04-01-2023, 02:58 AM | #1 |
Rep 24
lowering springs vs coilover set. what did you go with?
those who went with lowering springs and oe dampers, did it creak after a year or 2 on your g20? my audi went with that setup and it creaked after 2 years so i thought perhaps it might be better to do coilovers this time for my g20.
not sure if the savings is worth it, and not sure which bilstein coilovers to go with. what are anyone's thoughts on the bilstein evo s and b12 pro kit? |
04-01-2023, 08:00 AM | #2 | |
Rep 1,515
peelerec1005.50 g20exaudinoob20.50 |
04-01-2023, 08:10 AM | #3 | |
Rep 1,127
I don’t think many G20’s have installed the lower tier coil over systems. Most install springs or go all out for KW’s or Ohlins, as Chubbie did in the above response. Not to say Bilstein is an inferior company, but there coilover kit is a rather simple one for this chassis that I think people don’t see the value. I think peoples thought proces is “if you want to lower the car and get some slight performance gain and on a budget, choose springs. If you want to get the best available as of now, KW or Ohlins.” I would second chubbies decision on Ohlins. I had them installed on my Evo X years ago and they were the best modification on that vehicle.
Chubbiejones891.00 |
04-01-2023, 08:19 AM | #4 | |
Rep 1,515
peelerec1005.50 |
04-01-2023, 03:18 PM | #5 |
Rep 4,186
always coils if money not an issue
-JLT- |
Chubbiejones891.00 peelerec1005.50 |
04-02-2023, 09:45 AM | #7 |
Rep 24
a quick google tells me this will give me better comfort than bilstein. is this right? wouldnt mind dropping more monies if it gives a more comfortable ride.
my previous lowering springs with oe dampers were stiff af. nice drop and nicer on the turn but it was too stiff. |
04-02-2023, 03:02 PM | #8 | |
Rep 1,515
cfm56d7b5897.50 |
04-03-2023, 10:10 AM | #9 |
Rep 24
thanks for the inputs guys. kind of leaning towards ohlins but i am also going to check out kw v2.
04-03-2023, 01:17 PM | #10 |
Rep 1,515
04-03-2023, 09:50 PM | #11 |
Rep 829
I have g26, recently installed HR springs, was not my cup of tea. Car looked great but it was way to stiff for me and my struts would bottom out on smallest bumps.
I could lastv2 week on them and went back to stock springs. Will be considering coilovers next, but definitely not lowering springs. |
04-06-2023, 09:55 AM | #12 |
Joint Chiefs of Staff
24279
Rep 190,975
If budget is not a concern, coilovers are the better option.
For a daily driver, springs (preferably adjustable) are enough.
04-11-2023, 12:25 AM | #13 |
Rep 219
+1 for Ohlins R/T, I was previously on Dinan springs and can say the difference is night and day don't even look at springs if your budget allows. I bought them from Mike too, always got the best prices and transparency IMO.
BMW M340i
-Stg 2 Full Flex (Ecutek), downpipe, Ohlins R&T, Dinan intake, Dinan Turbo Inlet @g20.m340i Porsche 911 Carrera T (retired) |
04-11-2023, 10:06 AM | #15 |
24279
Rep 190,975
Thank you for the support
04-21-2023, 11:17 PM | #16 |
Rep 79
Drives: 2020 M340i xDrive | 1987 325iS
non adaptive suspension M340i xDrive on H&R springs with stock shocks. Also did the Dinan ride quality & handling kit, it's just bump stops and dust covers, don't think it was worth it honestly as the car does still bottom out on medium bumps as others have said. Also on cold weather I do get a suspension noise I and my mechanic cannot find. Might go KW V1's or V2's with the goal to improve ride quality.
05-07-2023, 11:27 PM | #17 |
Rep 10,265
Well said. Very little to add other than Ohlins do not disappoint.
05-08-2023, 12:18 AM | #18 |
Masterchief
367
Rep 1,022
Any eta when ohlins will be back in stock?
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
05-15-2023, 09:56 PM | #20 |
Rep 79
You all have me wanting to ditch these H&R springs. Anyone experienced both KW and Ohlins on a G20? I’m looking for more suspension travel and comfort as I live in a winter state.
05-16-2023, 12:24 AM | #21 |
Rep 1,127
I have a buddy who tracks his G20 M340i as well. He first started his track journey with KW V3’s and then switched to Ohlins R/T. My initial impression of a soft setting of the Ohlins was that the car was on clouds. Very soft. As compared to his KW’s in there softest setting did not comply as well with harsh roads near the track. For that reason, my subjective 20 min experience of both is the Ohlins are better for daily + street + soft + track suitable coilovers. Not to discredit the KW’s, though. They are great as well.
Turn Signal31.50 |
05-16-2023, 02:39 PM | #22 |
24279
Rep 190,975
It ultimately depends on which KW model you're considering. Ohlins are often praised for striking an outstanding balance between road comfort and track performance, much like KW markets its V2 variant.
Turn Signal31.50 |
