Technical Topics Suspension / Chassis / Brakes Brake pads for M340i
      01-25-2024, 05:25 PM   #111
prostcfc
prostcfc's Avatar
Drives: 2020 BMW M340i
Originally Posted by Z K View Post
Rhdjapan has good customer service. They should be able to get it to you in less than a month from time of ordering and will be cheaper than any US vendor.
I don't mind paying a bit more to get it from a US vendor but the wait time is just insane.
I paid $322 for four PMU HC-CS pads, then $50 for shipping. US sites were $300 per axle! Thanks, cheap Yen. It's been a week, and looks like they're about to ship, so yeah, hopefully arrive in the next week or two.
Z K1913.00
      01-31-2024, 12:12 PM   #112
prostcfc
prostcfc's Avatar
Z K Arrived today; only took two weeks. On the fronts, there aren't the tabs that the stock brakes have. Not sure what their purpose are (maybe vibration/noise purposes), but I assume I can just install the PMU fronts without prying the tabs off my old pads?
Z K1913.00
      02-08-2024, 02:37 AM   #113
Z K
Z K's Avatar
1913
Drives: G20 M340i, S15 Silvia Spec R
The stock block things are for noise reduction. You can try moving them over although I don’t know how. I haven’t had them with my pads and it’s been fine.
Auto Detailing Enthusiast!
      02-26-2024, 12:28 PM   #114
legolego
legolego's Avatar
Singapore
Drives: M340i
Are you looking for the base Brembo brakes with the 348mm rotor front brakes? If you have the optional big front brakes, that's a different pad.
For Project Mu, you can find any pad by going by the pad shape part number and the desired pad compound.
For the normal M340i Brembo brakes, front the pad shape is Z723. Rear is Z625.
Here is the fronts, The "Euro Sports Excellence" is the same pad with a different name for European markets. Evasive is in California so if it is in stock you can get it within days.
https://www.evasivemotorsports.com/s...0u-hWzqOnVhz2I
Front Type PS:
https://www.rhdjapan.com/project-mu-...k-package.html
https://www.blackhawkjapan.com/produ...z723-type-ps-7
Type PS rear:
https://www.blackhawkjapan.com/produ...u-z625-type-ps
Hi. Is the Z724 meant for the larger caliper that goes with 374 rotor?
      02-26-2024, 12:33 PM   #115
Z K
Z K's Avatar
1913
Yes, those are for the cars with the optional brakes. The M performance upgrade brakes or ZTK package cars.
      03-29-2024, 09:11 PM   #116
prostcfc
prostcfc's Avatar
Z K Do you notice your front insides wearing slightly more than the front outsides? Maybe a mm or two more? After my first HPDE weekend (with STOCK pads) I changed pads and noticed this. Both insides were about equal, and both outsides were about equal. First pad change, so I doubt there's any pistons sticking. I suspect it has to do with overheating brakes, particularly on the inside of the rotor, which doesn't get effective cooling. Thoughts? Hopefully the PMU pads hold up better.
      03-29-2024, 09:16 PM   #117
cyam
Actually the inside gets the most cooling. The brake air ducts are directed to the inside hub, where the air enters the center of the Rotor and flows through the vents in the Rotor. It means the inside pads would get the most direct airflow.
      03-29-2024, 09:28 PM   #118
Z K
Z K's Avatar
1913
Might be because of the physical design of the caliper. The inside side is where the brake lines attach. The brake fluid will flow to the inside pistons first and those get pushed into the rotor before the outside ones. The difference should be pretty minimal though.
Did you change the brake fluid with high temp track brake fluid?
      03-31-2024, 12:18 PM   #119
prostcfc
prostcfc's Avatar
For this particular weekend, no. It was Motul 5.1 with stock pads. I'm switching in Endless RF-650 so we'll see how it goes. The difference on one rotor was <1mm and the other was closer to 1.5mm, so it's not much. I was also thinking it could be the reasoning you're stating.
Conceptually I agree, but I wonder how well it works in practice. Here's an interesting video of this, though they are selling a product (last post in thread): https://f87.bimmerpost.com/forums/sh....php?t=2060907 Next HPDE I'm going to try and measure the temp difference on my own after a session and see what the delta is.
      04-24-2024, 08:54 PM   #120
RCKYMTN M34OI
For those that are curious on ordering some Project Mu pads: I ordered the PS pads from mhdjapan on 4/11-I got notification the shipped on 4/22, and they arrived today- 4/24.
Total was ~$364
I'll update on my impressions once I install and get some miles on them.
      04-24-2024, 10:23 PM   #121
M340I///M
M340I///M's Avatar
Drives: 2021 bmw m340i xdrive
2021 BMW M340IX  [9.07]
I’m looking for front and rear pads by project mu , I have the M performance 18”bbk , it’s the ZTK package, dimple front and rear rotors. Can anyone help me with the part numbers for front and rear?
2021 m340i xdrive ZTK package.
And where would it be best to order them from? That won’t take 1/2 a year to get here ?
      04-25-2024, 10:06 AM   #122
prostcfc
prostcfc's Avatar
ZTK package is the Z724 pad shape from PMU. Rears are the same as the normal M340 m-sport brakes (Z625).
Order direct from Japan (RHDJapan for example) and they should arrive within a month or less via airplane, assuming they're available. Seems like the US vendors get from a distributor who wait for a shipping container to fill. You also take advantage of the favorable Yen to Dollar exhange rate if you buy direct.
      04-25-2024, 06:42 PM   #123
M340I///M
M340I///M's Avatar
Thank you
      06-24-2024, 11:05 PM   #124
cyam
Originally Posted by kuzdu View Post
Only had the stock and ebc on this car since i got it but i will tell you its a huge difference in braking power. for anyone who is wonder how they noise is imagine you haven't washed your car for a month and a ton of brake dust developed, pretty much that's the noise you will get.
Which EBC did you have, what were they like?
So the HPS+ are really just like the OEM pads cold? I love the way the OEM/original pads are when cold. Barely touch the pedal and get instant response. I hate getting higher temp pads that, when cold, need more pedal pressure.
I am after new pads/rotors and do some very light occasional track work (I don't push that hard, so its not a big deal - OEM's are almost fine), but I don't want to sacrifice that cold friction level of the OEM's.
EBC yellows and Hawk 5.0 - I note that most say that cold they need more pedal pressure than OEM. I'd have thought the HPS+ would be worse cold as they are meant for more track / higher temps.
      07-18-2024, 03:14 AM   #125
m440i804
Drives: m440i
Anyone have input on how the Project Mu PS pads perform compared to Ebc red stuff pads? Less or more noise then red stuff?
Thanks
      08-06-2024, 06:59 PM   #126
ztkm340
Drives: BMW M340xi ZTK
I just ordered PMU Fronts PS z724, HC-CS and PMU PS z625 rears. I have the ZTK package. Also thanks for all the great info here.
      08-06-2024, 10:09 PM   #127
RCKYMTN M34OI
I had the HP+ for a few weeks in the CO winter. They stop like hell at first touch. They're actually Hawk's highest friction brake pad when cold as they're classified as an autocross pad. On the flip side they don't have the highest heat tolerance when compared to an all out track pad. Also, I assume they'd be a bit dusty as a daily driver. That car got stolen so not enough time to tell Lol
https://www.harrisonmotorsports.com/...ound-Graph.jpg
cyam441.00
      08-07-2024, 09:38 AM   #128
prostcfc
prostcfc's Avatar
Originally Posted by randomserious View Post
the MU HC-CS are great, had no issues with them and the only noise i hear is when i do a 3 point turn in my driveway. i track regularly, 12d on these pads so far.
i had the Mu Type PS before which were overheating at brake-heavy tracks (Laguna) but worked well street and other tracks, no noise at all.
How many track days do you get out of the fronts? I'm at about 50% on the HC-CS after 2 days/8 ~25 minute sessions. They are my DD pads as well, but very limited miles.
      08-07-2024, 10:41 AM   #129
ztkm340
I'm curious about that too. I wasn't fond of PMU's in my previous vehicle as they disintegrated relatively quickly, considering how heavy the car was, but I don't remember which spec they were as I got it around 2018 as a vendor sale, though, vendor claimed they're great on track.
If HC-CS are down to 50% after 2 track days then they seem to be on par of what I used to settle on in my other track car around the same weight as M340i which were Carbotech's XP12 fronts and XP10 rears. I'd even say they were good for solid 4-5 track days with 4-5 sessions each day.
      08-07-2024, 10:52 AM   #130
ztkm340
I hear you. Now I'm having second thoughts about PS's and sent an email to RHDJapan to swap those PS's for another set of HC-CS.
Wow, 12d out of pads is impressive. I could never get more than 5 days and I considered that to be great. The only pads that lasted me 10d+ were in the Radical
      08-07-2024, 12:09 PM   #131
randomserious
Drives: 2021 BMW M340i
i haven't run a pad down so far, always swapped prematurely (stock, ps, hc-cs).
i think they all around have maybe 5-6mm left. i do around 1000mi/mo (including track time).
      08-07-2024, 12:24 PM   #132
prostcfc
prostcfc's Avatar
I think he meant 12 days in total running HC-CS, not on one set. No way they'd last that long. I'm doing one more day on these in two weeks, and then I'm assuming they'll be down to 3 mm or so and ready for the trash (3 track days total use).
