02-23-2024, 03:56 PM | #177 |
Rep 210
2024 M340i xDrive
792M 19x8" square wheels H&R Springs 28662-2 13mm spacers front and rear My opinion is that 15mm is better suited for the front for flush fitment. The rears are perfectly flush with 13mm.
Instagram: @lakeshorebimmers
03-16-2024, 08:10 AM | #178 |
Rep 14
Drives: BMW 330e Msport
03-16-2024, 08:15 AM | #179 |
Rep 14
03-16-2024, 08:18 AM | #180 |
Rep 14
Looking to add wheel spacers to my wheels on my 330e
Any suggestions on the mm? Leaning towards 12.5mm |
03-16-2024, 09:45 AM | #181 |
Rep 1,184
At that time, lowered on dinan springs.
03-16-2024, 09:46 AM | #182 |
Rep 1,184
EAS & IND recommends 12mm front, 15mm rear, however, it really is subjective to your preferred aesthetic.
03-18-2024, 12:04 AM | #183 | |
Rep 31
Please let me know did you use extended bolts? I’m planning to do the same on black car, but a little bit confused about front adaptive struts and wheel clearance. |
03-31-2024, 03:00 PM | #184 |
Rep 2
Installed Dinan 15mm spacers all around today. The rears are perfect at 15mmm - looks significantly more aggressive. If I could do it over again I'd probably go with 12mm in the front as they are just a touch wider than I'd like.
05-09-2024, 07:28 AM | #185 |
M340i
405
Rep 1,010
Drives: BMW M340i
Here is my 2021 M340i with 10mm front and 13mm rear. Stock springs and square 225 tires.
05-09-2024, 09:35 AM | #186 |
Rep 75
I recently purchased a MY23 M340i. Love the car!! I will say as many of you have, man...they sure tucked the wheels in there! I've considered spacers in the past on other vehicles, but have been worried about performance/safety, etc. It seems that they work just fine, making sure a good brand, fit, etc.
Here's my setup. 225/40 (8.9") front, 255/35 (10") back. Not wanting anything crazy, but would like a more aggressive stance. Suggestions on brand, size, who to have install. Thanks for your input! |
05-09-2024, 10:07 AM | #187 |
M340i
405
Rep 1,010
Drives: BMW M340i
Any of the name brands should work. I was going to go with burger motorsports but found a great deal on CTS turbo so I bought them. Install is simple. Just remove each wheel to put them on. A tire shop may do it if you don't want to.
https://www.ctsturbo.com/product/cts...5x112-cb-66-5/ |
MitchDog52.50 |
05-09-2024, 10:50 AM | #188 | |
Rep 75
What about sizing? 10 front 12 rear? Some have mentioned larger in front. Not sure if the staggered setup makes a difference. |
05-10-2024, 03:36 PM | #189 | |
Rep 64
Some corporate tire shops won’t install wheels with spacers. Spacer size depends what wheel width you have. Scroll thru this thread and find someone with same wheels or similar specs (width and offset) |
MitchDog52.50 |
