07-06-2023, 11:27 AM | #265 |
General
10513
Rep 41,031
Drives: 2018 Alpina B6 650ix GC
Tells me nothing. Whichever ECU's were custom coded, you need to VO Code them with original unmodified FA to reset them.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-06-2023, 11:51 AM | #267 |
General
10513
Rep 41,031
I have no idea what you are saying.
07-06-2023, 12:36 PM | #269 |
General
10513
Rep 41,031
Do as I wrote and it should work, assuming it worked from factory.
07-08-2023, 08:54 PM | #271 | |
Rep 73
Just to double confirm my understanding, when we say VO coding it means
Thanks |
07-08-2023, 10:02 PM | #272 | |
General
10513
Rep 41,031
2) You select one or more ECU. You have to determine which ECU(s). 3) The VO Coding values at the FDL Code level are determined by FA Data and CAFD Boolean Logic. 4) Yes
07-10-2023, 07:36 PM | #273 | |
Rep 73
Learn a lot from you! |
07-19-2023, 03:08 PM | #275 |
Rep 16
hello , I did retrofit 5DF , if I push the steering wheel acc +/- distance , I get the message I could be purchased in the idrive store? but this is not possible a I can't activate cruisecontrol with stop and go. is this possible to activate with BU ? it is the small radar frs that needs to set active some kind of activation code ?
07-19-2023, 05:46 PM | #277 |
Rep 16
07-19-2023, 08:16 PM | #279 | |
General
10513
Rep 41,031
Latest is v1.0.56, which included only a small bug fix for 13in HP laptop resolution.
BLK.G20215.50 |
07-20-2023, 09:03 AM | #280 |
Rep 43
Drives: 2020 X3, X7
Thank you for this its very helpful, few questions. Is this bimmercode desktop app? I am assuming so. Are the releases for bimmercode desktop the same as the mobile app at released at the same time?
07-20-2023, 09:07 AM | #281 |
General
10513
Rep 41,031
BimmerCode? This is a Thread for BimmerUtility.
07-26-2023, 06:22 AM | #282 |
Rep 1,179
Not sure if I'm being thick, but can't find the default wi-fi password for the BU enet wifi adapter. I tried 12345678 and 123456789 but didn't work and no instructions came with it. Nothing on the website from what I can see either.
07-26-2023, 06:37 AM | #283 | |
General
10513
Rep 41,031
Password is BUWIFI_2023 There should be a sticker on the adapter.
07-26-2023, 10:49 AM | #284 |
General
10513
Rep 41,031
You need an ENET WiFi adapter, not just a USB x LAN Adapter.
07-29-2023, 01:23 PM | #286 |
Rep 56
Need help to restore my BDC.
I tried the BimmerUtility app for the first time tonight and was looking around the app when connected to my car. Accidentally touched the VO-code on my BDC_BODY3 and it coded it right away 🤦🏼 Of course I have all kinds of faults now. I went on their homepage and read that it’s easy to restore and that automatic backups are always made. So, how do I go about restoring my BDC module? I’m using BU on my iPhone so you know how to instruct me 🫣 |
