03-12-2022, 02:53 PM | #111 | |
Rep 2,705
These are my observations running square 245, this season I will be running 255 square.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
03-19-2022, 01:46 PM | #113 |
Rep 177
I ended up ordering 2 8.5" as well to copy your setup. Do I need to be cautious of what tires to get or any should work as I don't think rubbing is going to be an issue with this setup.
03-19-2022, 01:49 PM | #114 | |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
03-19-2022, 01:51 PM | #115 | ||||
Rep 177
03-19-2022, 11:31 PM | #116 |
Rep 44
03-19-2022, 11:32 PM | #117 |
Rep 1,758
No but i had spacers. The larger tires gave the look of lowered by decreasing the wheel well gap. and fyi I sold her
Current non-BMW's
03-25-2022, 04:03 PM | #118 | |
Rep 177
04-01-2022, 02:14 PM | #119 | |
Rep 177
04-02-2022, 11:14 AM | #120 |
Rep 1,758
Sorry I don't recall anything different from stock pressures
Current non-BMW's
04-02-2022, 10:04 PM | #121 |
Rep 177
04-02-2022, 10:09 PM | #122 |
Rep 1,758
Awesome, congrats.
Current non-BMW's
04-04-2022, 06:35 AM | #123 |
Rep 355
Its the rolling circumference of the tyres across each axle and front to rear that must be kept as close as possible on an X-Drive. The reason is that the transfer box which distributes the drive to the front and rear wheels contains clutches. When you turn a corner all the wheels are turning at different speeds and these clutches have to slip a little to avoid drivetrain windup. [Windup can cause steering, juddering and wheel skipping issues and was evident in much older, direct four wheel drive set ups.]
This clutch slippage obviously causes wear over time. When travelling in a straight line all the wheels are turning at the same speed so no slippage. If your tyres / wheels are 'mismatched' i.e. not the same rolling circumference then these clutches have to compensate by slipping slightly all the time causing excessive wear over time and potentially causing transfer box issues / failures. Differences in tyre rolling circumference can be caused by mismatched wheel /tyre sizes, different tyre brands [or even models within brand] and pressure. Its why 'BMW approved' tyres are recommended as they are made to tighter tolerances. Some people have no issues regardless of tyres fitted. Others have had lots of transfer box issues and some have had warranty work on the transfer box declined because of non-approved wheel / tyre fittments. There are several tyre diameter comparison sites to try before you buy such as: https://tiresize.com/tyre-size-calculator/ I became aware of this issue having just bought my previous F31 335d M Sport Touring and badgered the dealership "BMW Expert" until he got me the official BMW position on this as there were so many opinions on-line. See my post #37 here for the official BMW reply: https://f30.bimmerpost.com/forums/sh...1142647&page=2
F31 335d Xdrive Shadow Edition M Performance, Individual Tanzanite Blue, HUD, Adaptive Susp, Evolve-R Map, Xhp Stage 3 E60 535d Msport Carbon Black/E39 530d MSport, Black Sapphire/E34 525i MSport, Avus Blue/E34 520i MSport, Briliant Red Last edited by Assassin; 04-05-2022 at 08:54 AM.. |
ultrared93109.00 |
04-08-2022, 05:30 AM | #125 |
Rep 195
I'm really sorry, but I've read through a bunch of posts and not sure if this setup will work on my M340i XDrive for a Square setup:
19x8.5 235/40/19 with 25mm offset (would it be best to have the same on both axles?) I'm basically looking for the most balanced setup whilst getting the wheels flush. Someone please help a novice out. Would that be okay or should I try and find wheels with a smaller offset, maybe 20mm?
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe Last edited by Wet Fish; 04-09-2022 at 06:01 AM.. |
04-14-2022, 03:24 AM | #126 |
Rep 1,897
This thread seems a little bit more alive than the fitment thread on the G42 forums. Here is my 245/40/19 fitment up front on stock 791M 8" wheels - replacing OEM 225^2. Any thoughts on these gaps? Slightly worried about the gap between the top of the tire and the sprint perch. No rubbing yet…
04-14-2022, 07:55 AM | #127 |
Rep 2,705
Ravenseal
I think it will be fine but why not run 245/35-19 when the rear is 255/35-19 ? Much closer to the same rolling diameter...
04-14-2022, 08:40 AM | #128 |
Rep 1,475
So, have we answered the question on what the max square setup is? There is another thread where Apex wheels posted their offerings. If you take the specs and put it into the comparison calc, I believe you can run 265/35/19 x 9" squared. You will need to play with the offsets front/back and maybe use a spacer. To me, it seems like the 265s are possible.
There is even a member who is running 265s.
2020 MG M340ix
2018 LBB X4M40i 2014 EBII 435ix - SOLD |
PLF693805.00 |
04-14-2022, 10:34 AM | #129 |
Rep 85
Still confused about the definitive staggered approved sizes for xdrive
Also, if my car came squared, switching to staggered with a ~1% rolling circ difference shouldn’t matter right ? |
04-14-2022, 10:40 AM | #130 | |
Rep 2,705
Above that your exposing yourself to transfer case issues.
FellowM313.50 |
04-14-2022, 12:33 PM | #131 | |
Rep 85
Insane435495.00 |
04-14-2022, 03:38 PM | #132 |
Rep 1,897
I'm on xDrive, so it's 245/40 squared. I tried to order 245/35 but Pilot AS4 in that size were backordered at Discount Tire.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
