02-23-2023, 02:58 PM | #89 |
Rep 354
Drives: 2023 M340i
Supposedly you can’t remove pumped in engine noise at all. It has to be coded out.
02-23-2023, 04:43 PM | #90 |
Rep 167
Drives: M340i xDrive Tanzanite II
I am going to scandalously re-direct you to endorse my post regarding the 3 Series Harman Kardon design here : https://g20.bimmerpost.com/forums/sh....php?t=1990253
2020 M340i xDrive : Fully Optioned ; ZTK Pkg, Exec Pkg, DAP Pkg, HK, etc with 4 Screws Painted due to F.L.P. & the land of the $2 Gas tax.
02-24-2023, 06:46 AM | #91 |
Rep 363
Thank the lord I’ve rid myself of this audio disease that doesn’t allow me to enjoy the sound in my M340i. I find it just fine for driving. Maybe it’s just age. And I’m one who enjoys good sounding audio. I have 2 separate systems in my home. One 2 channel analog and the other 5.1 with mid to high end equipment.
(B&W Nautilus, Bryston, Rega, Oppo, Anthem, etc). I find it better than the Bose in my 16 Audi A6 and no worse than the Burmester in my wife’s 18 MB E350 coupe.
2018 MB E400 Coupe
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
02-26-2023, 01:08 PM | #92 | |
Rep 236
Does anybody know any Focal dealers in Michigan? That might be something worth pricing out. Not that the HK is awful but music is my first love and I’d like to have the best of both worlds if possible. |
04-08-2023, 09:31 AM | #93 |
Rep 140
Here they write a little about what does every frequency does.
https://www.songstuff.com/recording/...q_frequencies/ |
04-08-2023, 01:49 PM | #94 |
Rep 132
Roon is apparently working for DSP in Roon ARC.
This would allow a frequency response to be measured and then a filter to be generated and DSP applied using the smartphone. I would be curious to try it out once it's available. I've measured my car, compared it with my Mazda and there is no way to adjust the 150Hz dip as the EQ band is 100Hz and 200Hz; hopefully with DSP that could be adjusted. |
04-08-2023, 02:30 PM | #95 |
Rep 140
After many tries, and knowing that every song has been recorded different, being a Jazz and Blues musician who also hears Soul an R&R, my settings are:
Logic 7 on and off, depending the song or mood.... Bass: +3 or 4 Treble, +2 or 3 100 + 5 200 hz -5 500 hz + 4 1k -5 2k -2 5k +2 10 k + 5 If F/R goes to the back a little, like 2 or 3 clicks, then 10k needs to be higher, for my taste. With this settings I can hear, feel the bass drum, and the hi-hats the way I like, plus some clean bass and I really have never liked middle tones... |
04-12-2023, 10:41 PM | #97 |
Rep 19
05-19-2023, 04:25 AM | #98 | |
Rep 184
05-19-2023, 07:27 AM | #99 |
Rep 288
Suggestion, my opinion:
It is easier to just swap out the HK at a car audio shop and get something far superior - for maybe 3K - it will completely change your ride.. A good stereo usually sounds good when you turn it on, no matter what the settings. Settings are for fine tuning, not for making what is an otherwise bad stereo sound good. Example, get into an Audi with BO and you''ll immediately be blown away by the sound. Same with MB Baumester and so many others. I love BMW cars, I just don't know what they don't offer the higher end stereos found in the 5 and the 7 in a car like the 340. The HK works,, but BMW could have offered something better in a 50K car, really. Lexus did it with the Levinson sound system. The reviews have consistently trashed the HK in the 3 series. Come on BMW, wake up and give us a stereo that sounds better without googling for countless setting changes that maybe can help, but really never change things much. https://thedailymotor.com/sound-syst...harman-kardon/ Here is a forum topic that has some suggestions: https://g20.bimmerpost.com/forums/sh....php?t=1930260 If you go to the Alpha One website (Bimmertech) you can just type in your VIN and it will give you the parts needed to have a great sounding stereo. https://www.bimmer-tech.net/speakers...lifier-for-bmw |
05-19-2023, 06:17 PM | #100 | |
Rep 167
It doesn't matter if your amp doesn't fit in the recall they replaced mines after diagnosing that the booster part of the AMP was bad. Replaced it and bass never goes bad ever again as long as you don't turn on B&W codecs or logic 7 surround modes.
05-19-2023, 10:33 PM | #101 |
Rep 184
Great to hear! Thanks! I was already considering buying an used amp, but would hate voidingy warranty and also not knowing if replacing needs additional coding/sw update.
05-20-2023, 07:07 AM | #102 | |
Rep 1,565
Pretty close to what I set mine too as well. One thing I miss about my Tesla M3 LR, one of the best stock sound systems on the market easily.
Kind of tolerate the poor HK with these tweaks. My wife’s 21 X3 with stock HiFi sounds better than my 20 M340i sadly. I also coded out the active Sound. Lastly everybody will be different how they set their EQ. At my age I can’t even hear 16k hz… haha but I stillcan hear 10-11hz and boost it about +3. Plus I have tinnitus. Quote:
05-20-2023, 09:07 AM | #103 |
Rep 21
If you can swing it, go Match 10 DSP.
Bavsound speakers, Match subs for me. Sounds way better. Sublimal Sounds UK. Dave is the man. They ship to US. |
05-20-2023, 10:49 AM | #104 |
Rep 184
After a few days of testing i realized there is not much wrong with HK sistem (except lack of some 13 or 16cm driver - which could be easily put into front or rear door of any bimmer....to cover missing frequencies. The outdtanding problem seems to be the source! Radio (dab included) sounds terrible. Music via bt (from android) even worse. Much worse than any cheap car i have uses in last 30 years. However....once i tried usb key with my audiophile collection....the HK came to life! There is absolutely nothing missing in sound (after engaging eqviliser settings suggested here on forum)! When i play my 24/192 hires albums they sound incredible! Its a jawdropping experience! Still cant understand how Bmw managed to do such poor integration of external sources (and radio!). It almost seems like on purpose! Because the sound im getting via usb, listening my favorite audiophile picks (Diana Krall, Jazz at the pawnshop, Patricia Barber, Johnny Cash.....) Is absolutely incredible!! Ive listenened this songs thousands of times on my several hiend devices...and the result in my X3 is not noticably worse than home audio! So it seems it os the source/dsp/settings/whatever problem....and not the hardware itself. I openly wanted to change the amp and/or speakers.....but after hearing the music in last 2 days....im impressed. So i strongly advise everybody to try usb good quality material prior to investing in change of hardware!
X5-G05-45e71.00 |
09-21-2023, 12:29 PM | #105 |
Rep 1,657
For those with Harman Kardon who wish to increase sound quality markedly, these settings which I got from poster zazzau are just brilliant. And, importantly, don't require any coding. Begin by turning Logic 7 to OFF and follow the photos from there. Just amazed by how much better it sounds. Enjoy! |
09-21-2023, 12:43 PM | #106 |
Rep 109
I tried those settings and others, and myself did not see any big improvement. If you grow tired of what it sounds like, I would suggest trying coding, or for a major upgrade, FOCAL or some other high end components. True I did have to spend 3,000 on the FOCAL components, but man oh man, that resulted in a tremendous difference, night and day, like a real high end system should sound, with no need for hours on end of playing with settings. I'd say just about the same as BO or BW.
09-21-2023, 12:57 PM | #107 | |
Rep 1,657
09-21-2023, 03:03 PM | #109 | |
Rep 1,657
I've never been so happy with a BMW audio system. |
09-21-2023, 04:29 PM | #110 |
Rep 109
To the post above, pal, have you ever listened to MB Baumeister, BMW's Bowers & Wilkins, Lexus Levinson, Audi Bang and Olufson?
If you have listened to any of those, you can't be serious. No one replaces those other sound systems, and they are always ranked amongst the best... for good reason. Yet there are countless companies offering HK replacements for the 3 series...... The reason is obvious... I mean the HK is ok, but when you listen to the competition, it is an amazing difference, not even close |
