Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Software updates discussions
      04-01-2024, 03:44 PM   #1739
humisfum
Drives: BMW M340i
Originally Posted by dhock_holiday View Post
Got 11/2023.73 installed on my 23' M340i, heard the car make alot of strange electrical noises, even heard the rear make some noises too. A couple of things I noticed:
- Drive Recorder was greyed out, took like 2 forced reboots to bring it back. Took a long time to open the app as well, maybe 10-15 seconds
- My wireless CarPlay is completly borked. No longer connects to my phone and shows the infamous "Bluetooth version no longer compatible" message. Even after forgetting the phone and re-joining I'm still getting the same error. CarPlay used to work flawlessly before on my iPhone 15 Pro. EDIT: Fixed by factory resetting my iPhone, so maybe an issue with the phone.
- Built-in Maps got updated, I don't use it personally but there you go
- Scrolling now seems smoother in iDrive8, used to be choppy and laggy
- Only some of my custom coding got reverted (Comfort Plus etc.) some of my coding actually stuck around so I guess these new updates are only patching certain things and not others.
- I'll have to test more but it seems like auto-start stop got a bit smoother, could just be my engine was hot. I'll have to test more when its colder.
- Some changes to the HUD as well, in my driveway it did not show the speed limit. Now it shows a little white box, no speed but it says LIMIT
EDIT: Also noticed that the brake hold feature is slightly revised, it used to take more "force" to dis-engage the brake hold feature, now its noticebly less. Took a bit for me to get used to.
Thanks for the full details! Wish the app just showed this in release notes.
I think I know the answer but have to ask here in hopes someone has good news about it: is the idrive 8.5 change still not possible for an early 2023 3 series?
All I wish they added to the bottom was a dial for upper body temperature and for fan on and off button 🥲
      04-01-2024, 04:28 PM   #1740
zlatko
Bulgaria
181
Drives: G21 LCI 330d Xdrive
humisfum - no LCI G20 is getting OS8.5 We shall see how it goes with rumoured LCI2. A slider for controlling upper body air temperature will be godsend, but alas will never come for our cars! The best we can do is add this to shortcuts panel for quick(er) access.
      04-01-2024, 08:58 PM   #1741
I800C0LLECT
I800C0LLECT's Avatar
Drives: BMW M340
23 LCI. I had a great experience upgrading. Start/stop is much smoother as well as braking. All my settings carried over and CarPlay works great.
The engine seems smoother too for some reason. I couldn't tell if there car was on a couple times. Maybe that's part of the improved start/stop?
      04-02-2024, 12:50 PM   #1742
XxSullyxX123
XxSullyxX123's Avatar
77
Drives: '24 M340i xDrive, '20 Rubicon
Mine has been flawless for a week and now giving me the “Bluetooth no longer compatible” message also
2024 BMW M340i xDrive
      04-02-2024, 02:34 PM   #1743
Te311
Te311's Avatar
29
Drives: 2024 M440i
Originally Posted by prjkthack View Post
I also got the 11/2023.73 on my 23 340i a couple days ago. While it does appear to have installed properly, the app on my phone does not seem to think its up to date. So it shows that I have an update, and tries to download/transfer the update.
I don't notice any obvious changes. It did of course erase my Bimmercode changes (ambient color, startup drive mode, and startup warning message).
I have the exact same issue.
      04-02-2024, 08:58 PM   #1744
Dtek
Dtek's Avatar
Drives: BMW M340i
On my 24' I feel it messed with the power quite a bit. The smoother feeling I think is more like a detune. Hard to describe, but the powerband feels more empty now, tip in would take off with a solid torque feeling and feels flat and needs to downshift. Maybe in my head, but it feels different and not in a good way and I swear it lost some of the few burbles it had being a 24'. Does this update reset adaptations? Maybe thats what is going on.
      04-02-2024, 09:50 PM   #1745
A.Bissey
A.Bissey's Avatar
Drives: 2021 M340i, 2024 M340i
Same here as well. Message on the mybmw app will not go away
-Aaron
      04-02-2024, 11:35 PM   #1746
RCtennis3811
Drives: N/A
Originally Posted by RCtennis3811 View Post
11/2023.73 just prompted to update in my 2023 M340i.
A week and several hundred miles of driving after installing the latest software in my 2023 M340i and I’ve noticed zero performance/throttle differences unlike what some have claimed here. And this includes my 40 mile round trip work commute. But maybe that’s just me. 🤷‍♂️
2023 BMW M340i xDrive
2020 BMW 330i xDrive
2018 BMW X3 xDrive30i
      04-03-2024, 12:46 AM   #1747
zlatko
Bulgaria
181
A.Bissey, Te311 - you can check this post: https://g20.bimmerpost.com/forums/sh...07&postcount=3. Same "problem" was solved by iDrive soft reset.
RCtennis3811 - I am like you: I don't feel any change in engine, throttle or ASS behaviour after 11/2023.73.
      04-03-2024, 01:08 AM   #1748
humisfum
Drives: BMW M340i
Ah yeah that’s what I feared. I made a shortcut for it too but it really is so much worse than my F30. I still kick myself for not buying that car at the end of the lease just because of the upper temp controller.
      04-03-2024, 01:13 AM   #1749
humisfum
Drives: BMW M340i
Yep same issue for me.
      04-03-2024, 05:41 AM   #1750
toddwalton
toddwalton's Avatar
1558
Drives: 2019 X7 - 2024 G26
To those who have the latest update, there is one thing that's broken that I really need fixed:
Every time I am in CarPlay and I shift to "R" the rear camera takes over the display (of course) but when I put it back into "D" the display defaults to the BMW home screen and not CarPlay where I was before.
All my other/past BMW's, once done with the rear camera and back in "D" the display defaulting back to the spot I was at in CarPlay was restored.
Can anyone who has this behavior confirm whether or not this was corrected in the latest update? Thanks!
bap340i72.50
      04-03-2024, 09:04 AM   #1751
XxSullyxX123
77
After leaving the car again overnight it allowed me to reactive CarPlay and is working again.
This may have been covered, but I didnt read it:
Did anyone notice that they removed the steering wheel vibration on lane drift. I doublechecked and the whole setting for vibration and intensity is gone. I wonder if they got rid of it since that vibrating motor that was installed in the wheel for that exact purpose was failing on a bunch of cars and creating other issues that needed a warranty remedy. Kinda Bogus to remove a feature and simply headline "driving assitance updates" or whatever the term was for part of the reason for the update.
Edit: just kidding the steering vibration option is back. It definitely wasn’t earlier and was reset back to the factory High vs where I had it. Weird that days and miles later stuff is still reloading.
      04-03-2024, 09:10 AM   #1752
zlatko
Bulgaria
181
toddwalton - I tried parking camera with AA and it worked as expected, returning correctly to AA after Parking Assistant is switched off. So it's seem like a CarPlay issue.
toddwalton1558.00
      04-04-2024, 03:35 AM   #1753
ramparts
ramparts's Avatar
1177
Drives: M40i
Same here on CarPlay. Straight back into it
toddwalton1558.00
      04-05-2024, 09:59 AM   #1754
siddsbmw
Drives: 2023 BMW M340i xDrive
Mine randomly said start upgrade in car this morning and then an hour later said successfully upgraded and the notification is gone. Never even went near the actual vehicle.
      04-05-2024, 10:19 AM   #1755
toddwalton
toddwalton's Avatar
1558
Thanks. Just to clarify- were you having the "won't return to CarPlay after reverse gear" issue prior to the new firmware version?
      04-05-2024, 10:25 AM   #1756
toddwalton
toddwalton's Avatar
1558
Thanks, but I'm experiencing something differently (I don't have Parking Assistant) that I hope the new update will solve:
1. My car NEVER starts up in CarPlay even though I turned the car off with CarPlay active. Unlike my past BMW's that remembered the last state, every single time I start the engine, I have to tap the CarPlay button on the display to get it active again.
2. When in CarPlay, when I put the car into Reverse gear (backup camera comes on) and then back into Drive to drive off (backup camera goes away) the display shows the iDrive home screen and doesn't go back to CarPlay even though I was just in it 5 seconds earlier. I have to tap the button again to get CarPlay back up again.
These are the behaviors with the July '23 firmware that I am currently running that I am hoping the new April '24 firmware corrects and am hoping someone who used to have my problem can confirm it is solved now. Thanks.
      04-05-2024, 10:39 AM   #1757
prjkthack
prjkthack's Avatar
71
I did give this a shot yesterday morning and nothing had changed immediately. Turning off all the optional data does pretty much make the app useless though as all data is not visible (except the update notification). Now, about 24 hours later, my app says that my car has updated and the notification is gone. Unfortunately, all the other data is still not visible. Hoping its a temporary thing and the rest of the app starts working properly again. lol
      04-05-2024, 11:12 AM   #1758
zlatko
Bulgaria
181
toddwalton - I use only AA and can speak only for it. But my car automatically starts AA if it was ON while switching off the car. Actually there is a setting in AA which controls that behaviour. It provides 3 options: 1) Always 2) If used on last journey 3) Default(as set by car). If CP has similar settings, can it be that some update messed these up for you?
toddwalton1558.00
      04-05-2024, 02:33 PM   #1759
mikeyb74
mikeyb74's Avatar
Drives: G20 330ix M Sport
Mine has been stuck since February 15th. Just this morning I had a notification from the BMW app stating that the update is about to expire.
BMW11281.00
      04-05-2024, 03:47 PM   #1760
humisfum
Drives: BMW M340i
Yep mine just now notified me my upgrade is finished. Someone must have pushed an update to the app lol.
