10-08-2020, 01:04 AM | #89 |
Rep 698
Hi, I see most are installing in the trunk; however, did anyone check to see if a Cellink NEO would fit under the passenger seat in the G20 and not interfere with the seat when the seat is adjusted or moved? Thanks.
10-08-2020, 01:13 AM | #90 | ||
Rep 512
Just wondering what the rationale would be installing it under the seat , there is not much space there and then you would need to lead a cable from the battery in the back to under the seat If it's in the boot then it's a few centimetres direct to the battery If you install it on the boot there is quite a lot of space and you would never need to access it Well at least I have had no need since it was installed |
BMW11281.00 |
10-08-2020, 11:16 AM | #91 | |
Rep 698
10-08-2020, 05:18 PM | #92 | |
Rep 681
From memory, the car battery installation charges the Cellink in about 40 minutes of driving, whereas the 12v supply takes approx twice as long. Sorry, I can’t tell you if the Cellink battery fits under either of the front seats as this is something I have never considered doing.
BMW11281.00 |
10-08-2020, 11:35 PM | #93 | ||||
Rep 512
Ah I see I think the pic is just for marketing, it just depends on your brand of car and for ours , better in the boot Lots of space Pic with Neo installed. |
BMW11281.00 |
10-11-2020, 05:55 PM | #94 |
Rep 512
Blackvue 950 overheating
Hi All
So don't normally park my car outside for long , but today I did and I received a warning that my dashcam was overheating and may shutdown Maybe that's why the new version has cooling slits in the body. I have the dashcam connected via Blackvue cloud service so thats why I received the message on the phone If I didn't not sure I would be notified at all, probably only when I open the app Just a heads up for a Blackvue owners |
10-31-2020, 05:12 AM | #95 |
Rep 222
Hey all,
2 questions - any more overheating issues? It's not even summer yet! - anyone happy to share the price they paid and where they ordered from? I'm still interested but continue to leave towards drive recorder... |
10-31-2020, 06:33 PM | #96 | |
Rep 681
Cost of a Blackvue 900S-2CH is around $ 1200 with a Cellink Neo battery and 128 GB SD Card from Dashcams Australia. I also have the BMW Drive Recorder on my car but (thankfully) have never had to use it. I only use it as a backup to the dashcams and for potential side impact vision. If I was to get one OR the other, I would opt for the dashcams over the Drive Recorder. Occasionally, I download vision from the dashcams after a drive (usually on a winding road), or when I tried out the launch control. I’ve never done this with the drive recorder. Hope this helps.
06-24-2021, 10:56 AM | #98 |
Rep 86
Drives: 2021 M340ix
SteveAus This is probably going to sound ignorant but when you connected to this 20amp fuse did you use a 20amp fuse for the Cellink as well?
I had a kit for a different camera system that I previously owned and it came with a 5amp fuse which I used when mirroring your installation. It blew immediately and I am pretty sure that is why but I wanted to verify that it is save to use a 20amp fuse with this battery as I can not find it in the documentation anywhere. Side note, your guide is awesome and super appreciated!! I think I did finally find in some responses that you did use 20amp. |
06-24-2021, 06:57 PM | #99 | |
Rep 681
Yes, I used a 20 amp fuse for the Cellink connection. You can also use a 15 amp fuse if you prefer. Just make sure you keep the original 20 amp inline with the 12v accessory circuit. The Cellink draws a reasonable amount of power and needs a fairly beefy fuse to charge the battery and 5 amp would have been too low. I’m not sure what dashcam you are using. I’m a little surprised it uses such low amperage for the two cameras. You should check that the electrical output from the battery is compatible with your dashcams. I’m sorry, I can’t remember what the output numbers are for the battery, but you should be able to find these figures on the battery or in the literature. Hope you manage to get your dashcams up and running.
06-24-2021, 08:05 PM | #100 | |
Rep 86
Drives: 2021 M340ix
I put in a 20amp fuse earlier and that did the trick. It is now charging as expected. Now I just have to install the cameras and radar and I am done. Thanks for the response! |
12-31-2021, 12:41 AM | #101 |
Rep 19
Hi thanks for sharing! I see you re tucking the cable within the weather strip above the doors, isn’t that a concern or risk of the cable affecting curtain airbag delopyment should an accident happens?
01-30-2022, 08:18 AM | #102 |
Rep 20
I ended up buying the Blackvue Battery on special (worked out to a similar price to the Cell Link Neo which is the same battery rebadged).
I installed it in the boot, it's currently sitting in the right rear accessory pocket (where people put their cleaning towels/solution). I plugged it into the 12v accessory plug in the boot and then ran a short extension, the Blackvue lead already reaches into the boot when routed neatly down the pillar and along the floor (tucked under the trim). It doesn't charge as quick as hard wiring, but it does the job. On the plus side it won't interfere with the cars electronics and draw too much accidentally because it's managed by the system that sends power to the accessory socket. |
11-25-2022, 09:29 AM | #103 |
Rep 552
Viofo A229 to Cellink Neo
Sorry for bumping an old but useful thread. I'm planning to connect a Viofo A229 to a Cellink Neo in the trunk (boot). Do I need the Viofo Type-C HK4 Hardwire Kit Cable for this installation?
2022 M340xi Tanzanite Blue II Metallic
11-27-2022, 03:29 PM | #104 | |
Rep 681
Blackvue has a similar product…Power Magic Pro. I used this before in an F30 335i before switching to a Cellink Neo. The Neo battery bypasses the need to use this product as it is independent of the car’s battery. One thing you should be aware of, and this is dependent on how you use your car……. In my case, my car is parked in the garage for long periods of time. The car periodically does electrical system checks. During this time the circuit is triggered to start charging the Neo battery, it then closes the circuit after a short period of time. In my case, I had some problems with my sunroof where it would freeze in the open or closed positions because the car battery had been drained and the sunroof had “lost” its settings. I could not rectify the problem myself and each time had to take the car to the dealer to fix the issue. The dealer kept the car for a 12 hr battery and electrical systems check. The bottom line to this long story is that I was advised to remove the Blackvue and Neo battery and replace it with a BMW ACE. I wasn’t keen to do this, but eventually I did. I haven’t had a problem since. Now….if, unlike me, you use your car normally and drive it regularly, you should not have a problem with your dashcams, Neo…..or sunroof!! Just thought I should pass this on to people. BTW, I put the BlackVue and Cellink Neo in the VW Golf (that we use to transport our Cocker Spaniels to and from the beach - wet and sandy!!) and it works perfectly. The Golf is less sophisticated than the Beemer and handles the Neo without a problem, even though it also is left stationary in the garage for long periods of time. Incredibly, the Auto Stop Start function works first time, every time, after a long period of time in the garage and I do not have to charge the car battery like I seem to have to with the Beemer. Sometimes Less is More
Last edited by SteveAus; 11-27-2022 at 03:37 PM.. Reason: Additional information. |
11-27-2022, 06:10 PM | #105 | |
Rep 552
11-27-2022, 06:17 PM | #106 | |
Rep 552
12-19-2022, 10:02 AM | #107 |
Rep 552
Viofo A229 Duo - Cellink Neo - 2022 BMW M340xi
This is the first dashcam I've owned or installed. The scariest and hardest part was gathering information specific to the g20 and trying to grasp, in the abstract, how everything would work. I'm extremely grateful to all the good folks at dashcamtalk.com and at BlackBoxmyCar who patiently answered all my newbie questions. Additionally, I found information on the web specific to the g20.
The Viofo A229 is powered by a Cellink Neo Battery located in the trunk (boot). The Cellink is charged from a connection to the fusebox (F273), also in the trunk (boot) that powers off about 7 minutes after the car is turned off. I've added a Cellink Extended Battery and now have approximately 50 hours on parking mode. With a power cable and a rear camera cable running on adjacent sides from the front to the rear, all cabling is 99% hidden. I was amazed that I accomplished this on my first try! Front Camera: I could have hidden the front camera behind the mirror, but with this location, it's much more accessible. Rear Camera: The rear camera was originally mounted higher (more stealthy), but I was getting an antenna wire at the top of the frame. You'll notice in the video below that there's still a fuzzy horizontal line in the frame. I could not find a location that would eliminate that. The Viofo A229 menu, through the front camera or the wifi-connected app, is very useful for making adjustments, downloading videos, and turning parking mode on and off when it's needed and when it's not. The Cellink Neo's Bluetooth app is also very useful to check the battery status and charge level.
01-08-2023, 07:25 PM | #108 |
2023 M340i LCI xDrive (on order)
34
Rep 125
I am thinking of getting the BMW ACE 3.0 installed in my M340i when I pick it up in earlier April.
I will be getting the dealer to install it so hopefully wont get any headaches with a flat battery or other issues reported with sunroof not closing, linked to low voltage battery. I believe it wasn't available yet in Australia back in Nov 2022. Does anyone know when the ACE 3.0 will be available and whether we are getting the PRO version (with the touch LCD) or just the standard version? Any cost on this if it is available? |
01-08-2023, 11:24 PM | #109 | |
Rep 681
As a guide, the ACE 2.0 that I had fitted last year by the dealer was $ 1295.00. It was cheaper at one dealer compared to the second dealer we have in Adelaide. So, shop around…
01-09-2023, 01:52 AM | #110 | |
34
Rep 125
BTW: How are you finding the ACE 2.0? |
