Technical Topics DIYs and Coding Discussions Coding More Ambient Colors And Amber Sidemarker Delete?
      07-04-2020, 08:36 AM   #133
sztmek
Drives: BMW 3 G20
Do anyone figure out how to change AC and Radio buttons from orange to white ?
      07-10-2020, 08:56 PM   #134
rcrc
Drives: Volvo XC90
This is a very helpful thread! I've successfully coded bronze to red and it looks great. But the ambient lighting on the B&W speaker grills are still bronze. I changed all the D7,6E,14 bytes to FF,00,00 in 360A. Can't figure out how to change the speaker lighting. Anybody successfully code this so the B&W lighting changes as well?
      07-10-2020, 09:27 PM   #135
VipinLJ
VipinLJ's Avatar
You mean HK grill? Someone said those grills don't have lights?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      07-11-2020, 06:09 AM   #136
rcrc
Drives: Volvo XC90
I'm referring to the Bowers & Wilkins speaker grills, which do have lights (I'm driving a G05).
540iSUP704.00
      07-12-2020, 03:49 AM   #137
dwlc1983
Drives: 2020 330xi
Nope. You don’t need to change the hex code for white (90, E0, 90). Let that be as is in 360A. Instead, change the value for bronze (D7, 6E, 14) which are bytes 18, 19, 20, 23, 24, 25, 28, 29, 30 to red (FF, 00, 00). Then go to 360D and change byte 3 to 03 (it is originally 00 for white; 03 makes it blue and 01 changes from bronze to red since we changed it in 360A).
With that coding, you get blue where it was originally white (ONLY when you choose bronze and white; it remains white in the other options such as orange and white, green and white, blue and white etc) and red where it was originally bronze. When you choose only bronze, all the lights turn red. Basically, the photo I posted of my car in my previous post.
Hope that helps.
Very helpful and cool new look to the interior. Thanks man!
VipinLJ1949.00
      07-12-2020, 08:55 PM   #138
VipinLJ
VipinLJ's Avatar
I agree. BMW should’ve done it from the factory itself!
      07-17-2020, 08:53 PM   #139
SoFlo M340i
Drives: 2020 BMW M340i
I'll do a write up since it'll be a bit before I can make a video.
1. Changing the actual color for the ambient lighting (White, bronze, orange, blue, green, lilac)
BDC module > Expert coding > 360A LicLciColorLibrary > LIC_LCI_COLOR_LIBRARY_DATA > G20G21G26G28G80_Lichtpaket_code1 (selected option) > Custom value
Byte 0 to byte 151 present, screenshots of which can be found here.
Original RGB hex codes are:
90,E0,90 - WHITE
D7,6E,14 - BRONZE
93,1A,01 - ORANGE
00,20FE - BLUE
10,FE,32 - GREEN
78,3C,FE - LILAC
Any of these colors can be changed. As a result, that color will be removed completely and replaced with the new color you code.
The only change I made there was to the default bronze (D7, 6E, 14) at bytes 18,19,20, 23,24,25, 28,29,30 to red (FF, 00, 00). When you click save and then code it, all 151 bytes get saved as a new unassigned value which is the new selected option. I have no bronze color in my ambient light anymore. All the other colors are present along with the newly coded red color.
2. Ambient light option in iDrive
BDC module > Expert coding > 360D LicLciColorProfiles > LIC_LCI_COLOR_PROFILES_DATA > G22G23G82G83_Lichtpaket_code1 (selected option) > Custom value
Byte 0 to byte 21 present, screenshots of which can be found here.
Original values are:
00 - white
01 - bronze
02 - orange
03 - blue
04 - green
05 - lilac
In my car, bronze has been replaced with red. So 01 becomes red instead.
Also, I've replaced bronze and white with red and blue (byte 2 left as is and byte 3 changed to 03 from 00) AND green and white with blue and red (byte 16 changed to 03 from 04 and byte 17 changed to 01 from 00). When you click save and then code it, all 21 bytes get saved as a new unassigned value which is the new selected option.
Great write up but wondering if a video was ever made?
'20 Portimao Blue M340i – Current
'17 Dark Graphite 530i – Retired
'14 Alpine White 328i – Retired
      07-17-2020, 09:46 PM   #140
VipinLJ
VipinLJ's Avatar
I did make a screen recording but the problem is that when I first changed the values, the original default selected option in bimmercode change to a new unassigned value option.
As in, when it’s untouched, in 360A > LIC_LCI_COLOR_LIBRARY_DATA, the option G20G21G26G28G80_Lichtpaket_code1 is selected. When I changed the custom value there, it saved all those 151 bytes as a new unassigned value. So now, in my car, when I made the screen recording, the option selected was “Unassigned value” instead of “ G20G21G26G28G80_Lichtpaket_code1”. Thus, it isn’t accurate for those who haven’t changed the ambient light coding at all.
I’ll upload it on YouTube and post a link soon. I need to find that video first
      07-18-2020, 03:10 AM   #141
phayze
Drives: BMW
It will turn white when u are under the sun.
      07-18-2020, 06:21 AM   #142
SoFlo M340i
As in, when it's untouched, in 360A > LIC_LCI_COLOR_LIBRARY_DATA, the option G20G21G26G28G80_Lichtpaket_code1 is selected. When I changed the custom value there, it saved all those 151 bytes as a new unassigned value. So now, in my car, when I made the screen recording, the option selected was "Unassigned value" instead of " G20G21G26G28G80_Lichtpaket_code1". Thus, it isn't accurate for those who haven't changed the ambient light coding at all.
I'll upload it on YouTube and post a link soon. I need to find that video first
I know what you mean. I had an unassigned when I did M layout for cluster plus m340i logo. It couldn't display that logo with m layout so ended up as unassigned. I'd still like to see the vid if possible. I haven't tried to do this yet but I'm the reading of it, I'm semi-lost on the whole hex values thing. When I think of hex values I think of web coding value but this is something else and I just really need to sit down and understand what numbers do what and what values tie to which color and so on.
540iSUP704.00
      07-18-2020, 12:43 PM   #143
dwlc1983
Drives: 2020 330xi
The colors look great and thanks again for the write-up.
Question:
Has anyone else noticed that following the coding, the map lights don't automatically turn on? The are off (though the rest of the ambient lighting is on) when I start the car. They only come on after I go and change the colors back and forth...
Any solution?
VipinLJ1949.00
      07-18-2020, 01:05 PM   #144
VipinLJ
VipinLJ's Avatar
I've also made some changes to the write up. Please look at what I've added below the video in my post to get a better idea.
https://g20.bimmerpost.com/forums/sh...&postcount=103
      07-18-2020, 01:08 PM   #145
VipinLJ
VipinLJ's Avatar
Question:
Any solution?
Are you talking about the two tiny spot lights next to the dome lights? If so, another member also mentioned the same problem in the previous page I believe. But I do not have that issue. My map lights are the same as the idrive option change I made. And I don't need to change colors on the idrive to bring the correct color up. It starts up with the correct color. I'm not sure why it works differently for you guys.
      07-18-2020, 03:11 PM   #146
SoFlo M340i
https://g20.bimmerpost.com/forums/sh...;postcount=103
Thanks dude. Gonna mess around with this. I don't recall if anyone answered whether the orange for AC controls and other buttons can be coded to white instead of orange during nighttime. Do you know how?
      07-18-2020, 03:38 PM   #147
VipinLJ
VipinLJ's Avatar
Yup. Apparently it wasn't possible. Someone posted a change that might have worked but it didn't. So yes. Looks like we're stuck with the orange and white backlights for now.
      07-18-2020, 03:42 PM   #148
SoFlo M340i
Gotcha. A little off topic but do you know of a way to code the driver side mirror to also tilt down when in reverse?
540iSUP704.00
      07-18-2020, 03:51 PM   #149
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
Question:
Any solution?
Noticed this as well, after reselecting color they came on, I wonder what happens if I code another color as well
      07-18-2020, 04:49 PM   #150
VipinLJ
VipinLJ's Avatar
What color is the top map light for you guys? And what option is the ambient light set (what color are the strips and what color are the footwell/door handle lights)?
My strips are blue and the footwell is red. The dome spot lights are red too. I tried changing it and when I choose the red strips and blue footwell, the spot lights change to blue. I'm guessing that's how it should work?
      07-18-2020, 04:54 PM   #151
VipinLJ
VipinLJ's Avatar
I don't think the driver's side can be coded to tilt down in the G series cars. I'm not a hundred percent sure though.
      07-18-2020, 11:38 PM   #152
Swagasaurus-R3X
Swagasaurus-R3X's Avatar
Drives: BMW M340i
Don't you just flip the mirror switch button on the window driver panel to the opposite position you want? I'll check this out tomorrow.
      07-18-2020, 11:46 PM   #153
VipinLJ
VipinLJ's Avatar
When the switch is to the driver’s side position, the passenger side rear view mirror dips down. When it is to the passenger’s side, neither of the mirrors will dip.
      07-20-2020, 02:12 PM   #154
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
Great write up VipnLJ.
I managed to get mine coded this evening using your instructions and now have the blue strips and red footwell, door handle and dome lights. Looks great.
VipinLJ1949.00
