01-19-2022, 05:03 PM | #68 | |
Rep 1,969
What happens when you just punch it? What happens in a standard 60-120 run? You know, just driving normally like the hooligan I am.
Arctic Metallic\CF Splitters,Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1\M-Performance Brakes\Cobb Tuned\xHP Flash ->
01-19-2022, 08:49 PM | #69 | |
Rep 483
As it stands, it's in a weird spot. The M3P is probably more fun to drive, while this is is heavier than a Model S LR without the power. |
GOLFFRR10861.00 |
01-20-2022, 05:57 AM | #70 | |
Rainbow Racer
1008
Rep 2,540
I've seen videos of a guy testing 0-100 kph using different modes Eco Pro was around 5.0 (tells me it's always RWD, but this is an assumption based on the i4 edrive40 on dragy has done it around 5.1 seconds on a cold surface day) Comfort was around 4.0 Sport was slightly quicker Sport Boost, LC was around 3.5
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
01-20-2022, 02:18 PM | #71 | |
Rep 272
01-20-2022, 04:54 PM | #72 |
Rainbow Racer
1008
Rep 2,540
Yes, that is the video. I love how the car literally did 0-100kph in about 3.5 seconds (+/- .2 seconds) at 39% SoC in that video Battery state of charge be damned! Also, the first acceleration run was 88% at 386km of range. Given when it was posted back in Dec and it was in northern Europe, that seems to be a decent range to boot.
-Loe P.-
01-22-2022, 03:55 PM | #73 | |
Rainbow Racer
1008
Rep 2,540
-Loe P.-
01-23-2022, 07:09 AM | #74 | |
Rep 272
01-24-2022, 03:25 PM | #75 |
Rep 9,708
Some more data points for 0-62mph.
Sport boost + LC 3.94 Sport boost 3.94 Comfort 4.08 Eco 4.30 Looks like BMW have replicated typical BMW axle tramp to perfection to give that ICE feel. |
01-24-2022, 07:26 PM | #76 |
Rainbow Racer
1008
Rep 2,540
To be fair, damped roads + TCS/DCS off.
I like that BMW gives you full disability of those nannies with a touch of a button. I figured there would be some difference in each mode minus LC which looks like should be reserve to dry/higher traction surfaces. Eco-Pro doesnt appear to be too much of a snail and seems perfectly adequate for 95% of the time for me. On a side note, is it ever dry in Europe in winter?
-Loe P.-
01-25-2022, 01:44 AM | #77 |
Rep 267
01-25-2022, 03:40 AM | #78 |
829
Rep 3,982
55% SOC and wet pavement. Do you actually think those conditions make these meaningful numbers??
01-25-2022, 07:43 AM | #79 | |
Rep 9,708
It's an AWD which makes the difference between damp and dry, very small, maybe a couple of tenths. Wheel-spin is often seen as slower and undesirable, not necessarily true. Most performance engineers agree that some wheel-slip is optimal to get highest traction and allows for the drive system to gain inertia. No idea about SOC affect on power. I would hope that full power is still available at levels down to 30% at least. |
01-25-2022, 08:26 AM | #80 | |
829
Rep 3,982
https://insideevs.com/news/381551/vi...ance-soc-dyno/ Furthermore, in the i4 making more HP and almost 600lbs of torque, wet traction will be more of a factor. Beyond me how people testing these cars would test at a low SOC. Car Wow did the exact same thing, and yet the BMW still pulled on the M3P. Wheel spin vs no wheel spin is never good if your cutting power output compared to a dry surface with less throttle intervention, lol. Last edited by hotrod182; 01-25-2022 at 08:32 AM.. |
01-25-2022, 10:27 AM | #81 | |
Rainbow Racer
1008
Rep 2,540
Excessive wheelspin is never good even on an AWD car, and this is what 5 years of drag racing and AWD has taught me. You want peak grip without bogging down an ICE car, but there's no such think on an BEV car with "bogging" so any wheelspin beyond a slight amount on dry pavement would be considered excessive. Wheelspin, even a minute amount as compared to a prior run results in slower 60ft times, resulting in slower 100ft times, resulting in slower 330ft times, resulting in slower 1/8 mile times, resulting in slower 1000ft times, resulting in slower 1/4 mile times.... You are 100% spot on, we've seen 3.3 seconds out of this car on dryer pavement.
-Loe P.-
01-25-2022, 10:33 AM | #82 |
Rainbow Racer
1008
Rep 2,540
So which one outside of a Tesla competes with the i4 that is on-par with it 100-200 kph and 0-100 kph times?
-Loe P.-
01-25-2022, 12:29 PM | #83 | |
Rep 9,708
See the tests here (this same YouTuber reported on the loss of power earlier): By the way, this test was done at low temperatures and wet tarmac, so pretty comparable to the m50 video I posted. |
01-25-2022, 12:41 PM | #84 |
Rep 9,708
Probably Taycan GTS, Turbo and Turbo S. Different price level though. :
01-25-2022, 12:44 PM | #85 | ||
Rep 9,708
01-25-2022, 12:58 PM | #86 |
Rainbow Racer
1008
Rep 2,540
We know on dry pavement, both can do 0-60 in 3.3 seconds or better in some cases, so they are pretty comparable on dry pavement.
Waiting for more dry weather acceleration runs. In reviewing the i4 M50's video, it looks like TCS/DSC was still engaging itself up to 65kph which would tell me it's more than a chirp.
-Loe P.-
01-25-2022, 01:03 PM | #87 |
Rainbow Racer
1008
Rep 2,540
I was thinking the same thing too, the only competitors thus far are the Polstar 2, Tesla M3, and upcoming BEV C-class and A4 cars. Not sure what else is in the compact/mid-size entry level "sports" sedan class without stepping up to the next class of the Taycan/Model-S etc etc.
-Loe P.-
