BIMMERPOST Universal Forums Off-Topic Discussions Board Let's See Your House Projects!
      05-23-2024, 02:51 PM   #1629
Marmugmotleocay
Marmugmotleocay's Avatar
Drives: 2021 BMW X3M Competition
They came back today to seal the driveway. The shine is nuts.
Esteban51011.50
      05-23-2024, 03:48 PM   #1630
cbpip
cbpip's Avatar
233
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [0.00]
Asphalt over concrete ?
      05-23-2024, 05:20 PM   #1631
Marmugmotleocay
No. Asphalt over asphalt
      05-23-2024, 06:43 PM   #1632
spazzyfry123
spazzyfry123's Avatar
4640
Drives: Here and There
Any reason for asphalt instead of concrete? I’m on the fence myself. Looks great!
      05-23-2024, 07:31 PM   #1633
Marmugmotleocay
Thanks. When I bought the house new 24 years ago its what all the houses in the development had. It's probably a lot cheaper and easier to make it look fresh.
      05-24-2024, 07:00 AM   #1634
spazzyfry123
4640
What kind of lifespan have you been getting before needing to resurface? I can't imagine it's been 24 years...?
      05-24-2024, 08:06 AM   #1635
Marmugmotleocay
I have had it sealed around every 5 years but the asphalt driveway is 24 years old.
      05-24-2024, 12:36 PM   #1636
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Concrete is significantly higher in cost.
      05-24-2024, 03:18 PM   #1637
spazzyfry123
4640
Yep! We're playing the numbers game now. New construction in a rural area, so we opted for gravel courtyard and driveway until we can make up our mind. I personally think asphalt looks cooler
Curious on the long term costs over time. Concrete could be most expensive up front, but asphalt is more expensive in the long run with its maintenance.
vreihen1619087.50
      05-27-2024, 05:54 PM   #1638
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
If I could do it again I would go like I had in Germany. Something like this. promotes less heat saturation and is repairable and durable if done right.
Just me being a bite earthy crunchy. My driveway is one big heat sink in the summer.
Buug95921301.50
      05-27-2024, 07:09 PM   #1639
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Drives: '18 x1/'13 X3/'06 330i
2006 BMW 330i   [0.00]
T.O. concrete is more expensive up front and the prep work is important for the concrete. Good solid base is important and make sure they use reinforcement wire. Saw cuts for expansion important also. Just replaced a 25 year old concrete driveway 50'L x 20'W with new concrete. Old driveway started to crack and show age, but happy how long it lasted. Regularly power wash 2x-3x year and sealing every 2-3 years. I am pretty anal about keeping it clean and stain free. Have had to deal with oil stains ( one from a leaky BMW) which can be a bit tough to remove.
Had an Asphalt Driveway at an older home prior to this one. Had it replaced, and while a lot less to replace, hated it. My kids were younger then and didn't tend to remove their shoes on their way in. The oil/aggregate from the asphalt stained our carpets. Moved out of the house soon after the driveway was installed never sealed or anything. Would never have asphalt again though.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada
18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec
vreihen1619087.50
      05-28-2024, 07:40 PM   #1640
spazzyfry123
4640
Thanks J.L.! Cost will play a factor. We’ve got a fairly long driveway (x2 because I cut in a loop) plus about a 2000 sqft courtyard area. We’re free to do as we please without restriction out here in the sticks, but don’t want to be peddling out cash all the time just to keep it alive when it could be a one and done with concrete. Good thoughts on the interior stain. Not even a consideration of mine until now.
The driveway will be pretty tight to some trees, so I’m worried about what the roots will do over time. Asphalt seems to be a bit more malleable which may be beneficial over concrete. Still a problem, but maybe less so?
I’m like you on keeping the concrete clean. Part of me wants asphalt so I’m not a slave to it again. This was my last house. My driveway had to be perfect.
      05-28-2024, 08:14 PM   #1641
SpeedBuggy
Comfortably Numb
SpeedBuggy's Avatar
Yeah, I know all about anal. Young kid with a 335i with a major oil leak pulled in my drive. He worked for a landscaping company, wanted to see my 330i. Not sure where the oil leak was on his car, but it poured a huge puddle on my driveway. Ended up getting my concrete contractor to come out and powerwash/scrub the whole driveway and reseal. $1000.00 later no evidence of the oil leak.
As the driveway looks sitting underneath my 330i 😁
MoeTE87981.00
Wolf 3352507.50
      05-29-2024, 06:13 AM   #1642
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
You can supposedly add coloring dyes to concrete before it is poured, and in these parts there are several concrete installers who do stamping so that the concrete looks like faux brick/cobblestone or rocks.....
Currently BMW-less.
      05-29-2024, 11:36 AM   #1643
UncleWede
UncleWede's Avatar
My experience with stamp and color was mixed. We poured 33 yards and had a nice stamp picked out. They threw colored dust to make it look somewhat stone-like. Stamped it all nice and I was impressed.
3 days later they came back and SAWed the stress lines into the whole thing, over the top of my beautiful stamps.
W
T
F???
Said they didn't have time to put normal stress lines THEN stamp, the concrete would set up too fast for that.
I had a friend come out about a year later who was going to pressure wash/seal for me, he has a big commercial unit he used for shopping malls, etc.. He took one look at the coloration and said "I'll just do this little section first, see what you think." Color washed right off, so he simply seals it as is except for a few oil drips he cleaned up.
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
vreihen1619087.50
      05-30-2024, 12:46 PM   #1644
unluky
unluky's Avatar
7668
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I know it some areas - there are plants that will sell colored concrete. The guy that poured my huge patio was trying to find one that could deliver to me in the sticks, but there was not one close enough so they had to used the coloring dust. It has held up well for me, but he said the colored concrete was much better as it's colored all the way through.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
vreihen1619087.50
UncleWede18324.00
      06-06-2024, 08:35 AM   #1645
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6523
Drives: 2023 Golf R
Have you looked into decomposed granite? Could be a possible alternative.
https://www.truegridpaver.com/is-dec...for-driveways/
      06-06-2024, 10:19 AM   #1646
spazzyfry123
4640
Never heard of it...? I'll look!
      06-08-2024, 01:35 PM   #1647
RickFLM4
RickFLM4's Avatar
Drives: M4
I’m in Asheville with the dogs but no wife for this and the next 2 weekends so I decided to swap out cabinet door hinges in our condo here for soft close hinges. Small project but I’ll probably do a little each weekend until done.
For some reason the drawers came soft close but not the doors. I got an estimate from someone to do it in 2019 and it was something like $1,000, which is absurd. $85 for the hinges from Amazon + a little effort.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
Buug95921301.50
vreihen1619087.50
      06-09-2024, 10:18 AM   #1648
RickFLM4
RickFLM4's Avatar
Drives: M4
Ran into a minor issue. The hinges I bought open to 105 degrees, which seems to be the standard. However for the doors in corners and near walls, they open too far and bang into other doors or the wall. So I ordered some new hinges that only open 90 degrees for those doors. I’ll end up with some extra hinges and double work for a few doors but not that big of a deal.
Never thought about opening angle so mentioning as something to bear in mind if anyone else decides on a similar project.
Buug95921301.50
MoeTE87981.00
      06-09-2024, 01:28 PM   #1649
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
Finally bought a hot tub, getting new windows installed this week, new couch is on order an new interior doors and kitchen cabinets are next. Will update with photos.
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
Buug95921301.50
RickFLM411511.00
MoeTE87981.00
      06-21-2024, 02:58 PM   #1650
RickFLM4
RickFLM4's Avatar
Drives: M4
I spent about an hour today changing a light bulb in a ceiling fan because whoever installed it over-tightened the glass shade and it wouldn’t budge. Turned to YouTube and the trick that worked for me was using a sneaker like a mallet to repeatedly hit the glass with the rubber soles until it eventually loosened up.
Then the bulb that was out wouldn’t budge… but I eventually got it out without breaking it.
I was actually considering replacing the entire ceiling fan because of this little annoyance but glad I exercised a little patience to just change the stupid bulb.
vreihen1619087.50
mjj602.00
Buug95921301.50
MoeTE87981.00
