Technical Topics DIYs and Coding Discussions MGU expert mode in IOS Beta BimmerCode!
      06-21-2020, 12:23 AM   #89
Chevychong
Drives: BMW 330i G20
Finally got it,Thank you so much.
      06-21-2020, 01:30 AM   #90
VipinLJ
VipinLJ's Avatar
You’re welcome!
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      07-18-2020, 05:47 PM   #91
Gregus330i
Gregus330i's Avatar
99
Drives: BMW 330i M Sport
Well, you guys are very lucky with your G20's. There must be some differences to my F40. I've just coded Sport Plus on my F40 m135i and it's EXACTLY the same as sport - in all transmission settings. Also coded Comfort Plus then thought how does that work if there's no menu for comfort, it's just the one single setting.
Sport Plus on my idrive shows under transmission and engine sound - But in engine sound it's not going to improve anything because in Sport, the exhaust valve is open and in comfort the valve is closed - so what would sport plus do regarding engine sound? Absolutely nothing. Same goes for sport plus in transmission setting - it's exactly the same as sport. I usually use comfort transmission under sport individual for a nice fairly sharp daily drive. Better than comfort which is quite lazy and sport which is a bit too sharp for town driving & traffic. Maybe I should have kept my 330i!
      08-11-2020, 09:56 AM   #92
digitallust
digitallust's Avatar
Drives: 2019 G20 BMW 330i M-Sport
Just wondering if there is any coding out there in expert mode for front fog lights to remember last setting, or always on?
      08-25-2020, 03:07 PM   #93
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
I coded with Bimmercode to have fog lights on with both parking lights and high beams on my G20.
      08-28-2020, 07:11 AM   #94
kas206
Drives: Bmw 135i
Anyone using bimmercode with a Enet cable? I just bought a type C to Ethernet adapter and a Enet cable but I'm unable to connect to the car using an Oneplus phone. Any ideas?
      08-28-2020, 07:56 AM   #95
Heliot077
Drives: BMW G21
I use it with an adapter on my iphone...without any problems.
      08-28-2020, 08:13 AM   #96
kas206
Drives: Bmw 135i
I'm unable to connect at all. Which option do you choose from the adaptor settings?
I chose ENET cable and it gives me this error "please enable WiFi and connect your android to the OBD adapter WiFi network"
      08-28-2020, 09:56 AM   #97
VipinLJ
VipinLJ's Avatar
Which android phone is it? To use the enet cable on an android phone, you need to enable static IP and stuff.
Settings to use enet cable with BC on android
      08-28-2020, 11:04 AM   #98
kas206
Drives: Bmw 135i
Looks like that could be the problem. It seems like I'm unable to manually assign a IP address and it's getting one automatically.
I'm using a Oneplus 8. I did a quick Google search and it seems I'm unable to manually set an IP address. It's not available as a feature in the OS.
I guess I'll have to use another phone.
      08-28-2020, 12:27 PM   #99
VipinLJ
VipinLJ's Avatar
Yes. I had a one plus 6t and that wouldn't even recognize an ethernet connection. Went back to Samsung and all is well again.
      08-28-2020, 01:26 PM   #100
kas206
Drives: Bmw 135i
So the only way would be to sign into my Google account on a Samsung phone and redownload the app? Or is there another way?
      08-28-2020, 01:37 PM   #101
VipinLJ
VipinLJ's Avatar
Yes. Thats the only way I believe.
      08-28-2020, 01:39 PM   #102
kas206
Drives: Bmw 135i
      08-28-2020, 05:06 PM   #103
kas206
Drives: Bmw 135i
Managed to code comfort plus using the wife's Samsung phone using this method, Plugged the adaptor into the phone and instantly showed settings for IP address, changed the IP address, pressed connect and voilà!
Using a Enet cable is soo much faster than using a Bluetooth adapter.
      08-28-2020, 09:59 PM   #104
New2a430i
Drives: BMW 2021 M440i xDrive
Hey @mikeyb74, can you describe your path to do this? Thanks.
      10-16-2020, 02:54 PM   #105
BLG19
Drives: 2008 E82 135i
Does anyone know if you can change the default fonts to the M fonts instead of the switching the entire instrument cluster to the M layout? I like the fonts a lot, but rather be on the default cluster layout.
I'm not sure if its an option in Expert mode or not.
      11-06-2020, 02:07 PM   #106
thelmers
Netherlands
Drives: BMW M340i xDrive Touring
Originally Posted by xRingo94 View Post
Is it possible to have the M cluster, with my "M340i" logo and rpm like the b58 (7000 and not 8000)?
Just set is back to BMW cluster and then only change the following.
DKOMBI -> ag_mpa_msp_view -> mpa_ansicht_330_skala
You’ll have everything original, but only 200 mph on the dash.
      10-06-2023, 11:00 AM   #107
Tinted1
Drives: BMW x7, bmw x3
Lost communication to head unit
I too was coding all type of stuff in expert mode and one thing I clicked was the operating version from 2018 that was marked aktive to 2021 and after coding the screen went blank and says no communication to head unit module. Can anyone help? I’ve tried resets, battery reset, holding knob, BimmerCode backup tried, took it to bmw to try to reflash the head unit with stock file but I think since I changed the version it’s not got a way to communicate with other modules.
      10-07-2023, 01:35 PM   #108
TheNine90
Drives: bmw
The module likely has corrupt cafd file. The dealer should be able to fix the issue, i dont think what you did has affected the communication to other modules.
      11-22-2023, 12:40 PM   #109
okankaymak
Drives: i5
Anyone figured out a fix to the heat distribution not remembering the settings you pick?
      08-30-2024, 05:46 AM   #110
Crickoss
Drives: G20
I have the same problem, not remembering the settings I make
