04-17-2022, 12:36 AM | #112 |
Rep 146
Turner Motorsport 5mm spacer on the fronts. No spacer for the rears with powder coated satin bronze oem Supra wheels.
Running 255/35/19 fronts and 275/35/19 rears. Supra fitment to make for easier ordering at Discount tires. |
04-17-2022, 11:48 AM | #113 |
Rep 47
04-18-2022, 12:14 PM | #114 |
Rep 112
05-07-2022, 06:55 AM | #117 |
Rep 440
08-16-2022, 12:49 AM | #119 |
Rep 4,250
it turns out I need spacers as my new wheels have a +35 offset and i want to mount 255 tires in the front so it will need at least a 10mm spacer (will mount 255 tires rear to +35 wheels and will use the same spacer width as front, whatever the number may be)
i don't want it to be flush (aero!) so hopefully 10mm spacer is enough is the G20 wheel stud removable and i just "unscrew" the factory studs and screw in longer studs? thanks |
09-09-2022, 10:22 AM | #122 | |
Rep 38
I just got 12.5mm KSP hubcentric spacers for my square setup. Quality seems reasonable at a reasonable price. Will be installing this weekend. |
11-01-2022, 12:03 PM | #124 |
Rep 15
Exploring 10/13 mm BMS spacers on my 330i with 225/50/17 square setup on PS4 tubeless. Generally speaking, is there any perceptible change in ride quality or handling?
11-29-2022, 10:41 PM | #125 | |
Rep 3
Tires are 245/40/19 Michelin Pilot Sport 4 All Season Did adding spacers help or exacerbate the problem? Open to anyone for some help here. Was thinking 12mm all around but not sure anymore. Stock height fyi. Thanks! |
12-01-2022, 10:57 AM | #126 |
Rep 1,184
Imo no difference that is noticeable.
12-06-2022, 09:30 AM | #128 |
B58 Power
497
Rep 633
Eibach ProKit (30/25mm)
Eibach Pro-Spacers (15mm) BMW 898M
mr.almeida60.00 |
01-08-2023, 12:27 PM | #129 |
Rep 25
hello guys, my question is:
for handling, isn't better to have larger front axle vs. rear axle? the larger the rear gauge, the lower will be the responsiveness of the car (understeering) |
02-22-2023, 12:08 AM | #131 |
Rep 1,184
Front and rear wheels are different size (ie rear wheel + tire larger than front).
03-02-2023, 04:53 PM | #132 |
Rep 42
I am adding 5mm spacers to increase clearance between front wheel spoke and caliper. Should I get 30mm or 33mm extension lug bolt ?
Getting different info from different sites. What is the stock bolt length ? Do I need spacer with lips or stock hub is long enough ? |
