03-31-2020, 11:22 AM | #133 |
Rep 299
So if our cars do actually have the I4 version of live cockpit then we might be able to map that to an empty button if we can confirm which properties need to be changed in order for the m display to appear. So for instance if we need to code properties a, b, and c to enable m track display, we can map a button to toggle properties a, b, and c. Might be possible to link m track displays to sport plus mode. I'll be doing a lot more research
03-31-2020, 11:42 AM | #134 | |
Rep 327
If the 360 view camera button can be disabled from factory coding, I'm pretty sure there's a good chance we can map that button to any feature, in this case, M Track Mode would be ideal. Even if we don't have the necessary hardware for M Track Mode, getting the dash to show up while still in normal driving mode or sport/sport plus would be more than enough. |
VipinLJ1950.50 |
03-31-2020, 11:59 AM | #135 |
1951
Rep 3,520
I don’t have surround view either and that button on the centre console is press-able. IF it can be mapped to track mode, that would be a HUGE finding and a major plus point Android still doesn’t have the update and I can’t code MGU in expert mode yet.
g20beam483.50 |
03-31-2020, 02:52 PM | #136 | |
Rep 327
Edit: Now, in Sport Individual: Engine: Comfort > Sport > Sport+ Transmission: Comfort > Sport > Sport+ Damping: Comfort > Sport Steering: Comfort > Sport |
VipinLJ1950.50 CyclingBroStyle233.00 |
03-31-2020, 03:03 PM | #137 |
Rep 327
I have an idea. What if, we find a way to switch our iDrive configuration to a M Car iDrive configuration? IF I can do that, and that's a big IF, I can go through the car's system settings and just get to M Track Mode without having to press any button. That would, in theory, work. If we can just find what the default coding choices are in an M8 for DKOMBI4 and HU_MGU, then we can just replicate the same choices on a G20 and it would have the same system as the M8, just without the buttons.
The question here, is whether or not this coding is shared between the M8 iDrive 7 and the G20 iDrive 7, but at this point I'm certain all G generation platforms all use the same iDrive 7 software, with features disabled/enabled for each individual line. The other question is whether or not M Car system configuration requires any additional hardware to be functional, or if it will just take into account all the existing hardware and just disable software functions that are not hooked up to the additional hardware. For instance, the 2WD option in the M8 is not equipped on our vehicles because we do not have the M Diff. |
VipinLJ1950.50 |
03-31-2020, 03:25 PM | #138 | |
1951
Rep 3,520
03-31-2020, 03:37 PM | #139 |
Rep 327
I have translated some things from 3000 Anzeige_Konfiguration, also, I have tried to isolate as many M Track Mode coding settings as I can, that relate to this. Take a look:
Related to M Track Mode: DKOMBI4 HMI_MVIEW_ENABLE HMI_MVIEW_FAHRSTUFE_ENABLE > HMI_MVIEW_GEAR_ENABLE HMI_MVIEW_NAVI_ENABLE HMI_M_AWD_ENABLE HMI_M_MODI_ENABLE > HMI_M_MODE_ENABLE M_RACE_FAHRMODUS > M_RACE_MODES M_VARIANTE > M_VARIANT I need help understanding what HMI means. If someone can give me an answer to that, it would be much easier. Edit: HMI stands for Human Machine Interface, found it on a paragraph on ConnectedDrive. Last edited by g20beam; 03-31-2020 at 04:43 PM.. |
03-31-2020, 05:14 PM | #140 |
Rep 327
I was messing around in expert coding for HU_MGU and enabled M menu. I can go into M menu from iDrive and configure M1 and M2 settings, but it's useless because I cannot toggle M mode. But this is interesting because the settings in the iDrive system are there. Hopefully I can code more...
To do this, you need to go into HU_MGU, then expert mode. Look for M_GMBH If you enable all or most of those settings, you end up getting the M menu, fully configurable except for suspension of course. That option is greyed out, which is good, meaning you can enable features that your car does not have, and the system will automatically disable the feature even though you can visually see it. See photos below: Last edited by g20beam; 04-01-2020 at 12:19 AM.. |
VipinLJ1950.50 |
03-31-2020, 05:55 PM | #141 | |
1951
Rep 3,520
g20beam483.50 |
03-31-2020, 06:16 PM | #142 |
Rep 327
If you can get your hands on the M Steering Wheel, chances are this will all work. Still having trouble trying to get track mode instrument cluster, but it is definitely tied to G platform M Mode because the next M2/M3/M4 will definitely have the same M Track Mode display as the current M8. All the settings are definitely there, just gotta figure out how to get them to show. Also, the M menu configuration looks different from the M8's M menu, I think it has to do with the system still thinking that I am a G20, and not a M car. I can try to find the setting that allows me to change the iDrive 7 version to function like the M8 version. I am positive that's in the coding, and not a modified version of the same operating system...
VipinLJ1950.50 |
03-31-2020, 06:58 PM | #143 |
Rep 327
These are full HD images of M mode in M8. We can see that in M mode, you also get widgets for tire data and engine data. That, too, can very likely be coded. I already got M menu to work, I'm pretty sure M mode is somewhere in the coding, I just haven't found it yet.
We can also see that the instrument cluster is the M style instrument cluster, maybe enabling that will also help to enable M track mode instrument cluster, since there is no design for M track mode with the G20 instrument cluster design. Take a look: https://paultan.org/2019/05/09/bmw-m...new-m-mode-50/ |
VipinLJ1950.50 |
04-01-2020, 04:26 AM | #144 |
Rep 327
Scrap all of the M menu stuff. If I'm correct, none of that has to be enabled for M mode. I believe it is separate, since on the M8 center control, "SETUP" and "M MODE" are two different buttons. I believe M mode can appear in iD7, probably right under or on top of M setup. I am going to switch to M instrument cluster to see if that changes anything. Regarding codes related to M mode, here is a complete updated list of what I took note of:
DKOMBI4 HMI_MVIEW_ENABLE HMI_MVIEW_FAHRSTUFE_ENABLE > HMI_MVIEW_GEAR_ENABLE HMI_MVIEW_NAVI_ENABLE HMI_M_AWD_ENABLE HMI_M_MODI_ENABLE > HMI_M_MODE_ENABLE M_RACE_FAHRMODUS > M_RACE_MODES M_VARIANTE > M_VARIANT So far, I believe all these settings above are related to enabling M mode instrument cluster in iD7. Since it is in DKOMBI4 module, there isn't anything else I can think of that is related to these options. Enabling these will enable M mode support for instrument cluster. I think the final step is to find out how to show M mode in iD7 control panel. If that is enabled, when you select through the options in M mode, you will be able to choose Track, in which the instrument cluster will change when you toggle through the different M mode settings. HU_MGU M_GMBH (This helps to enable M menu/setup) BC_M_ANZEIGENSYNCHRONISATION > BC_M_SHOWSYNCHRONISATION BC_M_VERBRAUCH_NEBENVERBR_ENABLE BC_M_VERBRAUCH_REKUP_ENABLE CB_DIGIT_GESCHW_M_ANSICHT CB_DREHZAHL_M_ANSICHT CB_M_DRIVE CB_M_FAHRDYNAMIK CB_PRESELECT_M_ANSICHT CB_SLI_NPI_M_ANSICHT CB_SPA_M_ANSICHT |
VipinLJ1950.50 |
04-01-2020, 06:42 AM | #145 |
Rep 241
To recap we can bring up the configuration display. However we cannot active the modes. Is this a correct summary? Side note: we should create a consolidated "cheat sheet like" thread for activating Sport +, and other expert functions once we figure this all out.
This is awesome team work!
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
g20beam483.50 |
04-01-2020, 11:11 AM | #147 |
1951
Rep 3,520
g20beam is da man! I unfortunately am of zero help. Bimmercode still hadn’t been updated for android I wish I had bought the app on my iPad instead of on my phone.
g20beam483.50 |
04-01-2020, 11:27 AM | #148 | |
Rep 327
Right now I am trying to find the coding for center console buttons. Still not sure where this is but I am hoping that each center console button is a code that is assigned to each of the functions, ranging from 0- however many buttons there are. If so, then I can map value 02 (or something like that) for the second button on the center control panel, and then map button 02 to a function, in this case, for M Track toggle. All of that is assumption. I have no idea how button assignments work in iD7, if anyone has an idea that’d be really cool Last edited by g20beam; 04-01-2020 at 11:38 AM.. |
VipinLJ1950.50 |
04-01-2020, 12:54 PM | #149 |
Rep 1,426
Wait. Haven't been tracking this lately, so sorry if this has been mentioned. But did you guys figured out how to get the change to Sport + to show on the iDrive now?
04-01-2020, 01:11 PM | #151 | |
Rep 1,426
04-01-2020, 02:22 PM | #152 |
1951
Rep 3,520
If you have already done it before, you won’t need to do it again since it already shows sport+ on the live cockpit. This coding adds the iDrive option as well.
04-02-2020, 02:49 PM | #153 |
Rep 30
After the recent update to BimmerCode I was able to enable Sport+ Unfortunately I can't enable expert mode for HU_MGU. Are doing this from a beta version? How do I get that for IOS? Thanks!
04-02-2020, 04:36 PM | #154 |
1951
Rep 3,520
Email Stephan from the app. Tell him you want to be a beta tester. He’ll invite you to the test flight app I believe after you’ve provided him with proof that you’ve bought the app.
