08-05-2023, 08:15 PM | #1 |
Jewel Runner
332
Rep 911
Vibration on braking and hard acceleration
As the title says, the car shakes at all speeds while braking if any kinds, whether light, normal, or emergency. Car also shakes slightly when accelerating quickly. Starts speed does not make a difference.
Acceleration shaking could be unrelated and is very different from the shaking felt during braking. Took it to the dealer today and they said they need the car for about a week to figure out the issue. The problem with that is the car is lightly modified and they said any warranty work would be voided due to the mods (that's a different argument). Initial feedback from the SA is that there are worn bushings but wouldn't speculate further than that Car has been on KWv2 for about 2.5yrs/9k miles Has 10mm Dinan spacers (I'm thinking this is the culprit but assume I'd feel shaking at cruising speeds and I don't) Rear tires are new, fronts only have 12k miles on them Again, the car does NOT shake all the time. Only under specific conditions - braking from any speed with any pressure level applied - WOT acceleration, starting speed does not matter Just looking for input and possible causes and to see if anyone has experienced this. Already speaking with my local Indy shop to diagnose. I feel like it's a cop out for the dealer to blame the car being lowered as the cause but what can I do.
08-05-2023, 08:46 PM | #2 |
Rep 395
In most cases the dealer mechanic has limited understanding of exactly how all the suspension components work together. He/she has a book with measurements and calibration procedures, and is only trained to follow that procedure and make the proper adjustments. Once you lower the car or make other suspension mods, the “book” measurements from BMW are no longer applicable.
He/she cannot diagnose or fix it because of the non-standard parts. It’s the same principle used when a computer is really screwed up - reload an OEM copy and start over. |
08-06-2023, 12:36 PM | #3 | |
Jewel Runner
332
Rep 911
Hopefully the Indy will get me sorted. Thanks |
10-30-2023, 02:40 PM | #4 |
Rep 71
Did you ever figure this out? Also, when you mention the shaking, is it throughout the entire car, or is it felt primarily through the pedals, steering wheel, or both?
10-30-2023, 02:48 PM | #5 |
Jewel Runner
332
Rep 911
Shaking was felt throughout the entire car.
As I suspected BMW Dealership was blowing smoke and the rotors were out of spec. Replaced both front rotors/pads and the issue was immediately gone
