10-30-2023, 10:45 AM | #221 | |
Rep 15
I then locked the car. There were no clicking/switching noises whatsoever and as pointed out in another post the hazard warning light and the light under the light switches on the dash remained on until the battery was fully charged. Full charge took approximately 1.5hrs My question is: is it safe to leave the charger connected long term or am I better to disconnect it and connect it say once a month to charge up the battery ? What are others with the PRO25 doing regarding above ? I'm a little confused after reading the BMW bulletin here: BMW MHT Battery Charging.pdf It talks about damage to the 48volt Hybrid battery but appears to be a bit contradictory and confusing. Am I safe in thinking that the 48Volt battery will also charge from the 12V battery after the 12V battery is fully charged provided the bonnet is left open and the charger is left connected ? Can anyone explain what the bulletin is actually trying to say ? Finally I recommend the PRO25SE model over the PRO25 as it has a hanging bracket on the unit and the charging cable is around 5 meters long. Only negative is that the mains cable is short which limits hanging options. As the PRO25S/SE is expensive, it might be a good idea to compile a list of other chargers that work for the MHT. If anyone comes across one that works then just add it to the list to help others. |
10-30-2023, 11:27 AM | #222 |
Rep 102
People, I think this is being a little over thought. Since the late 80's I've used a Battery Tender Plus on my three BMW's and my other cars and many motorcycles with both AGM and lead batteries w/o a problem. I put it on my 2020 M340i every three/four weeks for the night mainly in the winter when I not using it, doors open or locked, hood open or closed. It's all good.
10-30-2023, 11:40 AM | #223 | |
Rep 532
My car isn't used regulary and so I leave the charger connected to the car, and use a timer socket to turn it on overnight on for 4 hours per day. |
10-30-2023, 06:13 PM | #224 | |
Rep 15
Have you got yours set to "Lithium" and how is it connected to enable charging of the 48V lithium Hybrid battery ? From what you are saying does it mean that when the car is driven it charges the 48V Hybrid battery first which in turn then charges the 12V AGM battery ? |
10-30-2023, 06:14 PM | #225 | |
Rep 15
10-30-2023, 06:20 PM | #226 | |
General
13266
Rep 19,785
Edit: Here is a document and some more information about the 48v system that has been posted in other threads. There is a bidirectional charge controller that can charge the 12 volt battery from the 48 volt system, or charge the 48 volt battery from the 12 volt system. Leaving the hood up tells the controller to shut down the 48 volt system and allows both batteries to charge from an external 12 volt source. With the hood closed, the 48 volt system charges both batteries while driving. Link for mobile app users -48v Electrical System 48V vehicle electrical system.pdf
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 Last edited by TurtleBoy; 10-30-2023 at 07:02 PM.. |
CSBM52721.00 |
10-31-2023, 09:38 AM | #227 |
Rep 102
No, I ordered the car in Oct. 2019, received it Nov. 2019, shortly before they stopped making them in Germany.
10-31-2023, 09:39 AM | #228 |
General
13266
Rep 19,785
Then your experience doesn't apply since it is a different system.
10-31-2023, 10:59 AM | #229 |
Rep 15
I'm still confused regarding the charging process using the CTEK PRO25S charger.
If the charger is first charging the 48V hybrid battery which then charges the 12V battery then is it really a good idea to leave the charger connected long-term since having full charge all the time on the 48V lithium battery is not a good idea and will decrease the lifespan of the battery ? Usually lithium batteries are best stored at around 50-60% charge. |
10-31-2023, 11:40 AM | #230 | |
General
13266
Rep 19,785
10-31-2023, 01:02 PM | #231 | |
Rep 1,777
10-31-2023, 04:03 PM | #232 | |
Rep 15
I have contacted both CTEK and BMW UK regarding long term use of a 25A charger on a MHT vehicle and if it results in any possible issues with the 48V battery and will post their replies here. I'm aware that when the battery is fully charged the charger will just monitor the battery and charge it up if it drops below a certain level. |
10-31-2023, 04:53 PM | #233 | |
General
13266
Rep 19,785
11-04-2023, 02:14 PM | #234 |
Rep 102
11-04-2023, 03:05 PM | #235 |
General
13266
Rep 19,785
11-05-2023, 01:58 PM | #236 |
Rep 102
11-10-2023, 02:41 PM | #237 | |
Rep 15
I wouldn't think the car could control charging of it's batteries when it's asleep ? |
11-10-2023, 02:49 PM | #238 |
Rep 15
So far I've had no luck finding any answers from BMW UK direct or their dealers
I got a reply back from CTEK ( I had sent them the BMW bulletins regarding battery charging on MHT cars which I got from previous posts on here ), see below: "It seems you got the same experience of BMW dealers as me. I got to see those bulletins back when I did the investigation on why a MXS 5.0 won't charge BMW mild-hybrids. The BMW workshop/dealer where I live only gave me nightmares in regards of how incompetent the employees were. Another customer tried contacting the general agent for BMW here in Sweden but got no good answer from them either. BMW and other manufacturers don't mention this and that's what triggered me to investigate it. With 10 years experience as a diagnostician for other German brands, when my investigation concluded, I figured out that mild hybrids requires at least 20A chargers because of the fact that they automatically charge the 48V battery. So when using something weaker it won't charge at all, not even the 12V. As I previously said, from the chargers point of view there shouldn't be any issue. However I cannot know for certain how it will affect the 48V battery. It's a lithium battery so there shouldn't be a problem but I'm not 100% sure. Connect it as it states in the user manual and make pauses now and then is what I would've done." I hope this helps. Med vänliga hälsningar/Best Regards, Mirsad Fazlic Basically I have two options: A- Leave the CTEK PRO25SE connected all the time B- Charge battery to full using the PRO25SE then remove and repeat every 2-3 weeks How are other owners of the CTEK PRO25S using it ? Last edited by Tommygunn; 11-10-2023 at 02:57 PM.. |
11-10-2023, 03:10 PM | #239 | |
Rep 15
Leaving the charger connected without the timer socket will mean it stays in maintenance mode all the time and will be monitoring the battery and only charging it up if it falls below a certain voltage. Do you have any idea which battery it is monitoring in the maintenance mode, the 12V or the 48V lithium one ? |
11-10-2023, 04:02 PM | #240 | |
Rep 1,777
11-10-2023, 05:40 PM | #241 |
General
13266
Rep 19,785
Yes, that is what I'm saying. It takes care of the charging at all times as it essentially doesn't sleep for that.
11-10-2023, 05:44 PM | #242 |
General
13266
Rep 19,785
Definitely do not do this as you will drain your 48v battery. If you close the hood for a long period of time while on the charger your 48v battery will likely need to be replaced. Many dealers found this out and is why they disconnect the 48v from the system when having the hood closed.
