull suffered from pump cavitation.
So far it is concluded that redbull's pump failed due to e85 eating through the resin case of the pump controller. The contention still lies in the two scenarios in hearing, one is redbull didn't opt to change the controller, the other was redbull wasn't allowed to do a swap. Not sure what the case is yet. Another thing I'm hearing is redbull is having braking issues like McLaren.
03-21-2022, 02:59 AM | #1026 | |
General
61812
Rep 19,963
03-21-2022, 03:21 AM | #1027 | |
General
61812
Rep 19,963
03-21-2022, 04:12 AM | #1028 | |
Rep 7,539
1) ethanol is a powerful solvent, and it dries out materials extremely quickly causing cracking and eventually material failure. This is why on street cars, when the government started mandating E10 fuels, car companies moved from rubber fuel lines which were susceptible to damage from ethanol to PTFE based lines which are not effected by this. Injectors and pumps need to also be able to deal with the solvent nature of ethanol which robs some lubricity from the gasoline. This is why cars running E85 have to switch to gasoline every few tanks to ensure injectors don't stick (unless you run full e85 tolerant fuelling components, or run a top cylinder lube). 2) Ethanol is hygroscopic meaning it absorbs water from the atmosphere, it then forms acidic components which damages metal and "eats" through things. This is why on modern cars again the fuel lines are made of PTFE and fuel injectors, fuel pumps etc are also made to be able to tolerate the use of ethanol. So these two factors combined likely damage the fuel pump electronic casing, which probably wasn't designed to tolerate ethanol. We will know more when redbull or f1 releases more info, but this is my guess on why ethanol is wreaking so much havoc based on what ethanol does to street cars.
M5Rick61811.50 |
03-21-2022, 04:36 AM | #1029 | |
General
61812
Rep 19,963
03-21-2022, 04:58 AM | #1030 | |
Rep 7,539
So this is the bare minimum f1 can do to try and stay somewhat relevant and entice constructors to join.
MontyB11428.00 |
03-21-2022, 05:30 AM | #1031 | |
General
61812
Rep 19,963
03-21-2022, 06:59 AM | #1032 |
Rep 1,820
Doesn't seem to be the spec supplied part that was an issue in the fuel system for RB, but the exact cause is still a mystery. Not long to find out what it was and if its a big or small fix on a back to back fly away race however.
https://www.motorsport.com/f1/news/w...ilure/9188330/ |
03-21-2022, 07:27 AM | #1033 |
General
61812
Rep 19,963
They're not sure yet but the fia supplied pump is the main suspect to do with the acidic ethanol fuel.
03-21-2022, 07:29 AM | #1034 | ||
Rep 3,997
All teams in Q3 had the opportunity to inspect over night. Quote:
minn1914078.00 |
